Question about Sewing Machines
Where would be a good location to find the parts for a sewing machine that is no longer sold
I am specifically looking for the complete tension assembly for the lower (green) tension control. I was recently given this and have no idea how to find parts.
  • Sewing Machines Master
  • 1,860 Answers
Check with sewvacdoctor.com or A1sewingmachines.com or ebay or sewingpartsonline.com
Posted on Jun 03, 2015
SOURCE: Bernina 801 Sport
Did you clean out the lint under the plate?
Posted on May 18, 2008
bargainbox
  • 1388 Answers
SOURCE: tension
As this happened mid project, I would pay most attention to check the top tension for lint or thread...........this full process of elimination ought to cover all possibilities.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
Posted on Jun 24, 2008
Zenqi
  • 208 Answers
SOURCE: Singer Featherweight tension assembly
Putting this back together is a thirty second job if you have done it a hundred times. If you have never done it but have mechanical aptitude, it may be a challenge.
Whatever you do, don't bend the check spring out of shape!
Below is a link to the Singer site with the schematic for reassembly. When placing the check spring back in place, place it in about the 6 o'clock position with no tension so that it has a fair amount of check before pulling it up in place..
When setting the tension, at a setting of "1" the tension disks should just be slightly compressing the beehive spring. "0" is almost no tension at all. Normal sewing is 5.
Get all of the parts together and push in the cup with the numbers while screwing on the knurled nut taking care to get the pin in one of the holes.
http://www.parts.singerco.com/CPpartCharts/2_2999/221-1_221K1_221K4_221K5.pdf
Posted on Jun 19, 2009
  • 1788 Answers
SOURCE: My brother LS-1520 sewing machine is having major tension problem
Try some metal bobbins, #15 or SA 156. that seems to help. If, you don't have a manual go to brother.com and download one for free
Posted on Jul 27, 2010
  • 255 Answers
SOURCE: sewing machine tension
Hi. The upper tension is too loose (even tho it looks ok). If the upper thread is too loose, it can't pull the bobbin thread up to properly form the stitch and you get those messy 'birds nest' on the bottom side of the fabric. I posted a Tip on Adjusting Tension--read that and adjust your upper tension.
Thanks!
Robbie
Posted on Aug 02, 2010
Testimonial: "Thanks! That does help. Now I'll have to find your tip on Adjusting Tension =)"
Where could I find a sewing table for my Bernina 931 ?
If you watch eBay, the sewing tables will sometimes show up (used). You can also look at SewSteady tables (clear acrylic). They are ordered specifically to fit your machine. You can also find them sold on eBay or even order them through your Bernina dealer.
Tables Inserts
Here's one currently listed on eBay (for 930 but should also work on 931--verify):
http://www.ebay.com/sch/i.html?_sop=10&_nkw=Bernina+930+table&_sacat=0&_from=R40&_trksid=m194
Jan 05, 2017 | Bernina Sewing Machines
Why is sewing machine thread gathering under fabric?
adjust the tension to a appropriate setting,
See the video here.
Sewing Help Sewing Machine Problem Thread Bunching Under Fabric
The knob and its location can differ based on the model of your sewing machine.
Oct 29, 2016 | Sewing Machines
Bernina Deco 330 embroidery machine bobbin case tension.
There are tests to perform for testing and adjusting bobbin tension. There really aren't any "specifications" other than adjusting it until the bobbin drop test is where it is normally recommended.
adjust bobbin tension Google Search
P.S.--be sure to ALWAYS raise the presser foot when threading the upper thread to insure the thread seats completely in the tension disk.
Aug 22, 2016 | Bernina Sewing Machines
Machine wheel is very tight and hard to turn
not knowing your machine make or model, I can only suggest that you are having "tension" issues. Most machines have tension control located around the wheel, sort of like a second very thin wheel. This type usually requires that you would hold the wheel in place while moving the 2nd wheel to make the adjustment.
Other machines have the tension control looking like a push button. Maybe in the middle of one of the other tenstion wheels. pushing that button in while turning that and/or other control wheels would help that.
I may also be that your machine just needs to be oiled. Fabric stores will have this oil and it is specially formulated for sewing machine parts. More is less w this type of oil.
T ake a look all around and even under the machine, hopefully you will find a number for tech support for your machine.
Good Luck and Happy Sewing!
Jun 05, 2012 | Sewing Machines
Where is the disc you speak of? My Janome has no outside disc as there is on most machines.
The discs are the located "within the dials" that you see on your machine. If it's a computerized machine they are "invisible" to you, but the machine's memory recognizes when you don't have your tension set correctly.
Now it's a good idea to set the tension at 3. If that still gives a problem. set the tension just a tad less. Try machine again. Not satisfied? Increase your tension MORE but no more than 1/2 until you try it. Usually, too, it's because needle incorrectly inserted. It has to go all the way UP in the needle bar groove as far as it can go, flat side toward the back, and tighten the needle bar screw securely. Keep the presser foot UP when threading; otherwise, the thread won't fall into the tension discs (yes, there's that word again, Mary Lou!) and hold that thread taut as you go from disc to disc when you thread it so that it can locate the slots. Keep going! Make sure you clean out the feed dogs (the silver plate located under your needle where the "teeth" are. these move the fabric when sewing so you never need to pull or push the fabric; however, sometimes pieces of broken thread get caught in there. Gently sweep out with the bristle ends of your small sewing brush). I sure hope this helps. You can read all about the parts of your sewing machine. Got to http://www.fixsewingmachine.com just to view the tips and tricks section to the left of the web page. It's difficult explaining how to fix the machine if you aren't familiar with the sections of the machine we are specific about. Much success to you.
Jimmy
Apr 12, 2012 | Sewing Machines
How to set up
  • Remove your Janome sewing machine from the box, placing the main machine on a hard surface appropriate for sewing and the accessories and smaller items to the side. Unwrap all of the wrapped items. Remove the tape used to protect the machine during shipment. Set aside the power cord and foot pedal.
  • 2
    Attach the power cord to the machine. The power cord plug-in area is located on the lower right side of all Janome sewing machines and has a series of metal prongs and a power switch. Fit the female end of the power cord onto the metal prongs and push it gently until it no longer moves.
  • 3
    Attach the foot pedal to the machine. The foot pedal plug-in is also located on the lower right side of all Janome machines, right next to the power cord plug-in. Press the foot pedal plug-in into place gently until it no longer moves.
  • 4
    Turn the power switch on. The power switch is located in the same area as the foot pedal and power cord plug-ins and is a rectangular black switch. Press this button. The sewing machine light will turn on.
  • 5
    Place a spool of thread on the spool pin, located on the upper right top side of the sewing machine. Place the thread so that the thread unwinds in a counterclockwise motion, with the thread coming off the back of the spool.
  • 6
    Insert a needle into your machine. Consult your owner's manual for the appropriate size and type of needle. Turn the needle clamp screw, located above the needle area, toward you to loosen it. Turn the needle so that the flat part of the upper shaft area faces the rear and slide the shaft of the needle up and into the needle area. Turn the needle clamp screw away from you to tighten the needle and lock it into place.
  • 7
    Wind the bobbin and insert the bobbin into the bobbin case. This procedure may vary depending on the model of your Janome machine, so consult your owner's manual for specific instructions.
  • 8
    Thread your machine according to the directions in your owner's manual. Like the bobbin, this procedure can vary widely depending on the model of your Janome machine.
  • 9
    Set your tension, located on the front of the machine, to halfway between three and four. The tension may be a dial or it may be computerized and located on the LCD screen, depending on your model. Consult your owner's manual to find out how to set the tension.
  • 10
    Place a piece of scrap fabric in the machine and sew a test seam before you start to work on a project to make sure all of your settings are correct.
    Things You'll Need
    • Janome sewing machine
    • Owner's manual
    • Needles
    • Thread
    • Bobbin
Jan 11, 2012 | Janome Sewing Machines
Missing front main tension cover on Necchi 535 F A 180994
Do you mean the Tension adjustment knob? If that is the part you need then try this site: http://vintagesewingmachineparts.com/necchi-535-fa-tension-adjustment-sewing-machine-part-3/ .
There are also several sites that have parts for sewing machines but do not list their complete inventory online. To check if they have your part, e-mail them with a complete description of the part and the model. For example, try http://www.a1sewingmachine.com/parts.html .
I hope this helps.
May 12, 2011 | Sewing Machines
Help with an older sewing machine
There are lots of men who sew...it is not gender specific.
Perhaps this will help--unfortunately not free:
Wards 1984 Instruction Manual
Montgomery Wards Sewing Machine Instruction and Service Manuals
Montgomery Ward did not make their own machines, so it was most likely manufactured by a sewing machine company with Montgomery Ward's name on it.
However, most machines thread similarly. Just be sure to ALWAYS RAISE the presser foot when threading the top thread--this allows the thread to seat in the tension disk. Set the top tension to about the midway point to start and then tweak from there.
threading older sewing machine Google Search
Understanding Thread Tension Threads
Bobbin tension is usually the last thing to try to adjust...be sure to mark the screw setting BEFORE making any adjustment...
Bobbin Tension How and Why Tension is Adjusted
Needles are probably the least expensive resolution to a lot of sewing machine problems--change them often!!! About every 8 hours of sewing, and be sure to use a needle that is compatible with the thread and fabric. Be sure to install the needle with the flat part facing the correct direction. Most machines have the flat part facing the back of the machine, however, some machines with the bobbin loading from the side will have the flat part of the needle facing the harp (throat) of the machine. AVOID old or bargain bin threads! Use fresh, good quality sewing machine thread (generally, Coats & Clark is not one of them...)
All About Needles
May 13, 2017 | Singer 7422
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
