The belt on my awia px e860 has come off, how does it go back on? Can anyone help me please, a photo or two would be great thanks
  • Audio Player... Master
  • 5,342 Answers
Will this help?
http://www.manualslib.com/manual/207101/Aiwa-Px-E860.html?page=2#manual
Posted on Apr 22, 2015
  • Anonymous Apr 23, 2015
    Very helpful just what I was after, thank so much I can use my turntable again and listen to my vinyl :-D
djproaudio
  • 515 Answers
SOURCE: Aiwa PX-E860 turntable
Don't understand. If it doesn't turn on, how do you know the electronics are ok? More than likely your transformer shorted, and will need to be replaced.
Posted on Sep 24, 2007
  • 42 Answers
SOURCE: what size belt do I need?
There are zillions of belts out there. I hope you still have the broken one which will give you the profile of a new belt. Measure the diameter of the sub-platter under the platter. The belt you need well be a slight stretch fit. Then, with the platter back in place, slip the belt over the motor pulley making sure it is not twisted.
Posted on Jan 24, 2009
lesliemurphy
  • 69 Answers
SOURCE: A needle for AIWA PX-E860?
try this company?
mailto:info@needledoctor.com
Posted on Oct 07, 2009
  • 47 Answers
SOURCE: My PX-E860 turns on, but will not spin.
Just needs a new belt. You can get those at audio shops. Just take the table off and take a look at the belt size (should say) or take the belt to an audio shop and they can find the size.
Posted on Oct 14, 2009
Testimonial: "That was it. It had been sitting in my basement for about 10 years. I'm assuming the moisture dried out the belt."
  • 396 Answers
SOURCE: how do I attach the turntable belt to the Aiwa px e850
Lift the platter off the turntable. You can identify the motor spindle by using your fingers to turn the round shaft which rotates freely. Remove the rubber mat off the platter. Place the belt around the outside of the drum on the bottom of the platter. From the top of the platter, place your finger in one of the platter holes and tension the belt so it will not fall off or twist. Griping the platter trough the holes while keeping tension on the belt place the platter on the turntable aligning your finger with the belt to the motor spindle. Place the section of the belt on your finger over the motor spindle. Replace the rubber mat on the platter.
Posted on Jul 21, 2010
The start and cut switches do not seem to work I have it open and the wires do not seem to be attached to anything
Aiwa lid close control switch Turntables Questions ... - Fixya
www.fixya.com > Forum > Tags > lid close control switch > Turntables
Aiwa turntables lid close control switch related questions and answers. Ask your Aiwa... Ad. Question about PX-E860 Turntable ... aiwa lx 70 turntable needle arm My aiwalx 70 turntable is not working. I can power it up, and when i press the start/cut button the platform rotates, but the needle arm does not move to play the .
Aiwa fusing unit Turntables Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fusing unit > Turntables
the drive belt on my Aiwa px-e860 turntable has come off. how do i put it back on Lift... the start/cut button the platform rotates, but the needle arm does not move to play the . ... will not turn,belt o/k fuse o/k Check any switches to see if they work.
Jan 16, 2016 | Aiwa PX-E860 Turntable
Put belt back
I attached a guide for helping you to replace a turntable belt.
Jul 07, 2013 | Aiwa PX-E860 Turntable
PX-E860 Turntable: I need to replace the cartridge of my aiwa turntab...
my aiwa PX -E800 TURNATBLE has stopped working ,, is there anywhere i can get a replacement turntable .
Regards
Trevor
May 17, 2010 | Aiwa PX-E860 Turntable
The drive belt on my Aiwa px-e860 turntable has come off. how do i put it back on
Lift felt on platter and and lift the platter section off the unit by putting your thumb and forefinger through the two large holes and pull upwards.There should not be any special routing for the belt and should go directly onto the spindle motor to your platter. Place the belt around the inside rim of the platter while it is still off the unit. Now replace the platter and move the platter around until you see the spindle motor through one of the holes. Use some tweezers to manouvre the belt onto the spindle motor. On some units you will have to lay the belt out inside the unit, replace the platter and manouvre the belt onto the platter. Hope this helps
Dec 14, 2009 | Aiwa PX-E860 Turntable
How do I attach the turntable belt to the Aiwa px e850
Nov 05, 2009 | Aiwa PX-E860 Turntable
Oct 14, 2009 | Aiwa PX-E860 Turntable
TURNTABLE SPEED TOO SLOW. IS THERE ANY WAY TO ADJUST IT.
The liely cause of the slow speed problem is the belt. Your turntable is belt driven, like components in your car's engine compartment. As the belt ages, it can begin to slip. Replacement of the belt will probably restore the speed once again. The PX-E860 turntable has been discontinued. There are parts, such as the belt, that are still available. How much longer these parts will be available for remains unknown. If you like the the turntable, you should consider purchasing several belts as the next time you need one, they may not be available or may cost much more.
One source for replacement belts (there may be many others, ie: eBay):
http://www.elexatelier.com/aiwa.htm
You might also need a manual to direct you as to how to go about changing the belt. The manual is a free (after registering) download below:
http://www.retrevo.com/support/Aiwa-PX-E860-Turntables-manual/id/1077bh126/t/2/
Oct 05, 2009 | Aiwa PX-E860 Turntable
What size belt do I need?
Dec 28, 2008 | Aiwa PX-E860 Turntable
HOW TO INSTALL AIWA PX-E860 TURNTABLE BELT
http://www.archive.org/details/Turntable_Belt_Installation
above is a generic video that applies to almost all belt driven turntables including yours that will show how to install the belt and a few other things. the website shown in the video lists your belt under the "find my player" button on the left side of that site.
Dec 26, 2007 | Aiwa Z-L500 Shelf System
Sep 23, 2007 | Aiwa PX-E860 Turntable
211 people viewed this question
 Grubhead
Grubhead
