Question about Cub Cadet Garden
Where does the other end of the idler arm spring hook up on a 2006 Cub Cadet LT1050
    An expert who has answered 20 or more questions within one hour.
  • 48 Answers
Look on the frame behind the deck you will see a notch and it's probably has some wear marks. That's where it goes
Posted on Aug 17, 2016
  • 155 Answers
SOURCE: have 2005 cub cadet lt1050, in the middle of
Hi try adjusting the electric clutch you have to adjust it by tightening the three nuts on the outer edge and slide a 10 thou feeler guage through the three sides.
hope this helps.
Posted on Jul 23, 2009
  • 146 Answers
SOURCE: 609 yard machine tractor idler pulley spring broke
Here's a diagram, not a great copy, but it may help:
The spring hooks to the idler arm on the opposite end from where the pulley is mounted. The other end of the spring looks like it hooks to a raised tab on the deck, straight behind the left mower spindle. Hope this helps you, please rate my solution if so, thanks!
Posted on Jun 08, 2010
  • 32 Answers
SOURCE: how to replace the drive belt on a 2006 cub cadet
Use the link below to download the manual for free.
Posted on Nov 14, 2010
woobie dog
  • 1273 Answers
SOURCE: I own a Cub Cadet Hydrostatic Lawn Tractor, not
Hello, W/D here.
Without a particular model number, I'll have to be somewhat generic, so forgive me in advance.
The fact that the mower will run and the blades will engage is good news; it eliminates about half of the things that would need to be checked.
Look for a lever at the (usually) back of the tractor, on the back plate, down low. Sometimes called a range selector or a disengagement lever. Normally, the position of this rod is "IN". If it has pulled towards the "OUT" position, the transmission is disengaged. Usually this rod is pulled out when you want to push the mower, and I expect you're tired of that by now! Chech and see if this is the issue, and post back if not.
Regards, --W/D--
Posted on Mar 07, 2011
  • 3074 Answers
SOURCE: i have a 2008 cub
this is a detailed manual and will explain everything, Good Luck Tim:
Posted on Jun 01, 2011
How to replace mower belt for ZTR cub cadet mower
Changing the Blade Drive Belts:
a.Set the parking brake. Remove ignition key and both spark plug caps.
b.Unscrew the wing nuts from the deck covers and remove both covers.
c.Using a 3/8" socket breaker bar or socket ratchet insert the drive end into the 3/8" square opening in the lower idler arm assembly and push the idler arm counterclockwise. While holding the idler arm back, loosen the blade drive belt from the pulley and slide the belt away from the pulley.
d.Remove tension of the PTO belt by moving the belt tensioning rod. Loosen the belt retaining bolt.
e.Pull the tensioner pulley away from the belt and remove the PTO belt then remove the blade drive belt.
f.Reverse the process to install the belt.
Jan 08, 2015 | Cub Cadet z-force 60
I have a Cub cadet my 1018 with a 42 inch deck my iderlerspringcameoffneedtoknowbothbothplaceoneachendtoreconnect
Go to your local cub dealer with the modle number of the deck. They have diagrams that will show how to connect the spring correctly. If the spring came off it may have lost tension or part of the hooks on the end of the spring broke off. I would get a new spring. I have also seen the the idler pully get sloppy and not keep the idler pully properly lined up with the other pulleys.The belt will then ride up off the pulley and the spring will come off.
Sep 28, 2014 | Garden
Cant remove oil filter on Cub Cadet LT1050
grab the filter with a pipe wrwnch or drive a screw driver through it and turn it. good luck. Ron
Sep 14, 2013 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Cub cadet ltx 1050 extension spring where does it go
In case anyone has a 2014 Cub Cadet LTX 1050 KW and needs to know where the damned spring goes when it falls off when removing the belt keeper, here's a photo.
Jul 15, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Idler arm 1045 cub cadet
Check for alignment of all the pulleys--esp the idler arm. Probably enough out of alignment to "work" the belt off----possibly bent?
Feb 27, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
461 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
