Question about Microsoft Xbox 360 Console
How do i know how many gigs it is without having to plug it in and turn it on?
  • HollywoodUndeadFan
    HollywoodUndeadFan May 28, 2015
    What type of console is? There are 3 main xbox 360 types.
  • 3 Answers
If you still have the box it should say on the side. Otherwise I don't think there's any other way to check
Posted on Jun 10, 2015
What's your problem?My husband got a Vivitar ViviCam 7028 as a rewards gift from his company and we've been busy taking lots of photos and video on it, but when I try to download the photos to my...
The first problem is explained by the error message. Your camera is consuming too much power to go through a USB hub. Try connecting it directly to a USB port on your computer, without going through a hub.
The second problem is most likely related to the card reader. You didn't specify the exact model of Belkin reader so I can't give you a definite answer, but it appears the reader is designed for SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it will not work with devices not specifically designed to work with SDHC cards.
To sum up: If you want to use a USB port, connect directly to it without going through a hub. If you want to use a card reader, make sure the reader is SDHC-compatible.
If you have additional questions, or some part of the above isn't clear, please feel free to respond to this post.
Oct 22, 2011 | Cameras
Losing 1 gig per day
There could be a number of reasons for losing 1 Gb of downloads each day.
If you are viewing or downloading movie, video or YTube, these are usually large files, movies are Gb in size.
If your e-mail have video or audio attachments, these can be Mb size files.
If you have a wireless Internet connection and if it is not secured properly, someone could be accessing your Internet without your knowledge and using up your download allocation.
Is someone else using your computer, do you know if they are accessing the Internet, chat room, blogs, etc.
Jul 24, 2009 | HP Computers & Internet
Hard drive from gateway solo pro 40 gig will it work in toshiba
I'm pretty sure it will. The only thing is that Gateways of that generationn used a custom connector which plugs onto the hard disks standard IDE / ATA connector.Just pull this extra connector off and you can use the disk in any machine.
Also ,Toshiba used similar adapters,so if Toshiba's using one on your model,then you'll need to palce the toshiba adapter onto the hard disk from your Gateway. You may also have to go into your BIOS ,and make sure the BIOS recognizes the disk if your BIOS isn't already set to "auto detect".
Mar 28, 2009 | Gateway Solo 9300 Series (5501056) Plug-In...
Windows says not enough space on pny 8 gig flash drive
Try formatting the drive as NTFS instead of FAT32 (assuming you are using it only on Windows computers). FAT32 doesn't support files over 4GB.
For more info, see http://www.google.com/search?q=fat32+file+size+limit
Feb 08, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
FITTING EXTRA RAM INTO MOTHERBOARD
What you can physically fit and the space available is not the same thing, Crucial is an excellent site but it might say that you have the capacity to fit x megs but whether you have the empty slots is different (see the last paragraph), and you will not really know untill you open the case and look.
The actual fitting is simple enough if you can reach the slots without dismantling the whole machine!
Supposing you can clearly see and reach the slots, with the machine off, and the power cord removed - yes removed! Gently press on the white clips at either end of the fitted memory it will pop up, lift it out without touching the gold terminals, notice the slot in the bottom edge.
Now, and without altering the orientation, place it back in the slot lining up the slot to the peg in the receiver. Now with a little pressure you can clip the memory module back in the slot and the tags will pop back into the locked position.
Okay you have done it, its as easy as that. So when the new stuff arrives you will know how to fit the new modules.
Your new modules could have twice the value of the old ones, so if your board can handle say 1 GIG of memory in two slots, thats a max of 512 megs in each, you might have 2 x 256 megs fitted and there are no empty slots, so pop out the 2 x 256 and drop in the 2 x 512 making an upgrade of ½ a Gig (in each slot) giving a total of 1 Gig.
The probability is that there are four slots, two of which might be empty, its the combination making up the total that determines how much extra you can fit....
I hope thats clear??
BluRay
Nov 22, 2008 | Asrock K7VT4A+ Motherboard
Lexar 2 gig flash drive
every flash drive is plug and play with windows xp or vista..i got this problem too and i have just re installed my windows. make a backup first the format your pc..
tips:use an original version of windows
Oct 21, 2008 | Computers & Internet
5 second beep/alarm
Hi krusty_623.
If this is new RAM, you might want to try removing the battery from the motherboard, resetting the CMOS (clears out all the old hardware settings) and putting the battery back in so that the motherboard redetects the RAM as if the setup was brand new. I've had the same problem only once on a RAM upgrade and it baffled me. Once I reset the CMOS the motherboard accepted the new RAM without any problems. I don't know if this will work for you, but it's a simple thing to try.
Spacetime
Oct 19, 2008 | Computers & Internet
Computer won't read my ipod.
Press and hold down on the center button while pressing and holding down on the menu button. IPod is rebooted. Try plugging it into ITunes.
Jul 05, 2008 | Apple iPod nano
Ram memory
Okay, I have a stupid question, the more powerful the chip the hotter it runs. It could be the second slot will not work with a 1 gig because of heat issues and ventilation?
I have the same problem, with 2 one gig chips. I am going to try to replace the easy access slot with a 1/2 gig chip. I'll let you know.
Cheers,
Paul
Mar 31, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Microsoft Xbox 360 Console Logo
95 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
