How do i fix it
When i connect to TV via HDMI cable I can see video BUT no audiuo
    Habit-Forming:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 166 Answers
Unit has prob got a faulty dsp / hdmi pcb
Posted on Apr 22, 2015
  • 43 Answers
Maybe if we knew what receiver and tv you had, we could help. There's like a menu function on the receiver that is set wrong.
Posted on Apr 20, 2015
CremeStout
  • 115 Answers
SOURCE: Analog RCA input to HDMI output?
You have said the correct thing HDMI is digital therefore Analog will not pass.
You might have RCA audio outputs on your cable box so either send them into the TV from cable or into the AMP then use AMP volume to listen to TV audio (select unused input and remember it is for TV) the key is to remember that cable box will drive the initial vol so raise or lower cable vol then use AMP vol to obtain desired volume.
Posted on Dec 03, 2007
SOURCE: No sound from digital cable thru AVR3200 after adding HDTV - DVD plays fine
you need a digital coax cable and then connect it to 6.1 also the digital cable type is not a coomon type so check that also
Posted on Jan 23, 2008
The Machine
  • 788 Answers
SOURCE: How to Connect HDMI Components with AVR 3805 as Hub
In reference to the comment you added to our chat session:
Just connect your receiver to your TV using the same cable your receiver is currently using to connect to your TV, be it Composite, S-Video, or Component. Just switch your TV to that input when you need to set-up something on the receiver.
Posted on Jul 09, 2008
DickCanFixIt
  • 948 Answers
SOURCE: I'd like to connect my HP laptop to Yamaha 663 receiver
Connect your S-video output from the computer to an empty S-video input on the receiver. Connect your speaker output from computer to analog audio input on the receiver using a 1/8" stereo connector to RCA patch cable. You may have to set your computer to output video to the S-video jack, consult your HP documentation for instructions.
Posted on Dec 29, 2008
  • 4 Answers
SOURCE: Onkyo TX-SR705 - No Audio - Flashing HDMI
The posabilities is power amplifier on your reciever is bad,
replays reciever or repair it.More likely this is IC amplifier located on the main board of the reciever
Posted on Apr 17, 2009
How do I connect the wireing
The VCR portion is connected to yhe TV via yellow-end cable(video) from "video out" to TVs "video in" and red and white-end cables(audio) from "audio out" to TVs "audio in". The DVD plays via HDMI cable from "HDMI out" to TVs HDMI in. S-video cable can be used if no HDMI terminal is available on TV. External tuner in (cable TV, Satellite) is connected to the video and audio in terminals or better yet if S-video out is available on the tuner box.
Aug 24, 2014 | Magnavox ZV427MG9 DVD Recorder/ VCR
I am trying to connect ps3. (bought may 2012 with uncharted 3). To my denon 2313 via hdmi. No video at all or sound? Please help
You need to tell the PS3 to use the HDMI cable output. To test have you tried connecting the PS3 directly to the TV. Once you have that working then add in the AVR.
Jan 19, 2013 | Denon AVR-2313CI
My problem is that i have a 56" philips with hdmi etc... i have my dvd recorder plugged in via audio video cable .... i have my cable coming thru hdmi... i cant get my recoreder to record whats...
Hello rpgscope,
I am assuming both your dvd recorder and cable is plugged into your tv? Conncet a composite cable (rca cable or aka red, white, and yellow cable) from cable box OUT to dvd recorder IN. That should fix the problem. I mention composite cable but if you another slot for av then go ahead and use that. Make sure you have AV connected from dvd recorder OUT to the tv IN. Also the cable box should be HDMI OUT to tv IN. If you have it connected like this, it should work. Hope this helps.
- Joe
Aug 30, 2011 | Toshiba Televison & Video
I RUN THE CHANNEL SCAN FOR CABLE BUT I CAN NOT PICK UP ANY CHANNELS.
If you are connecting to cable via a cable box you do not need to scan for channels. You simply need to be on the input channel that corresponds to the connection type you are using. For example, if your TV and cable box are connected via HDMI you need to press your Input or Video Source button until it says HDMI. Cycle through your Inputs and see if that fixes the issue.
Hope that helps!
Jul 19, 2011 | Coby 40 TFTV4028 LCD TV
I needed to know how do connectd my dvd player with my tv and ditail cablebox form coxs
HI,
IN THREE WAYS
1. FROM DVD'S OR CABLE BOX'S HDMI OUT PUT TO ANY OF TVS HDMI IN PUT VIA HDMI CABLE ( FOR THIS BOTH SHOULD HAVE HDMI CONNECTIVITY )
2 DVD'S OR CABLE BOX'S COMPONENT VIDEO OUT TO TVS COMPONENT VIDEO INPUT VIA COMPONENT VIDEO CABLE ( NORMALLY COMES IN THREE COLOUR ). ALSO CONNECT AUDIO USING A TWO RCA CABLE.
3 . AND ALSO THROUGH COMPOSITE VIDEO CONNECTION.
SELECTION FOR THE TWO DEPENDS ON U. ACCORDING TO UR REQUIREMENT.
OK
Dec 13, 2010 | Televison & Video
Connect my xbox on reicever
If your xbox has HDMI connector then you HDMI cable to connect it to the receiver and another HDMI cable to connect receiver to the TV. Receiver should support both video and audio over HDMI.
If your xbox doesn't have HDMI, connect the video directly to your TV using whatever connector/cable is available (in terms of quality from best to worst: HDMI, component, s-video/scart, composite).
Then connect audio to the receiver via optical spdif cable.
Jan 29, 2010 | Yamaha RX-V463 Receiver
If hdmi cable sends audio and video info from my laptop to my tv why can't I hear anything? I have video but no audio. the Audio all say hdmi/high def audio and are working properly
Have you "muted" the sound on your computer?
Have you "muted" any of the outputs (MIDI, speaker) on your computer?
Have you "muted" the sound on the TV's built-in speakers?
Have you "muted" the sound on any external speakers that are connected to your TV?
Does your TV have _more_ than one HDMI port? Have you tried them all?
Got a friend with a TV with a HDMI port?
If so, connect your laptop via THEIR HDMI-cable to their TV.
Also, connedct your laptop via YOUR HDMI-cable to their TV.
Jan 09, 2010 | HP Pavilion dv5-1002us Laptop PC
Toshiba 32AV500U HDMI issues
The Toshiba 32AV500U cannot display 1080p. Hook up your PS3 to your computer monitor, provided that it can display 1080p, or some other TV that can, then change your Video Output settings under Settings> Display Settings and uncheck 1080p, which will allow the PS3 to display in 1080i. Once you do that, then hook up the Toshiba via HDMI and it will work with no problem.
Jul 23, 2008 | Televison & Video
I am trying to connect my Samsung DVD Recorder to my Samsung PS-42D7HD tv via the HDMI cable but it just comes up "no signal" on the tv - nothing at all. Also have an Olin HD Set top box with...
Hello
by befault your dvd recorder is transmiting signals via component video, so what you need to do is this connect both cable HDMI and Component or just a video cable then go into setup and then select video out via HDMI your video will go off on the screen and then with TV remote slect input source HDMI on TV and it should work fine.
Thankyou
May 09, 2008 | Televison & Video
46 people viewed this question
 Grubhead
Grubhead
