Question about Garden
Engine bogs and dies at initial acceleration on toggle; will run at full throttle
  • 1,169 Answers
Fuel mixtures are set incorrectly
Posted on Apr 18, 2015
Why does my ATV bog down and die when I keep the throttle wide open?
If you are lucky, you might just need new fuel filter and the fuel bowl cleaned out, and maybe new air filter. If not so lucky you need carburetor rebuilt. Backfire is usaully caused by engine running too lean ( too much air for the amount of fuel present). Fuel bowls get gunk in them and the fuel needles and fuel jets get varnished up. The accelerator pump gets worn out gaskets and/or bellows and doesn't give the right amount of fuel mist when you accelerate.
Full Choke is indicative of a motor starved for fuel
Mar 04, 2015 | ATVs
Econ Quad Viper 70 4 stroke won't stay running unless choke is one quarter or more closed. Occasionally pops through carb and bogs down if accelerated.
there's still debree hanging around,there's some more cleaning to do at the pilot.after doing so look if you can see true.after reassembling readjust the adjuster for the pilot two full circles and a half circle.have fun
Dec 21, 2014 | Viper Motorcycles
I'd like to get step to step instructions on how to clean the throttle body in my 2010 Jeep Patriot
  1. Purchase "02 Sensor Safe" throttle body cleaner spray;
  2. Drive the vehicle a few miles, bringing it to full operating temperature, then park it in your driveway with the engine still running;
  3. Gain access to the throttle body, and hold your thumb on the butterfly linkage so that you can open the throttle butterfly when the engine begins to load;
  4. Begin by spraying throttle body cleaner spray on all linkages around the throttle body. If the engine begins to bog because it is aspirating throttle body cleaner, quickly open the throttle butterfly to keep the engine running.
  5. Once you have cleaned all around the throttle body, spray cleaner DIRECTLY INTO THE THROTTLE BODY, opening the throttle sufficiently to keep the engine running. It will run rough during this process but try not to let the engine stall.
  6. If the engine stalls, restart it, and continue cleaning the throttle throat until you see clean metal.
  7. Pour some fuel system cleaner into the gas tank and drive the car a little more before parking it. Try to find an excuse to accelerate hard, WIDE OPEN THROTTLE momentarily if safely possible (as when accelerating to merge into traffic on a highway).
  8. Drive back home.
  9. Done.
Jul 19, 2014 | Jeep Patriot Cars & Trucks
My 88 toyota camry wont accelerate when i step on the gas pedal
tests:
cruise at say 45mph ok?
if i accelerate , it bogs then catches up?
if i accelerate, it bogs and never catches up?
if i go WOT, wide open throttle it has full power up a hill after the bog?
these test , are the KEY tests.
this tells me what is wrong.
i hope the car is tuned up, if not , why no? the 60k mile done?
Jan 25, 2014 | 1988 Toyota Camry
163FML (CG200) bogging at low rev
Hi, Marcus and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on blue links below. Good luck and have a wonderful day.
Bogs when open the throttle fast
Motorcycle Message Board Motorcycle USA
boging and half throttle
boggs down when accelerate aggressivly to full throttle Pit Bike Club
Why is the engine bogging under acceleration Suzuki FA50 Moped
Bike dies when you give it throttle
Mar 17, 2017 | Motorcycles
2003 yz 250 starts and idles but runs rich and bogs as soon as the throttle is applied
Hi, Anonymous and the usual suspects are:
1. Throttle cables misaligned or misrouted.
2. Damaged or restricted fuel tank venting system.
3. Intake system air leak.
4. Vacuum piston malfunction.
5. Accelerator pump leaking or no output.
6. Plugged bowl vent or overflow.
7. Fuel level in bowl too low.
8. Restricted fuel supply passages.
9. Plugged jets or passages.
10. Worn or damaged needle or needle jet.
11. The enrichner valve not seated or leaking.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2002 yz250 idles fine but bogs and tries to die when twisting the throttle...
YAMAHA YZ250 LC Owner Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Mar 19, 2012 | 2003 Yamaha YZ 250
96 Jimmy bogs down when I accelerate hard
Sounds like the fuel filter is getting clogged. It will flow enough fuel for normal driving, but can't supply fuel for full throttle acceleration, causing the engine to bog down. Replacing the fuel filter with a new one should fix the problem.
Feb 26, 2011 | 1996 GMC Jimmy
Engine stalls after acceleration - Start fine, idles fine, but won't run at full speed. Engine dies when throttle is engaged more than half-way. Fuel filter is ok, air filter has been cleaned.
Sounds like its not "un-choking" it self, that its running like its still choked like you wold at initial start up.
Disassemble it and see if u can pysically see the activation and deactivation of the choke when u apply them.
While u are at it, also make sure:
Gas is fresh?
MIx is right?
Plug is good?
Chain brake mechanism is released.?
Good luck.
Oct 04, 2009 | Echo Garden
2000 GMC Sierra 3500 losing acceleration power
next time it happens try spraying water in mist form around the throttle body if it bogs, replace the throttle body gasket. if it doesn't bog you may have a bad wire wait until dark start the vehicle have someone feed the fuel very slowly and watch for arching from a wire it will be easy to see when it is dark, replace that wire.
Apr 13, 2017 | 2000 GMC Sierra 3500
Garden Logo
139 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
