How do I finish my installation? - Computers & Internet
  • NOEL
    NOEL Apr 18, 2015
    Hi Ron Jurenka, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • Al Clark Apr 18, 2015
    What are you installing on what
  • 5,631 Answers
Please complete your question: what are you installing
Posted on Apr 21, 2015
How to remove code sc792 ricoh MP5000b no finisher?
The machine does not recognize the finisher, but recognizes the bridge unit.
• Defective connector
• Defective harness
• Incorrect installation
• Defective harness
Mar 24, 2016 | Ricoh Office Equipment & Supplies
Should I pick a pre-finished or an unfinished floor?
Re-finished flooring has a great advantage over unfinished flooring. Both floors install exactly the same; however, once the pre-finished floor is installed you're all done. An unfinished floor requires sanding and then the application of urethane. This can take an extra couple of days with an incomparable amount of aggravation.
Feb 06, 2013 | Building Materials
How to install staple finisher on lexmark T634
Try to check under printer properties. Just go to Printers and Faxes > Right click on the Lexmark icon > Properties > Configuration tab > Check under Configuration options.
Nov 21, 2012 | Lexmark T632 Laser Printer
Unfinished XP upgrade
The xp set-up page appear on the middle of the set-up right after the restart (first one ) ..if this is the case you should insert the disk again ..and let it finish the installation ..(will stay a few minutes and do nothing and after that will start installing devices have patience )
It may also be a case of files not being loaded well and in this case just take the installing from the start by inserting the disk again ..and press any key when it asks ..format the C drive after choosing it as location ..and continue with the loading of files and after restart ..do not press any key ..and let it boot to the set-up and go on with finishing installation .From the restart point it should last about 39 minutes to the finish ..
Please do not hesitate to ask any question if you do not understand ..
In sort ..insert the disk and start it ..and let it continue the installation cause it is just to the middle ..when you finish ..install drivers ..make teh connection ..and install antivirus..and you are done .
Dec 21, 2011 | Computers & Internet
Pc Game Error
Hi! I'm trying to install My Horse and Me the PC game, the installation goes through everything normal and but when I press Finish it gives me this error message
Unhandled Exception
Error Number:0x80040702
Description:Failed to load DLL:GameuxInstallHelper
When I press OK the installation window where you press Finish pops back up and it says
InstallShield Wizard Complete
The wizard was interrupted before MyHorseAndMe could be completely installed.
The system has not been modified.To install this program at a later time,run the installation again.
Click Finish to exit the wizard.
So I press Finish and then if I try to go and find it its not there its been uninstalled. And I have tried installing it several times with no luck .
So if you could please help me that would be wonderful because I really want to play my game.
Thank You!
Nov 14, 2009 | Atari Video Game Consoles & Games
How can i find out my parking brake adjustments on my 2003 ford escape?
Parking Brake Cable Adjustment Vehicle with low series floor console
  1. Remove the floor console front finish panel.
    1. If equipped, remove the manual transmission shift knob by turning counterclockwise.
  1. Remove the floor console rear finish panel.
    1. Apply the parking brake.
Vehicle with high series floor console
  1. Remove the floor console finish panel.
All vehicles
  1. Remove the adjustment nut clip.
  1. Turn the parking brake control adjustment nut so that the parking brake control stroke is three to five notches when pulled.
  1. Confirm the parking brake is applied.
  1. Install the adjustment nut clip.
  1. Install the floor console rear finish panel.
  1. Install the floor console front finish panel.
    • If equipped, install the manual transmission shifter knob by turning clockwise.
Jan 21, 2009 | 2003 Ford Escape
Toshiba satellite L200
Installing the Yahoo Messenger 8.1 needs an Internet connection. It could be that your laptop is disconnecting to the Internet while you're installing Yahoo Messenger 8.1 that's why it will not finish the installation process.
Make sure that your laptop has a stable Internet connection before installing the YM 8.1. If you have a modem or a router, it would be better to connect it directly to the modem or to the router with an ethernet cable rather than using the wireless connection.
May 07, 2008 | Toshiba Satellite Pro A200-EZ2204X...
Staple function is grayed out - how do you turn it on.
You do n ot need to enter the Service Tech code to ajust finishers. In fact that code should rarely be entered.
Is the option available while copying?
If it in the driver, select the greyed out option and let the driver inform you of the problem/setting.
Has the finisher been identified in the "instaled options" tab of the driver?
Normally, the driver or panel will indicate what the conflict is if any. If all these have been set correctly, contact whomever installed this finisher and have them do it properly.
Apr 29, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
