Question about Bissell Vacuums
Bissell 16971 has a leaking problem when turned on. The water flows out too fast. Any recommendations as to what is may be?
  • 3 Answers
It is possible that the auto load assembly is damaged or your trigger (button) is stuck. Also check to be sure nothing is stuck in your auto load assembly (this is the part with the spring that allows the water to flow only when pushed up on).
check section on which the auto load would rest to make sure it is also moving freely when trigger on handle is depressed, and not stuck in the up position.
I included link to ereplacementparts.com they have tare down pics and all the parts if new are needed. I have used them for parts to my side by side a few times. good luck
Bissell 1697 Upright Proheat Powersteamer Deep Cleaner Parts
Posted on Apr 19, 2015
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Bissell Proheat Problem
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
hfjk
Posted on Sep 30, 2010
My machine will spray from the hose attachment, but not when I am doing floors.
Check Flow Indicator Filter under the Flow Indicator. Turn Indicator cap counter-clockwise, remove rotor. Filter is under rotor and pulls out. Clean filter. Additionally, check LINT FILTER in the clean water tank cap. Check you User's Guide if you have more questions or call the Bissell Consumer Care at 1-800-237-7691 The other thing you can do in this case is reseat the tank. It may be blocking the housing connection but the sprayer connection is smaller and open. Cleaning the filters after each use though is recommended.
Dec 06, 2015 | Bissell ProHeat Pet Upright Deep Cleaner,...
My Bissell P:rolneat will not dispense water through the floor unit or the wand.
Check the filters. Flow Indicator: Turn Indicator cap counter-clockwise, remove rotor, next remove filter. Clean the filter and replace items in reverse order. Additionally, now is a good time to clean the Lint Filter on the tank cap. These filters are recommended to be cleaned after each use. Hope that helps, if not Bissell Consumer Care can be reached at 1-800-237-7691.
Nov 28, 2015 | Bissell Vacuums
Bissel carpet cleaner not sucking up dirty water why ?
Sounds like a clogged filter. Try cleaning the Flow Indicator Filter (turn Flow Indicator cap counter-clockwise to remove it, lift out rotor and filter under it. Clean filter and reinstall in reverse order); Check and Lint filter on the Heater tank Cap. All filters are recommended to be cleaned after each use. Bissell Consumer Care number is 1-800-237-7691
Nov 24, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
Cleaning fluid leaking out and machine not suctioning up water
First thing is clean the filters: Heat tank filter on the tank cap, and then the Flow Indicator Filter (turn the Flow Indicator Cap counter-clockwise and remove, lift rotor and filter out. Clean filter and reinstall in reverse order) Consumer Care # 1-800-237-7691
Aug 16, 2015 | Bissell ProHeat Pet Upright Deep Cleaner,...
My bissell portable stain remover shampooer leaks water from the bottom
Check your Customer Care Guide for the location of the filters. I'm not familiar with this machine but if it has a "Flow Indicator" there's a filter under it. Just screw off the Flow Indicator Cap and you'll find a rotor. Under it is a filter that gets clogged and needs to be cleaned. There's usually a filter on the cap of the water tank as well. It looks like a screen, remove it and clean it too. The back pressure can lead to leaking. If that didn't help call the Bissell Consumer Care at
1-800-237-7691 Hope that Helped.
Feb 15, 2015 | Bissell Vacuums
My carpet cleaner wont stop leaking water after cleaning and i need keep vacumning up excess water
The unit works on suction and can develop a syphon if the filters get clogged. There's 2 filters that you should be cleaning after each use. One filter is located under the Flow Inidicator: Unscrew the Flow Indicator Cap to remove it. Lift out the rotor and the filter is under it. Lift out the filter and clean. Reinstall in reverese order. If that didn't help you may want to call Bissell Consumer Care at 1-800-237-7691 Hope that helps.
Dec 24, 2014 | Bissell ReadyClean DirtLifter Carpet...
How do i fix my carpet cleaner from leaking from water tank
First Check and Clean filters: Unscrew the Flow Indicator cap to remove it. Lift out the rotor and the filter. Clean the filter and reinstall in reverse manner. Hope that helped, if not contact Bissell Consumer Care at 1-800-237-7691
Dec 24, 2014 | Bissell ReadyClean Deep Cleaner
Older Bissell Proheat 12 amp black shampooer, BLADDER separate / LEAKS
Depending on the model yes:
Google turned up several sites -
http://www.svcvacuum.com/bissell/tanks.htm
You can also look at Bissell www.bissell.com
Jun 24, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Singer by ryobi turtle plus carpet cleaner model ms4000
Will water squirt out the hose? If it does then the heater in the handle may be clogged and not allowing water to flow. The heater is in the handle. There are a number of things that can cause your problem. If no clogged heater and lines, and no water from the hose, then the pump or pump belt maybe bad, the cap for the flow indictor is leaking air and not sealing, the gasket at the bottom of the tank isn't on the tank, either missing or sitting in the hole in the base where the tank sits.
Here is a link you may find useful:
http://bissell.com/images/Schematics/7901.pdf
https://bissell.com/NewsLetters/ListArticles.asp?Page_id=27960&Article_id=132
Feb 21, 2008 | Bissell 7901-7 Proheat Upright Vacuum
Bissell 1697w Powersteamer
I have a similar model and occasionally have problems with water/detergent flow. I find it is generally due to an airlock in the piping caused by forgetting to turn the deregent water control off before removing the detergent container. Follow the manual instructions. Turn the knob to off. Fill both containers. locate them carefully. Make sure filters in the water tank and in the flow meter are clear. Start machine with handle laid flat and knob turned to maximum flow.
Dec 22, 2006 | Bissell 1697-7 Powersteamer Pro Deluxe...
Vacuums Logo
90 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
