Question about VIA Computers & Internet
My pc makes a weird constant beep when turning on, it also crashes shortly after,if i turn it off via power button and turn it on it will work if i run it on Recovery Mode,is there a solution to this?
The OS i have is LynuxUbuntu,because the previous HDD died and i replaced with another one.
    Top Expert:
  • VIA Master
  • 8,246 Answers
Check your ram also check your fan is running ok if not clean it out or you could over heat.
Posted on Apr 18, 2015
Testimonial: "will do"
Get 3 long beeps and 2 short beeps when power on
Likely bad ram... but i need the make and model for the beep codes..
http://www.computerhope.com/beep.htm
Mar 11, 2015 | Gateway Computers & Internet
Acer long beep when cpu turned on
I'm Electronics Telecom Engineer,webdesigner ,seo, PC support professional,Online teacher via skype I'll help YOU
to fix problem Please feel free to contact me anytime via e-mail at besubmitbe@gmail.com, or on Skype at bpshbp
Feb 15, 2014 | Acer Aspire™ T180 PC Desktop
Compac computer won't turn on and the power light blinks constantly what can i do to fix this problem
Does it beep? if it does, whats the beep pattern...ie long long short, or short short short
if nothing else, something is causing a short...check the usb ports (real common) the contacts break from wear and short out, have your power supply tested.
Aug 20, 2012 | HP Compaq Presario SR1303wm PC Desktop
The computer repeats 4 short beeps constantly when turned on ... power supply light is green and also motherboard light is green
Hello, depends on which make of bios you have. If you're lucky it's a keyboard error, but take a look at this page of bios beep codes.http://www.5starsupport.com/info/beep_codes.htm
regards,nicam49
May 11, 2012 | HP Compaq dc5100 PC Desktop
When you turn on the computer it makes a series of stringed beeps for a second also when turning it off, keyboard and mouse does not work
what's the beep pateren it does? here is the basic beep codes:.....
Error Code: Faulty Component:
1 short beep None (Normal Boot)
2 short beeps POST error
Non-stop beep Power supply or system board
1 long beep and 1 short beep System board
1 long beep and 2 short beeps Video card
1 long beep and 3 short beeps Memory
3 long beeps Keyboard
Non-stop short beeps Power supply or system board
(a key on the keyboard might
also be stuck)
None Power supply, system board,
or system case built-in speaker
Oct 01, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
Computer turns on, but won't work afterwords
Nev, the two loud beeping sound of the system when turning it on could be a problem with the memory or the system board.
Try disconnecting the power and take out the battery, then press and hold the power button for 5 seconds then look for the memory comparment and reseat it.
Keep me posted.
Thanks.
Nov 16, 2008 | HP Compaq Presario V2000 Notebook
Constant beep when power up
Continuous Beep = No Power, Loose Card, or Short.make sure all the cards are inserted correctly and also check your memory, make sure it is in the dimm slots properly
Nov 15, 2008 | Sony VAIO Digital Studio PCV-RX860...
System won't boot
Better you try with a bootable CD, if that works then check for your Hard Disk it might got faulty or crashed.
Feb 04, 2008 | Dell Dimension 4600 PC Desktop
Constant beeping and will not re-boot
Question- the beeping, is it short (1 second beeps) or long (2 or more seconds) and how many before it stops? or doesn't it? does it have any rhythm? The beeps correlate to some hardware problem, if you want to check the beeps yourself, just google "Bios beeps" and it will bring up a table of what the beeps mean.
J
Jan 07, 2008 | Computers & Internet
Constant beeping,won't turn on
What is the beep pattern? beeeeeeeep, beep,beep beeeeeep etc. also what BIOS do you have?
Aug 05, 2006 | Gateway EV 700 17" CRT Monitor
Computers & Internet Logo
46 people viewed this question
Top VIA Computers & Internet Experts
David
David
Tony
KG John Justin
KG John Justin
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
