Question about Saws
What type and size of blades do let use? - Saws
    Sergeant:
  • 468 Answers
Call a blade manufacturer and let them help you in what right blade to use for your cutting preferences. I purchase my blades on sawblade.com . They are located in Houston Texas
Posted on May 13, 2015
What other makes of attachment will fit the MtD power unit?
I have used blades from Toro on my MTD mower, found them better then the what MTD gave me ,bit stronger and cheaper. Just be carefull, when you take the blades off,do keep the 2 screws that hold the blades in place, they have different sizes depending on what brand you have, blades can be swapped but the screws and bolts can not be changed with other types. For belts etc you can use any " generic " brand, size matters but brand is not a big difference, i used belts from 40$ and 100$ , no difference what so ever. To be honest , the cheaper one is still running after 2 seasons while the expensive one snapped after one season.
Apr 20, 2016 | Mtd Garden
Tip
Choosing the right hacksaw for your job
For every project that you want to work on, there will be a different set of tools that you will need to use. The hacksaw has different types of blades and frames that can be switched out for the different projects that you are working on.
There are three main kinds of blades that the hacksaw can use and each one has different benefits. The teeth on the hacksaw blade will range between 14 and 32 teeth per inch. The thicker the blade the fewer teeth there will be per inch on the blade. The types are regular, raker and wavy. Regular blades are good for soft metals that don't have a lot of metal and the teeth will be closed together touching and alternating left and right. The raker blade has teeth placed in sets of threes and are best used fro cutting through thick metals. The last kind of blade is called a wavy blade, on these ones the teeth are in a wave pattern that are great for making smooth cuts in hard thin metals.
When it comes to hacksaw frame types there are two types to look at the fixed frame and the adjustable frame. Fixed frames are only able to hold a blade of a single sized length of blade. The adjustable frame can hold different length blades typically between 10 and 12 inches. The blades that you will buy for a hacksaw will have holes on either end of the blade. These holes are used to attach and dettach the blades from the frame.
Whatever the blade that you are using make sure that when you are sawing through metal make sure that you go slow because rubbing metal on metal will generate a lot of heat and can spark. You can also ruin the blade on your if you are sawing too quickly.
on Feb 02, 2014 | Saws
How to fit blades correctly
Hi Stephen:
Sounds like a basic question, so will give some basic info.
- WORK SAFE - Always remove the spark plug lead before changing or working on blades on push type lawnmowers.
- ONLY REPLACE BLADES WITH SAME SIZE BLADES that have the same mounting connections.
- WEAR GLOVES - These blades are sharp, and can have nasty little pointy bits that snag skin.
- Install blades with the flat side of the cutting edge closest to the ground.
- Make sure that the correct upper and lower mounting washers are in place.
- Snug the attaching bolt in SLOWLY and make sure that any notches or gear-type teeth are properly aligned, then tighten.
Any questions?
Please reply by using the comment box.
Jun 30, 2015 | Garden
What blade for black and decker 34338 bandsaw
If you say blade TPI and width, it would totally depend on the size and type of the material you are cutting. I buy my blades on sawblade.com. They custom weld band saw blades.
Sep 25, 2014 | Saws
What size of blade
The blade length is probably almost 100" , but I suggest you try to calculate the length , try this method Calculate Belt or Band Saw Blade Length VintageMachinery org
Jul 08, 2014 | Saws
What size blade duds it take
You can measure the length of the blade or take it off and go to a store and get a mulching blade it doesn't have to be a Poulan Pro
blade a generic mulching blade of the same size will work and be cheaper. Tractor supply handles a lot of different types of blades.
Jun 17, 2014 | Poulan Pro PR550N22SH 22Inch Briggs ...
I need to know what size/type of jigsaw blade to purchase for my SKIL 4230 Model# F012423000.
The size and type will depend on your needs when cutting. Fortunately, this model can use both T- and U-shank blades.
My personal preference if for the T style as i find they hold better.
use this picture and info as a guide. When you go to hardware store look for a combo set for metal and wood.
metalworking will have fine teeth, woodworking will have larger teeth.
Hope this helps
Thanks
Please rate FIXYA
May 20, 2011 | Garden
I have a black&decker brandsaw but i dont know what size blade to put on it,it is a b.d.339, ai
Its a 1512mm blade. I did a search on Dewalts Servicenet and it no longer shows, so you'll need to locate a reseller that specializes in metric blades. Its correct model number is BD339 type 1 ( no peroids). Hope this helps.
Mar 02, 2011 | Garden
Wiper blade size for 01 chevy impala
i think its a 22 but just to make sure go to walmart to get your new wiper blades they have a machine that you type in you vehical and year and it tells you what size it is
Dec 17, 2010 | Chevrolet Impala Cars & Trucks
Need to change saw blade, lost instructions
1st, !!UNPLUG the saw!! Wear gloves to prevent nicks from contact with the saw blades.
If this is a handheld 'skill-saw' type saw, use a piece of wood to chock the saw blade from turning as you use a proper size socket/wrench to loosen the bolt which holds the blade.
The bolt will loosen counter-clock wise. It will probably be very tight, and you will have to use some effort to loosen it.
Remove the bolt, lift the follow guard and remove the blade.
Replace the blade with a like size diameter blade by raising the follow guard, inserting the blade, replacing the bolt, using a piece of wood to keep the blade from rotating and TIGHTEN the bolt. You will almost feel as if you need three hands to accomplish this procedure but its been done millions of successful times.
Good luck. :)
Mar 11, 2009 | Hand Tools
Saws Logo
418 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
