Washing machine door will not open at end of cycle
  • 8 Answers
SOURCE: DOOR WONT OPEN
Hi. Try un-pluging machine,take off top lid slide your hand down between casing and drum until you find lock, then try flicking door casp while trying to open door gentely. when open replace door lock before using again.
Slim jim
Posted on Nov 26, 2007
SOURCE: bosch wff 2000 washing machine - won't spin/drain
I had a similar problem a few years ago, sometimes it would pump out sometimes it just stopped and would not spin. Turned out the pump was broken so I replaced that and everything has been fine since. The guy in the spares shop told me it was not uncommon and showed me how the impeller could stick to the casing magnets. The pump cost about £40
Posted on Sep 06, 2008
SOURCE: Washing Machine Door won't open
I had the same problem. I went through all the steps on this thread to no avail. Finaly I just pryed the thing open - with no damage, thank goodness.
Once open I saw that the latch in the door didn't move when I pulled the handle. The problem it seems was in the latch on the door itself. If you end up this problem and want to get wet clothes out, just stick a flat-head screwdriver, behind the door latch into the horseshoe-shaped metal bit and lever it open - no prying necessary.
Not sure how I'm going to fix this permantely but at least I got my wet clothes out and can do laundry as long as I keep the screwdriver near by.
To fix - I'll either need to figure out how to disassemble the door and replace the latch mechanism, or just buy a whole new door.
Posted on Sep 21, 2008
gittos73
  • 244 Answers
SOURCE: Broken door handle for a Thor washing machine
there r 2 ways to get the door open 1)use a normal knife and place in front of the door handle push it in and it should open 2)pull the plug out take the lid off now place your hand down to where the catch goes into the washer using your fingers u should be able to pop it open with a bit off fiddling
Posted on Dec 16, 2008
  • 1294 Answers
SOURCE: j845 washing machine door won't open
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about quarter inch or until a click is heard.
6. The door may now be opened. Your door lock is broken; actually you have to wait 2 minutes after the wash is over to try the door. If you cannot have access through under the machine, you can try through the top. Some models have a cord behind the dispenser tray.
Sites for spares.
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Posted on Apr 11, 2009
Door will not open after washing cycle ends on SamsungWF8704RSW washing machine
If water still in machine saftey feature will not let door open. Machine may have been over filled with washing, or filters may need cleaning, or both. Set the machine to do another spin cycle, sometimes needs to beredone several times. Clean your filter in normal way but be careful as water in drum could drain through filter.
Sep 15, 2016 | Washing Machines
Why cat I open door at end of wash cycle
http://www.whitegoodshelp.co.uk/washing-machine-door-will-not-open/
Mar 14, 2016 | Hotpoint Washing Machines
How do I unlock a whirlpool duet washer
from a previous discussion:
Wait at least three minutes after the end of the cycle before attempting to unlock your Whirlpool washer. The door will not unlock until the motor speed equals 0 and 180 seconds have elapsed since the motor control unit received the "Stop" command. If the water in the washer is warmer than 122 degrees Fahrenheit or the water level is set higher than Wool, Delicate or Hand Wash, the washer must drain before the door latch will unlock 2 Hold down the "Control Lock" button on your Whirlpool washer for three seconds at the end of the washing cycle. Listen, and when you hear the unlatching sound, the door should open.3 If your Whirlpool washer did not unlock at the end of Step 1, press and hold the "End of Cycle" button for five seconds to manually reset your washing machine.4 Unplug your Whirlpool washer and leave it unplugged for 45 minutes. After 45 minutes, plug your washer back in. The washer's programming should be reset and the door should open.5 Manually unlock the door of your Whirlpool washing machine. Make sure to unplug the appliance before completing the manual unlock. Use a screwdriver to remove the metal strip, called the toe panel, at the bottom of the washing machine. Once you've removed the toe panel, reach up inside the front panel of the washer and feel around for the door latch. Locate the tear-drop shaped tab at the bottom of the door latch and pull it gently. When you hear a click, the door should open.
Jan 04, 2015 | Whirlpool Washing Machines
Door wont open on washing machine zwf16581w at the end of the cycle
The door is designed to stay shut at the end of a cycle usually for about 4 minutes, even if you switch the machine off at the mains. Other than that you probably need a repair.
Dec 17, 2011 | Zanussi Washing Machines
Whirlpool duet washer door will not unlock or complete the cycle
  • Oct 13, 2011 | Whirlpool Washing Machines
    Door wont unlock once a wash cycle has begun
    that is correct ,. pump water out then the door will open.
    May 20, 2011 | Kenmore Elite 45986 Front Load Washer
    Machine won't start after opening door near end of cycle
    Unplug the machine for about a minute. then plug back in. It restarted on its own.
    Apr 29, 2009 | Washing Machines
    Dead in the water
    End of cycle? After the end of cycle you have to wait for 2 minutes minimum (or hear a click), only then you have to try the door; or your door won't open & if you force it you'll damage the door mechanism (not good). End of cycle means "your wash is done".
    Pl rate if helped.
    May 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Washing machine door blocked
    Try to unplug the unit for 10 to 15 minunets, the washer may reset its self to default mode.
    Feb 13, 2008 | Whirlpool AWM6120 Front Load Washer
    Washing Machines Logo
    Top Washing Machines Experts
