The E1 error code on your Bosch cooktop indicates that there is an issue with the power supply to the cooktop. This could be caused by a faulty power cord, a faulty power outlet, or a faulty circuit breaker. You should check all of these components to make sure they are working properly. If the issue persists, you may need to contact a qualified technician to diagnose and repair the issue.
Please make sure that your laser-distance measure is charged properly to start. View it's screen for any listed error codes that could give us a clue to watch the issue is. If the error code hints at restarting the device, then we can move in that direction. If the error isn't revealed from perusing any troubleshooting documentation that comes with your device, then you can reach out to Bosch for repair/replacement help.
Contact a laser service center. I doubt anyone will be willing to work on it. It would be a lot of research for a 2.00 part. Usually you will be unable to find parts for big box store lasers. A laser dealer may have a broken one laying around that he can pull a used part from. Just a a precaution I'd recommend never purchasing a laser from a retail store such a sears or home depot. If possible go with a Leica Geo-systems unit. Topcon, spectra physics, and trimble are also good lasers that have all parts readily available. In the service industry we call cst, bosch, robotoolz, "throw away lasers" because if anything at all goes wrong you throw it away. If i recall properly I have searched for parts for Robotoolz and contacted the manufacturer in the past. I was told that they are not supported and parts are not available. Check around and see if you can find a service center with a used part. Google search (Leica Geosystems, Topcon, Trimble Laser dealer).
Hello 1 Turn on ps, then remove any disc in there. 2 Insert cleaning disc.Make sure tv is on and your set to proper input as you would if playing games. 3 A image should come on screen. 4 Use controller to navigate to cleaning cycle and hit x button i think to start cleaning.
If this does not work take laser cleaner back,and purchase another one.Not all work in ps3 or ps2.
you have 2 posibilities the first one is very unprobable and the second will fix the oven
1) the new gas valve is defective and while the proper amprage is being supplied to it,it simply wont open
2) even though the bake ignitor is indeed coming on it isn't drawing the proper amp draw (3.2-3.6 amps) to open the gas valve ,the very fact the ignitor comes on totally eminates that the control isn't providing power to it for the bake ignitor to heat
i have been a appliance repair technician for over 30 years and am 100% confident that by replacing the bake ignitor the oven will work fine
Hi -
I can't see how any installation problem would cause this - if the dishes are still wet at the end of the cycle, you'll probably find the water isn't heating during the wash cycle. The dishwasher uses steam to heat the washing compartment and dry the dishes. It would appear that the dishwasher isn't heating water internally.
Even if the washer was accidentally connected to the cold water supply ** (see note), this shouldn't happen as regardless of the water supply temperature, the washer should still heat the water to the correct temperature internally.
** UK dishwashers should be connected to the cold water supply. For US installations, dishwashers are commonly connected to the hot water supply. For other locations, please consult your installation instructions.
I suggest you start a regular wash cycle and leave it to run for 10-15 minutes. Then open the door and test the temperature of the water in the base of the washer by hand. The water should be hot and there should be steam present in the washer when you open the door.
If the water is cold or only warm, the water isn't being heated internally or isn't heating to the correct temperature, in which case you should contact the retailer or Bosch Service immediately for a replacement. Do not accept an offer of repair on a brand new washer!
Additionally, do not attempt to repair the dishwasher yourself when under warrantly as this will invalidate the warranty.
Hope this helps. If you need further assistance, please let me know your location and the model number of the washer. This should be laser-etched into the top of the door if you can't find it on any of your paperwork.
Regards,
BElectric
it is usually a flash from the brushes that contact the armature. they may have not seated yet. there is the possibility that you have a problem and if it continues you should take it back or contact Bosch customer service.
