Why does my computer have a floating thing that says 3:digital input self test feature check
  • 5,631 Answers
You monitor is not properly connected to the computer. Check the video output cable and specially, the pins. You may have a doubled pin no making contact
Posted on Apr 18, 2015
5 Suggested Answers
kozachek
  • 122 Answers
SOURCE: I am getting a self test feature check box floating around on my
Ensure that the monitor cable is firmly connected to both the back of the monitor and to the video card on the PC.
Posted on Mar 16, 2010
Testimonial: "quick response"
SOURCE: screen is showing
it mean that
* either the data cable which goes from computer to monitor is loose or bad
* the computer is off or not turning on .
Posted on Apr 17, 2010
  • 109 Answers
check your vga cable!
Posted on May 11, 2010
  • 269 Answers
SOURCE: self test feature check stuck on screen
from my past history dell has/is problems with the E153pc and the E172pb is it under warranty and have you gotten hold of dell about this I have had cases where they have replaced monitors.
sorry it was no great help but dell knows of this problem. dont let them bull**** you.
Posted on Jul 21, 2010
HDMI to VGA
You need a video format converter to connect in between.
Apr 30, 2013 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Self test feature check stuck on screen
Jul 21, 2010 | Dell E153FPc 15" TFT LCD Flat Panel...
Dell gx270 not communicating with monitor. self test feature check is floating on monitor
This is a self check for the monitor. This self test means that the monitor is not getting a signal from your computer. Have you installed any video cards in this computer?
If its onboard video meaning you never installed a video card then your video card is bad. Try purchasing a video card and installing it in the computer and your problem should be fixed. I hope this helps you. Any other questions feel free to ask thanks.
Jun 23, 2010 | Dell OptiPlex™ GX270 PC Desktop
Dell flat screen goes white and colored block appears and floats
Check that your monitor is connected properly and tightly to the computer. If it is, then the monitor may be bad. Borrow a friend's monitor and try to see if it works, if someone else's monitor works, then replace your monitor.
Mar 11, 2009 | Dell gx 150 p3...
Flat Panel Monitor: 1907FPt
Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove both Digital (white connector) and the Analog(blue connector) cables from the back of computer.
  3. Turn on the monitor.
    The floating 'Dell Self-test Feature Check' dialog box should appear on-screen on a black background if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green. Also, depending upon the selected input, one of the dialogs shown below will continuously scroll through the screen.
    1. This box also appears during normal system operation if the video cable becomes disconnected or damaged.
    2. Turn off your monitor and reconnect the video cable, then turn on both your computer and the monitor.
    If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Jun 04, 2017 | Dell E173FPb 17" TFT LCD Monitor
Dell172fpb 17" monitor
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and the monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove Analog (blue connector) cables from the back of computer.
  3. Turn on the monitor. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually.
  4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
Thanks
proton
Oct 26, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
Inoperative monitor
Here are a couple things to try.
1. try the input select button on the monitor (The minnus button) without pressing the OSD menu button 1st, see if it changes to analog.
http://support.us.dell.com/support/edocs/monitors/1703fps/en/controls.htm
When the DVI self-test screen is up, it is indicating monitor is in DVI mode.
2. If that doesn't work, try a DVI to analog converter on the DVI port on the monitor and connect the analog cable to the converter. See if you get any video that way.
3. If you can access the On-Screen Display (OSD Menu) perform a factory reset.
Sep 29, 2008 | Dell UltraSharp 1703FP Flat panel TFT 17"...
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
