Question about Garden
Where does the hosepipe on my 18000 qualcast pressure washer fix to
I use a Wolf Big Blaster 2 and I need to source a replacement male to male plastic reducing nipple from the Aluminium water inlet pipe to the external hosepipe connection.
Any decent HYDRAULIC pipe service centre should be able to help or scan eBay as many such companies offer adaptors and spares.
Oct 15, 2015 | Garden
Hose keeps popping off... Brand new. Is there a method of starting up ? I attached the hose... On goes karcher...On goes hosepipe tap....the plop, off comes the pipe ? What am I doing wrong. It is attached...
The best thing is to get a complete pair of quick couplers. One male one female and replace the ones you currently have. Stick the male on the washer the female on the hose and as they are the same should be able to hold under the pressure of water.
Mar 24, 2014 | Karcher Garden
Nilfisk has lost power
It will be one of three things. The pump valve seals have failed or there is something preventing the seal from closing properly. This can be checked by removing the the valve caps from the pump and lifting the valves out. They are the three boltheads in a line like these but probably stainless steel (this is not a nilfisk pump image)1301757511_nilfisk-pump.jpg
Take them off and lift the valves out and check that they have nothing trapped in them
9k=
The image above shows the base seal which is probably stuck at the bottom of the valve recess and the valves themselves. If the base seal is gone no pressure. check that there is no debris between the innner and outer part of the valve by pushing the base the spring will return it a seal froms here so make sure clean.
Finally the other reason is a broken spring in the pump head where the water leaves the pump to travel down the hose. It holds a ball bearing.
If I am honest if this was a cheap washer like the 110 or less then you will spend more time and money fixing it than buying a new one...
If you want an everlasting pressure washer you need an engine driven one preferably with an interpump on it but they cost....
Mar 04, 2014 | Garden
Pressurewasher
you may of already tried this but is there a water flow back connection on the hosepipe? has it been connected to the end that fits onto the pressure washer? we had this same problem when it was connected the wrong way round... the flow back stop connection should be tap end...hope this helps...:-)
Feb 07, 2012 | Electrical Supplies
I got an hotpoint wma64 front loading washing machine and my water intake has stopped working i am filling the machine with a hosepipe what can i do to fix the problem?
water goes through softner and powder draw hole gets gunged up stopping water supply take drawer out and clean then clean inside where draw fits black gunge blocks small hole where water comes through should do the trick
May 15, 2010 | Hotpoint WMA64 Front Load Washer
How to connect the cold water supply to K 3.65 Jubilee? In the instruction leaflet, figure J, number 1, 2, and 3 I seem unable to connect it. The above is a pressure washer.
Hi all you need is a 3/4 tap fitting from a diy store.
Maybe a hoselock 3/4 male and female fitting that will fit a standard 1/2" hosepipe. If struggling I can send you a link to the fitting on ebay but if you type in karcher tap connector you will see it by the seller vavcandwash.
Feb 14, 2010 | Karcher 1750 psi Electric Pressure Washer
My washer will not drain after the wash cycle and before the rinse cycle
Coin in Pump
Sock in hosepipe
Drop the outlet pipe into a bucket till the machine is dry , take the back off unfasten the hose to the pump and check to see what is in there
Sep 29, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
