Question about Home
/the light does not work on my Centrios Color changing projection atomic clock, have changed batteries is there something I am missing? #6318324 Thanks
I have changed the batteries, the clock works but the projection light does not
  • 3 Answers
SOURCE: outside temp on skycam atomic clock
Try changing the battereis in the CLOCK. When the batteries in the clock start getting low, the clock does not pick up the outside transmitter.
Posted on Jan 15, 2009
  • 12 Answers
SOURCE: Don't know how to set my atomic projection alarm
I have the instruction manual. r2larson@earthlink.net
Posted on Dec 20, 2009
  • 5 Answers
SOURCE: I need to change the atomic clock from military
Hit the set button until the number 24 shows up instead of the time. Hit the "+" button once, and it will switch from 24-hour to 12-hour display. Hit the set button to cycle through the rest of the settings.
Posted on Jun 29, 2010
  • 5187 Answers
SOURCE: How do you manually reset a Lacrosse Atomic Clock.
There are many LaCrosse atomic clocks. Which model do you have? Support for most is available here: http://www.lacrossetechnology.com/support/home.php . Use the drop down menu to select the model.
For the analog clocks, there is a manual set button on the back of the clock. Press the button and wait for the clock to advance to the correct time. Then make sure the correct time zone button has been pushed. Then make sure the clock is in a location where it can hear the signal overnight. (For best results stand the clock upright in a window.)
For WT-2165U travel alarm, press and hold Set to enter the setting function. Then select the time zone (with + or -) then press and release Set. Set the DST setting to on or off as needed, then press and release Set again. The next setting option is the snooze alarm duration. Press and release Set again to change the hour manually (+ to increase). Press and release Set again to set the Minutes. Correct the date (year, month, day, day of week) similarly. Then set the display to 12 or 24 hour time. Press and release Set to finish and exit the set functions.
For some of the digital clocks you can set the time manually by pressing and holding Set. First set the time display mode (12/24), then press and release Set again. Then set the hours, followed by Set and then the minutes. Continue through other menu options or just do not press any buttons for several (30) seconds.
On the digital clocks, the item being changed will flash.
To avoid interference with the signal reception, place your radio controlled clock where it will be at least six feet away from a TV, computer, air conditioner or other household electrical appliances. The optimal location is near a window. Windows facing Colorado providing the best signal.
I hope this helps.
Posted on Feb 03, 2011
  • 31 Answers
SOURCE: I have an "SKYSCAN" atomic clock. seven days ago I replaced batteries. Has not reset as of yet.
http://skyscan.info/content/manuals/25-model-86709.html This is the direct link to the manual.
Posted on Nov 16, 2011
I have a centrios clock that has an alarm, tells the time and temperature. I need the manual for it
So you worked out you need to specify a make :-)
Try these instructions or post to this forum. If you provide a model number for the clock which should be underneath it or at the back, I will try to find the specific model. They seem to make a few models. Post as a comment to this posting rather than starting a new one. Thanks
http://mb.nawcc.org/showthread.php?107852-Centrios-Atomic-Clock-Instructions
Nov 04, 2015 | Centrios Televison & Video
How to set the time on Centrios atomic clock?
I had the same issue. This s a great clock radio, but not very intuitive. I've uploaded a PDF of the manual from my clock radio, I hope it is useful.
Nov 30, 2012 | Centrios Audio Players & Recorders
Hi, I have a centrios radio controlled atomic clock. I don't have a manual. Can someone tell me how to reset it?
Welcome to FixYa!
Use a pin to press the reset button. A tiny hole about the size of a pin is located somewhere at the front or at the back of your atomic clock.
Thank you for using FixYa. Have a great day.
Jas247
May 05, 2011 | GPS
Set time zone on centrios atomic clock
1. In the normal time mode, Press MODE key to enter the alarm time mode .
2 Press SET key to change the time zone, P is pacific, m is mountain c is central and e is eastern.
Nov 26, 2010 | Watches
Manual for Centrios atomic Clock model 6316008
Go to the Source.ca look for this clock, model number.Go to the parts section and download the instructions in french or english.I just looked so i know this works.
Nov 04, 2010 | Vacuums
Changing the time
you can go to http://www2.oregonscientific.com/assets/manuals2/bar338pa.pdf to see or print the user's manual.
If you don't want to get the manual, here's what you do to fix it. . . . .
*note: you need to do this anytime you change the batteries.
1) open the battery cover
2) on the left side you'll see 3 little buttons labeled a)zone, b)C/F c)reset
3) push the reset
4)push the zone button until your time zone is highlighted on the front display
5) look at the front display & if you see a blinking "radio signal" icon at upper left of time numerals
don't do anything else. The time, date, etc. will automatically synchronize your clock with the US Atomic Clock. This could take up to 10 minutes. As long as the "radio signal" icon is blinking, it's working on it. When the icon doesnt' blink, it's set. Cool, huh?
6) if the area you live in can't receive the signal from the Atomic Clock, instead of a blinking "radio signal", you'll see just a bare antennae. Since you probably set your clock manually, that's what it shows now before you do anything.
7) after you push reset & set the time zone do NOT touch any other buttons to set anything!!! (I know it's difficult to leave things alone, but just sit on your hands). Pushing the "clock" button or the up & down arrows will stop the radio signal & change to manual functions. Look at the signal icon mentioned in 5) and 6) above. If you only have the bare antennae icon. . . . . go ahead & set the time/date yourself. You have no signal.
Enjoy your clock!
debkresh
Jan 25, 2009 | Oregon Scientific FM Weather Projection...
Atomic clock reception
I guess the battery has run out on you. change the battery and you are good to go. I got to warn you though, if you are skittish on taking a good risk, do not try to change the battery yourself. It is a little piece of complex machinery. I have the same problem a while ago. I decided to change the battery myself after the watch repairman tried to sell me a new watch. And you know what, I'm glad I did. My atomic watch is working fine again.
Nov 19, 2008 | La Crosse Radio Controlled Atomic Clock
Outside temp on skycam atomic clock
Nov 10, 2008 | SkyScan 86742 Digital Atomic Wall Clock
Centrios Atomic Desk Clock/Temperature
Here is how you adjust the time zone:
1.) push MODE till "AL" appears after the minute.
2.) tap "SET" (tap means push but do not hold) and time zone will advance.
3.) THE TRICK: The Time Zone can only be set in the Alarm Mode. Make sure you so not push and hold "SET" until the hour flashes as you would to set the alarm time. You just go into Alarm Mode and tap "SET" to advance the Time Zone by one zone per tap. When the Time Zone is where you want it, tap MODE to return to the clock and set the correct time.
Nov 08, 2007 | Audio Players & Recorders
Home Logo
196 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
