Question about Garden
Model 312777 type 0150-E1 Briggs and Stratton
What do you torque the head at
  • 1,169 Answers
Recently changed to 250 in lbs using three stage step torque.
Posted on Apr 18, 2015
Valve clearance for model 312777-0128-e1
Intake or exhaust? I'd say 1mm or .004 of an inch, both are the same essentially. Don't forget to do it when the engine is warm, and only until you feel slight drag on the feeler gauge.
Jul 31, 2016 | Briggs & Stratton Garden
Need a repair manual .pdf for a Briggs and Stratton Model 311707 Type 0132-E1 engine
H.A., Check the attached links,instruction and guides for Briggs and Stratton, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My 311707 0132 E1 Model Overview from PartSelect com
http://www.smallenginesuppliers.com/html/engine-specs/briggs_vertical_shaft_engines/276781SingleCylinderOHV.pdf FAQ Small Engine Specifications Briggs Stratton Specs
Briggs Stratton Small Engine Specifications
Jul 01, 2016 | Measuring Tools & Sensors
I need a repair manual for a 2004 briggsandstratton model#282h07-0150-e1
You can get the owner's manual but not the repair manual, that you must buy from the manufacturer.
Jun 09, 2016 | Briggs & Stratton Garden
Does anyone know the head torque specs and tightening sequence (if necessary) for B&S 42A707 Type 2238 E1 17 HP? Thanks.
briggs has service manuals available on their website... take those numbers and search... and yes. they have a sequence and a torque spec. which is 160 inch pounds
Oct 25, 2014 | Briggs & Stratton Garden
I have a Briggs engine 121602-0269-E1 and had to remove the head. Should I install a new head gasket and what in reinstall torque setting?
always replace head gasket if removed. torque value is 28.2 NM or 250lb/in the head should be torqued in 3 settings. do 1/3 then 2/3 and then final 1/3
Oct 15, 2014 | Briggs & Stratton Garden
Need head bolt torque specs for a 1996 saturn sl
Quote:
Originally Posted by norvelplagbao52
1993 saturn sl2 1.9 dohc cylinder head torque
specs and sequence
Cylinder head bolt
tightening procedure:
CYLINDER HEAD BOLT TIGHTENING SEQUENCE:
INTAKE
SIDE
8 4 1 5 9
7 3 2 6 10
EXHAUST SIDE
In sequence,
torque the cylinder head bolts. Torque: 30 Nm (22 ft-lbs).
In sequence,
torque all bolts. Torque: 50 Nm (37 ft-lbs)
In sequence, turn each bolt an
additional 90 degrees.
specs and sequence
Cylinder head bolt
INTAKE
SIDE
8 4 1 5 9
7 3 2 6 10
EXHAUST SIDE
In sequence,
In sequence,
Sep 19, 2013 | 1996 Saturn SL
Torque specs. for a briggs @ stratton 24hp. head bolts
WHAT IS THE VALVE CLEARANCE ON A 23 HP. BRIGS MOTOR AND THE TORQUE ON THE HEAD BOLTS?
Jul 17, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
What is the torque setting on the head bolt for a harley davidson sportster
Cylinder Head Bolt Installation
Factory Method
For each cylinder head, start with head bolt numbered one. In increasing number sequence (1-2-3-4), tighten the head bolt in three stages.
1. Tighten each bolt to 7-9 foot pounds of torque.
2, Tighten each bolt to 12-14 foot pounds of torque.
3. Mark each head bolt and head with aligning marks. Tighten each bolt 1/4 turn (90 degrees).
Torque Wrench Method
For each cylinder head, start with head bolt numbered one. In increasing number sequence (1-2-3-4), tighten the head bolt in four stages.
2. Tighten each bolt to 12-15 foot pounds of torque.
3, Tighten each bolt to 22-25 foot pounds of torque.
4, Tighten each bolt to 38-42 foot pounds of torque
Good luck, i hope this helps.
Aug 06, 2011 | Harley Davidson XL 1200 C Sportster Custom...
Garden Logo
75 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
