Question about Home
The light on my clock no longer works
Have changed the batteries the clock works but the light does not, is there a bulb that can be changed and can I do that myself?
Clock light is dim or out?
Sounds like you need a new clock. Parts and repairs cost more than new products.
Apr 11, 2015 | Tivoli Model Three Clock Radio
How to replace radio/clock light 2006 honda accord
the radio works
the clock works?
but the dimmer, park lamp in inside is burned out.?
turn the dimmer to make,
of all the other (many) park./dim lights are working then the bulbs are bad. the FSM shows all the steps for removing.
my guess, is you are asking why? above, but are you asking how?
i dont know.
Nov 27, 2013 | 2006 Honda Accord
I need the replace the bulb for the clock on a 2006 Toyota 4-runner
The only bulb you can change would be for the night view, this would be the bulb that lights the back ground of the clock, most models have a replaceable bulb in the rear of the clock,, you will need to remove it and see if yours has a removable bulb, if not then clock must be replaced.
If your problem is that the clock does not work then check the fuses, all fuses and if they are good then clock will need to be replaced.
Dec 20, 2012 | Cars & Trucks
The dial light does not come on, everything else works great. Paid 8 dollars for it at a thrift shop today. I like it. Also changed battery and nothing comes on with a new battery.
i bought a tiny 12 or 14 v bulb at ametron (similar ones a radio shack) made in taiwan and at radio shack found in the drawer section. i grafted it into the radio, following a post by another party-- and the dial lite lit up...sorry i no have more info as to bulb size but i am not real savvy in electronics, ...the bulb is about the size of a popcorn kernel and has two tiny wires coming out of it; it fits into a sleeve that is green in color; i think radio shack has a tiny green bulb which willl work as well (mine was white)
Sep 06, 2011 | Proton R5A Clock Radio
1991 Toyota Camry: How do I change the headlamp bulb on the driver's side? What steps need to be done?
Hello first start by opening your engine hood rite behind your head lamp pot is a plug socket simply twist counter clock wise and socket will come out remove bulb and replace turn clock wise to tighten up turn head lights on to check that new bulb works both high and low beam you have now changed your head lamp bulb and restored your lights
Jan 23, 2011 | 1991 Toyota Camry
How to change the headlight
hello first open hood go behind headlamp is not working turn the light socket counter clock wise out comes socket and bulb bulb pulls out reinstall new bulb reinstall socket turn clock wise turn on head lights check low beam then hi beam both working well job done.
Jan 05, 2011 | 1999 GMC Sonoma
Clock light doesn't work. how do I change the bulb?
You need to remove the clock and then look on the back of the clock and theres a small socket that untwists and comes out thats the bulb socket, remove the socket and replace the bulb.
Dec 11, 2010 | 2003 Subaru Forester
Power switch no longer works nothing works except
Please contact the below for service.
Online: customerservice@sharperimageonline.com
Phone: 1-877-714-7444 8:00 AM - 8:00 PM EST Monday - Friday
Oct 30, 2009 | Sharper Image Travel Soother 20 Clock...
No head, tail, dashboard lights or clock - fuses & bulbs are good
There is a few fusable links that power that stuff. Did the fuses blow or they no longer have power to them. If the fusable link doesnt blow and there is a short then it will take out all your fuses. I had a fuseable link go and it killed everything.
Jan 01, 2009 | 1989 Jeep Grand Wagoneer
After changing a blown oven light, the clock works but nothing else turns on, including the fan, light, microwave
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, linked here on Fixya:
http://tinyurl.com/yzjozk
Nov 27, 2007 | Whirlpool MH7135XE Microwave Oven
Home Logo
192 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
