Question about Optics
Is the red cross hairs suppose to turn on when unit is turned on.Is there soom way of turning them on?
If i push the power button and hold it the cross hairs turn on but as soon as I release the power button the cross hairs go out.Only once have the cross hairs turned on and stayed on in the four times using the unit.
snakehead
  • 1074 Answers
SOURCE: Polaroid FLM 2011
have a tech repair your tv the problem is in the power supply and related circuit.good luck.
Posted on Apr 14, 2007
The Machine
  • 788 Answers
SOURCE: My computer won't boot and the CyberPower 825 AVR makes a continuous sound.
It sounds as though the UPS is not receiving power. Check that it's cable is properly plugged into the wall. Also verify that it's internal ground fault interrupter has not tripped, it's usually a little red button on the back of the unit, it should be pressed in and should stay that way, if it pops out then there is a problem with the ground of your electrical outlet. Also check that the breaker for that electrical has not tripped at your fuse box.
Since the UPS is not receiving power the batteries have discharged and that is why your computer cannot start, there is not enough juice from the UPS to boot it. That is also why it is making a noise as most UPS's sound an alarm to indicate that they are not connected to power.
There is a chance that the batteries in your UPS have gone bad or that something has become faulty in your UPS. Try plugging your computer and monitor directly to the wall bypassing the UPS to see if they work fine.
Posted on Jun 18, 2008
SOURCE: delphi roady 2 won't power up
You have a bad power plug on the unit. The solder connection are loose. The one have is doing the same thing. The power plug pins have came lose and need to be resolder. Working on how to take the unit apart to solder the connection.
Posted on Dec 09, 2008
  • 50 Answers
SOURCE: Dryer shuts off after releasing "push to start"
this problem sounds like it can only be 1 of 2 problems. the start button or the motor is not going into run winding. i found over the years that the blue wire i believe is burnt at the motor. this can be repaired quite easily .cut the wire and strip it putting a new connector on. if you need to you can buy an assortment at a hardware store. if every thing is good check the start button for burnt wire if ok then you most likely have a bad motor. i'm pretty sure though that a wire is burnt off at the motor
Posted on Jan 30, 2009
  • 4 Answers
SOURCE: blinking red lights
Take out all the cables (HDMI,POWER,RCA,etc...) and then plug just the power back in and see if the TV turns on, and make sure when you take the power cable out, take it out from the back of the TV, when you plug it back in it should click.
If the TV powers up then try plugging in your HDMI cables and see if that works.
Posted on Feb 20, 2009
Hisense tv stuck on upgrade screen but isn't updating. Says 0% constantly.
Try resetting the set if possible. If no reset button you can also unplug set while it is still turned on. Then push in and hold the power button for a few minutes. Then re plug unit, cross fingers and push power button to see what happens.
If still does it, then something has to be wrong with your main board circuits.
Nov 24, 2016 | Hisense Televison & Video
Where can I find a replacement power switch?
Power switches are safety components that can only be replaced by manufacturer approved parts. Contact Crosley for where you can get approved parts.
Nov 24, 2015 | Crosley Entertainer CR-79 Turntable, CD,...
Fusing unit
fuser problem, push in order clear modes (yellow button) 1 0 7 and hold the red stop button for 5 seconds the screen will change, turn off copier red power switch and turn back on if problem comes right back you need a service call
Sep 16, 2013 | Ricoh Aficio 1035 Copier
Emerson tablet hard reset
With the unit powered on, you unplug it from power source.
Then push and hold the power button for about a minute. THEN, replug back in and turn on. And cross your fingers.
Aug 07, 2017 | Tablets & eReaders
Denon AVR-1908 won't power on
Are you getting a standby light at all? Is it flashing? Do you here a click when you plug the unit in? If the answer is no to all of these then you blew a fuse. If you do have soome sort of standby light, then your set is in protect mode. More than likely for a blown channel. If no lights, but you ar egetting a click, you could have a bad transformer. Use a DVM and see if it is open or not. Good luck
Aug 23, 2012 | Denon AVR-1908
Control station won't turn on.
That sounds like a hardware faulty i can only advise you to contact logitech.
Jun 04, 2009 | Logitech Z-5500 Computer Speakers
I HAVE A SLIM PS2 RED LIGHT COMES ON SHOWING HAS POWER BUT RESET BUTTON WONT TURN GREEN when I push the power button.
well first of all your only supposed to press it. dont hold down. i dont really know why, but i suppose if anything something having to do with the power cord. proud to be part of your help
-brandon
Mar 30, 2009 | Sony PlayStation 2 (PS2) Console
My controls wont work
Hi, Sounds like you need to check the sensor bar. Make sure it is plugged in or if you have a remote sensor bar check it's batteries. If this doesn't work you can clear the console sync info by turning off the console power, unplug the console for a few seconds, plug it back in and turn the power back on. When you get the Health and Safety screen, press and hold the console synchro button for 15 seconds. Now resync your wimotes by using the red buttons in the remote battery area rather than the screen sync. If you need more help let me know as there are other things like a stuck button on a controller to look for. Good luck!
Jan 28, 2009 | Nintendo Wii Console
Leapster doesn,t respond when the pen touch screen
for leaster 2 -
turn off unit, take out cartridge.
hold the hint button, turn unit on.
press A button, touch the stylus on all the cross hairs that appear.
power unit off when done.
power back up.
(got these from the leapfrog site and it worked for me!)
Sep 29, 2008 | LeapFrog Leapster Electronic Book:...
Red then green blinking lights.
push power on at button (no need to hold button)and press proceed button for 2 secounds at the same time you turn on power and it should reset.
Dec 24, 2007 | NEC PlasmaSync 50MP1 50 in. Television
Optics Logo
302 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
