Question about Water Water Heaters
Water heater piolet light won't stay on
Piolet LIGHT Won't stay on
olddewsons
  • 38 Answers
SOURCE: The piolet light will not stay lit on a GE Profile
Make sure there is not a direct draft hiting heater. this wil always blow out flame.
It could be thermo-cuppling. If this is bad,it wont leave gas come in to keep piolet light lite. hope this helps. :)
Posted on Jul 07, 2009
motor1258
  • 6674 Answers
SOURCE: The piolet light will not light. If I turn the
You may have a plugged orifice in the pilot tube assy. If you have any way of getting to the orifice with compressed air, and blow back, it may dislodge it, if it is plugged. If possible, carefully remove pilot tube at valve end first, so that if it is debris in there, it blows clean of the tube, so it won't clog again. Otherwise you'll have to remove complete assy. Another thing to try as well, is to shut valve off, loosen fitting at valve for pilot tube, AND MAKING SURE NO FLAME OR SPARK ANYWHERE IN THE AREA, take a spray bottle with dish soap and water mixed (bubble tester) and then spray at pilot fitting when it is loose, and push pilot, to see if any bubbles appear, indicating gas flow. If no flow there, then I'd get a new gas valve.
Posted on Jan 26, 2010
SOURCE: installed upgrade to water heater and piolet light
New gas water heaters drip condensation the first time they are lit.
The dripping stops.
You should be fine.
Keep us posted.
You can add a comment and I will help further if needed.
Posted on Nov 03, 2010
  • 10865 Answers
SOURCE: Whirlpool gas water heater model FG1H5040T3NV. The
Hello. I see this all the time with these Whirlpool units. Do this:
Make sure that the end of the thermocouple is over the pilot light. The therocouple needed to be pushed farther thru the hole in the bracket.
That may solve your problem, I hope it does.
That said, if this is a new unit, seriously consider returning it. IF it is not new and the suggestion above does not solve the problem replace the thermocouple. IF that does not solve it, replace the gas valve. Joe
Thanks for choosing Fixya!
Posted on Nov 29, 2010
SOURCE: pilot light won't stay lit on new water heater
1) Get more air to the water heater and see if problem continues.
2) Read the following pdf-s for things that might apply to your situation.
http://waterheatertimer.org/images/Negative-pressure.jpg
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
3) Read pdfs above first, and then Add a comment with missing information below, for possible do-it-yourself help.
Does this water heater have a blower?
Is gas valve electronic? Or does gas valve have a dial?
If gas valve is electronic, have you checked outlet with circuit analyzer?
Did pilot light work correctly for a while? If so how long?
Where is water heater located? Hot attic? Closet? Garage? Is area dirty and dusty? Has air intake been cleaned?
What color is pilot flame? Clear blue or yellow-or-orange?
Have you inspected inside of combustion chamber for dripping water?
Posted on Aug 29, 2011
Why won't my pilot light stay lit
Try replacing the thermocouple and make sure the piolet flame is heating the thermocouple
Jul 29, 2014 | Little Giant Water Heaters
Installed upgrade to water heater and piolet light lit fine. for a minute the flame turned yellow as condensation driped but when it stopped flame went back to blue.
The dripping stops.
You should be fine.
Keep us posted.
Nov 03, 2010 | Whirlpool Water Heaters
Piolet lite will not stay lite. Takes awhile to lite after it dose lite it kicks off again
Sounds like a bat thermocouple to me. Replace it they are not very expensive.
Good Luck,
Gil
Mar 01, 2010 | Reliance & 30 Gal LP Gas Water Heater
Jan 25, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
The piolet light will not stay lit on a GE Profile Smart Water heater.
Jul 05, 2009 | Water Heaters
Pilot light wont lit up
Change The Thermostat Cause If Your Getting Gas But The Water Heater Doesn't Detect The Heat It Will Close The Valve. When Lighting You Hold The Button Down For About 30 seconds so the thermostat will detect flame and stay lit. Check To Make Sure The Thermostat Is Where It Should Be. Heres A Picture Of What It Will Look Like.
You Can Replace Them If Need Be Will Be Available At Sears Or Home Depot. Also They May Sell Them At other Local Hard Ware Stores.
Happy Fixing And Thanks For Using Fixya.com
Sincerely,
Michael Scott
Jan 19, 2009 | Vanguard International Vanguard BY Rheem...
The pilot won't light up
Hi Welcome to fixit.com
Make sure the gas/propane is on and or working elsewhere in the house. If the piolet wont light ....and its a standing flame piolet ....its the thermocouple gone bad. Please rember to leave me some positive feedback ! Thanks !
Dec 16, 2008 | Bosch AquaStar Indoor Natural Gas Tankless...
Water Heaters Logo
44 people viewed this question
Top Water Heaters Experts
freddyfox
Kenneth Walker
Are you a Water Heater Expert? Answer questions, earn points and help others
