Question about Canon Office Equipment & Supplies
MX492 unsupported ink cart 1485. Brand new printer
SOURCE: unsupported cartridge message
I was having this problem with a Z730. The printer was finally working again after removing and inserting ink cartridge like 40-50 times. No pun intended. After installing cartridge try turning off printer and then back on.
Posted on Dec 06, 2008
gwbm
  • 353 Answers
SOURCE: error msg "installed ink cartridge cannot be recognized"
With refilled cartridges, this is usually due to a faulty "reset" of the chip. Simply reset it again and it will usually be OK. If you don't have a chip resetter, buy one very cheaply on E-Bay.
Posted on Mar 19, 2009
don_farr
  • 1018 Answers
SOURCE: installed a new Lexmark ink cart and got an incorrect message
When you say, "Brand new Lexmark Ink Cartridge..." is that a true statement? Is this a Lexmark Factory new cartridge?
If it is, then the cartridge itself has a warranty against defects. Contact Lexmark Technical Support and tell them the problem and the purchase information and have them replace the cartridge for you.
Posted on Aug 18, 2009
SOURCE: Hp Designjet 500 not recognising ink cartridges.
I've had that problem with unfinished cartridges showing up as empty. I imagine that it could be a bad cartridge as well but I hear and feel the ink when I shake the cartridge. Therefore the ink is there. I also have a problem with some inks. I find the HP inks work perfectly whereas other manufacturers' inks work on and off. I need a solution as well. Right now I have full cartridges that are not picked up by the Designjet sensor. Any idea?
Posted on Oct 20, 2010
damnor01
  • 1179 Answers
SOURCE: My esp 3 kodak printer
Your printer needs a service, in other words the waste ink sponges need to be cleaned and dried. They then need to be replaced and the printer reassembled. Then the Epson counter resetting software needs to be installed.
With this software the printer can be set to zero, it will work perfectly after this bit of attention.
It is a good printer, it's nothing that can't be repaired.
A computer technician will be more than happy to service your printer for you.
All the best!
damnor01
Posted on Feb 01, 2011
Testimonial: "Thanks for the detailed info. Sorry to see that'll take a tech to repair it. It may be cheaper to buy a new printer."
Unsupported ink cartridge after power outage
(1) Open the printer and wait for the carriage to slide over. If for some reason it does not follow these instructions:
(a) Unplug the printer
(b) Manually slide the carriage over until you can get the ink cartridges out.
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water or a mix of hot water and isopropyl alcohol to thoroughly clean the print head.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
If that does not work then you have one of two possibilities:
(1) One of the ink cartridges is defective and causing the error
(2) If it's definitely not that, then the print head will need to be replaced.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For Canon Printer Support
Mar 18, 2014 | Canon PIXMA Office Equipment & Supplies
I have a Lexmark x5470 & I get an error unsupported cartridge
Ink cartriges have chips in them, if the printer does so many prints without getting the "I've had a new Original Cart fitted" it will stop untill,you give it one, regardless if there ink or not
Im afraid it doesn't care that you only need to use the colour cartridge, it is designed to cost you money and make money for lexmark not refillers.
Welcome to our modern world, manufactures make the ink hard to recycle by incorperation of expensive chips that makes refillers, unable to make a easy dollar, because if that want to make cartridges that work they must also fit the expensive chip.
All empty cartridges have a little ink left in them because getting air in ink lines is not a thing we want.
Nov 07, 2009 | Lexmark X4270 All-In-One InkJet Printer
Installed a new Lexmark ink cart and got an incorrect message
take out the cartridge , turn off your printer and take out all the cables behind your printer and wait for 5 minutes and put everything back in.. if the same error shows.. im sorry but your printer needs to be replaced.
Aug 15, 2009 | Lexmark X2500 All-In-One InkJet Printer
Error message reads: left cartridge incorrect.
hello there :
this error refers to the black ink cart not being detected .
possible the new cart has a some fault on it ., u can confirm it by checkin for any defetc , leak on the cart itself or test the printer with another black cart , (if u hav one ).
*if the old black cart is still detected by the printer though the ink is low ...then jus call dell tech support ., with the order # for ur purchase and the cart replaced .
each dell cart u buy has 2 yrs warranty on them .so use them
hav a gooday !
Jul 19, 2009 | Dell 924 All-in-One InkJet Printer
Canon MX850 willnotprint from Large Black Ink Cartridge - PGI-5BK
Ink Carts do act finicky at times. Especially Canon carts.
In many cases, the ink carts have a small fuse built into the back of the cartridge that opens up if the cart has been removed for any reason. Replacement Carts come with the fused portion reset, thus when you insert it into the printer, it works great. If the cart is FULL, it still may not be observed as full or new by the Printer itself. Best way is to use a new cart, not necessarily a Canon Brand. Use an inexpensive company like
https://www.carrotink.com/canon-pgi-5-cli-8-combo-10-pack-ink.html
Feb 15, 2018 | Canon PIXMA MX850 Multifunction Printer
Unsupported cartridge message
Aug 19, 2008 | Lexmark X2470 All-In-One InkJet Printer
Stylus Photo R280
Ink carts being not recognized and you say its a brand new printer?
Heres what you may want to try.
1. Turn off the printer and disconnect the usb cable from the printer
2. Press and release the ink button once you see a solid green light and solid red ink light
3. Open up the printer cover and check out where is the ink cart holder positioned
4. It should stop in the middle part of the printer, you should see an arrow or a ink out marker (ink icon with a / with it( indicating which ink cart is out or not recognized or expended. (This is a usual process on all the epson stylus photo series I had)
5. Press and release the ink button again, it should stop to the next ink cart which you are having a problem and if it doesnt then your ready to reclamp the ink carts.
Just follow your manual usually theres an on screen instructions how to manually replace or reseat the ink cartridges. If the issue persist, you may want to contact epson, ask for a warranty procedure or what you can do next for this. (Either a bad set of ink cart or a bad print head) Good luck!
Jun 12, 2008 | Epson Stylus Photo R300 InkJet Printer
YELLOW INK LOSE
Take all carts out. Have a close look into the cart holder. If you have lost ink it will be beneath the cart holder! That might be because the cart holder leaks. You need a new cart holder then. You have to open the printers top cover, carefully take the holder out, clean the bottom of printer and replace the holder with a new one.
This happens sometimes because the glue which fastens the foil (this is the bottom of the holder!) lost its adhesivness.
Feb 11, 2008 | Brother MFC-5440CN All-In-One InkJet...
Printer won't print in black
This could be to several reasons:
1#  The black cart contains blue ink-> Change to a brand new cart.
2# The cart assy has a bottom that is a foil. Sometimes this foil leaks.
Ink will mingle: You need a new cart assy.
Run the cleaning cycle twice after inserting a brand new bk ink cart and print out a test print. If you still see blue instead of bk the assy is leaking.
BTW the bk is darker than blue (or better cyan). You must see bk! So it seems to be the prob with the right ink....
Nov 11, 2007 | Brother Multi-Function CenterĀ® MFC-215C...
149 people viewed this question
old marine
old marine
