Question about Microsoft Close Combat: First To Fight xbox, 2005
What is the password?
Password required for extracting file
What's the password to extract the GTA liberty city
If its a torrent it should say in a README file, or its a private .zip file requiring a secret password
Nov 05, 2016 | Video Game Consoles & Games
Tip
Rar password recovery
This is a tip explaining how to recover lost RAR file passwords. I will also provide you with a link where you will be able to download the software required to recover your password. You need to remember, that this process of recovering the password, may take a few hours.
For this purpose, i will password protect a rar file, and recover the password by using this software, RAR password recovery magic.
Click HERE to download the software. You will need to wait 1 minute before the download will start. Choose the "Regular download" option to download.
Once you have downloaded the software, we can extract and install it. Here is how it is done.
Step 1:
Extract the.
I set the download directory for the file to be saved on my desktop
When the download completed, i extracted it to my desktop.
Now , i have opened the extracted folder, to have a look at the contents.
YOu will see a couple of files, but, you only need the first one. Open the first folder. You will see a rar file once again. All you need is to extract this folder. It contains the install file, as well as the serial.
Now, open the folder you have extracted. You will note that there is a serial code as well. After installation, we will enter the serial key, and star recovering.
Now the software is installed, all you need to do now is to enter the serial code. You can have the serial code, as well as the name in the folder with the serial file, as above mentioned. Choose the enter code option to enter the serial.
You need to fill in the same name and serial as shown. You can leave out your email address.
Ok, now we are done installing. Now we can start to recover. For this purpose i created a password protected rar folder. The password is 123. This is a easy password, but the software can manage up to 6 letters and charters.
Here is how we insert the rar file and start recovering.
Open the software, you should have a icon on your desktop.
Click on the OPEN tab, and brows to the password protected folder you want to recover.
Select the settings tab, and choose if your password was either letters or numbers, or a combination. Mine was only numbers, so i selected only the number box.
Now, just click on start, and wait for the software to recover your password. This might take a while, so you can minimize the trey, and continue with other work if you like.
When the password is recovered, you will hear a sound notification, and see a pop up. This pop up will contain the password.
I really hope you can find this helpful. Please rate accordingly.
Kind regards
Andrea
on Mar 01, 2010 | Computers & Internet
How to Use WinRAR?
The WinRAR application will compress the files and save in the same folder or location as the original files. The WinRAR program can also extract compressed files with a RAR or ZIP format. Select the files that require extraction using the pointer. Right click on the selected file to display a drop down menu.
Materials Needed:- PC
- winrar archiver program
- file to compress
- compressed files
Step 1
Ensure that the computer you are going to use for compressing files has WinRAR program installed before proceeding with the compression of file.
Step 2
Select all the files to you want to compress by using the mouse and the CTRL button or the SHIFT button. The CTRL button is for selecting several files in the same folder or location. The SHIFT button is for selecting blocks of files.
Step 3
Right click on the selected files to display a drop down menu. Select the 'Add to Archive' option from the drop down list. This will display a WinRAR window menu.
Step 4
Input a name for the compressed files in the Archive name section in the General tab. Ensure that the name is not similar to any other compressed files in the save location.
Step 5
Select the file format of the compressed file after the deciding on the name. File formats can either be RAR or ZIP. There are also other options such as deleting of the original file after the compression, putting authenticity verifications, and putting a recovery record.
Step 6
Click the 'OK' button after completing all the required fields in the menu. The WinRAR application will compress the files and save in the same folder or location as the original files.
Step 7
Step 8
Right click on the selected file to display a drop down menu. Select the 'Extract files' option from the menu. This will display a window from the WinRAR program.
Step 9
Specify where the extracted files will be located in the 'Destination path' option of the General tab. Do not replace the destination path if the extracted files will also be placed in the same location as the compressed file.
Step 10
Click the 'OK' button after filling the required fields in the window. This will start the extraction process of the RAR or ZIP file.
Oct 19, 2016 | Computers & Internet
I need extract password for CSI Hard Evidence
It sounds like the zip file you're trying to access is an encrypted zip archive. So to correctly open the zip file, you need to identify what exactly it was encrypted with and I should be able to help!
Feb 27, 2015 | Computers & Internet
Extract protected rar files
To extracted protected a protected rar file, you can use Winrar.
Download and install Winrar and then open your rar file using the program. It'll ask you for your password. You must have the password to extract the file. If you don't know it, then you will not be able to extract the file. Once you've got the file open, just choose where you want to extract it to and you're done.
Hope that helps.
Mar 28, 2011 | HP Pavilion a1620n (882780664494) PC...
I forgot my password and dont want to delete all my files. Anything I can do?
You could try a data-recovery company to extract the data from the chips without requiring a password.
Dec 16, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Rar file extraction
Ive never needed a password for rar but make sure its the free version and you can also try tugzip its another zip program but combines rar winzip files into 1 program.
Jun 16, 2009 | HP Pavilion a1320n (882780261747) PC...
Microsoft Close Combat: First To Fight xbox, 2005 Logo
630 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
