Question about Boating
I have two white wires running to battery where do I hook them
  • 693 Answers
Hi Kenny
What device is it?
Are they factory wires or an add-on?
A little clarification would help
-Steve
Posted on Apr 19, 2015
Battery wireing
Firstly what do you want to hook on to it? A stereo or amplifier? If so you can fix it onto your chassis then it will be your ground wire hope it will help
Apr 02, 2017 | Car Audio & Video
Radio shack cb radio trc-481 model no.:21-1550b. i need to know to hook up the wires to my truck
Red wire is the primary power, this can be hooked to a fuse in the fuse block that shuts off with the vehicle, such as the fan or windshield wipers, the white wire is the memory power, this should be hooked up to either the battery (not recommended as you will pick up alot of engine noise), or another fuse that has a constant flow of power...such as interior lights. Not that both red & white have an inline fuse of there own, anything over 2amps will cook the radio.
If interested in operating without the vehicle running, hook both to a fuse in the fuse panel that has a constant power flow, use the same fuse for both red & white, not going over 3amps MAX!
Black of course, is your ground.
*NOTE-any many radios, the better the ground, the less engine noise your radio will pickup, because alot will be flitered through to the ground. Best to run it to the body, for example the bolts that attach your seat to the body...put the wire between the bolt & the floor...this helps create a capacitor like ground.
Citizen's Band Central~Find us on facebook
Sep 18, 2011 | GPS
I HAV A MURRY RIDER.M/N 42A707 TYOE1653-01.WIRED FROM BATTERY TO STARTER.STARTS AND RUNS.NO OTHER WIRES R HOOKED UP.I WOULD LIKE 2 HOOK UP ALTINATER.I HAVE A WHITE WIRE AND 2 BLACK.1 WENT 2 SAFTY.DO I HOOK...
White is usually always power FROM the S (Starter) terminal of the Key switch to the clutch pedal switch then on to the start solenoid. For briggs and stratton key switch terminal 4 is used for starter power. The model number you passed is for the engine only.
Without your riding mower model number I can not even begin to guess for sure. If you can locate the mower model number I will look it if and see what I can find.
Tri-circuit Diode Wire
Green Connector
with 2 diodes leading to 1 Red Wire and
1 White Wire
Red Wire = 2-5 Amp DC unregulated for
battery charge
White Wire = 2-5 Amp DC negative for lights
This is the usual wiring off of the QUAD regulator.
Yellow Connector 2 Yellow Wires
White Connector
Black Wire = 8 Amp DC unregulated for lights
Red Wire = 8 Amp DC regulated for battery
Small magnets Quad Circuit
20 Volts AC @ stator
I really need an explantion of where your trying to connect to and from. I am thinking your connecting from the engine alternator. IF you replaced the alternator... depending on which alternator you purchased there is a modification that has to be done to wiring harness of the alternator to the regulator.
Kelly
Apr 23, 2011 | Garden
I just bought two flood lamps to fit to the bumper of my 95 jeep wrangler, how would i wire them to a toggle switch?
  1. 2-wires on each fog ligth
  2. toggle switch 2-hook up
  3. okay run hot wire from battery to one side of toggle
  4. on fog ligths one wire migth be white or black
  5. take one of the wire on fog ligth (white)&other fog ligth (white)wire
  6. take a wire hook both white wire from both ligths an hook to this wire an run it to the other side of toggle
  7. black wire on ligths hook them to ground
  8. after you hook the ligths up an they work it best to put a fuse connector between one of the wires on toggle
Dec 06, 2010 | Jeep Wrangler Cars & Trucks
I bought Utilitech #0141224 7 day digital in wall timer. I have just 2 wires at the junction box both of which are painted over but assume one could be black and other white. The 7 day digital timer...
Hello, I bought an in door smart digital timer (G.E.) or Jasco product for my front porch light. I hooked all the wires as instructed and programmed according to instructions. I have a two wire system, so i left the green wire unattached. The light comes on but flashes very fast. What's up with that? This is the second one i've replaced, the first one did the same thing!. Whats wrong?
Thanks,...
M Jones
Sacramento, CA.
Aug 16, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I bought a used trolling motor (motorguide brute 750 50# thrust) it has a 12-24 volt selector switch and three wires to hook up to battery, a black, a white, and a red. i'm assuming on 12v setting of...
the black wire goes to - and the red goes to + for 12 volts. If you want 24 volts you need to add another battery and run a jumper wire from the - of the first battery to the + of the second battery and hook the white wire to the - of the second battery. Here is a picture to help you.
Mar 15, 2010 | MotorGuide Electrical Supplies
Electric trailer brake hookup
Truck Brake control
Red/Black stripe Black
Blue Blue
Lt. Blue/white stripe Red
White White
Orange Not used
Jun 28, 2009 | 2006 Toyota Tacoma
What wire do i hook the remote wire to coming from the amp?
Hello cjfatback,
You want the blue/white wire.
Here's what the manual shows:
Red - Power (to ACC in vehicle)
Black - Ground
Yellow - 12V positive (battery lead)
Blue/White - External Amplifier Control Lead
White - Left Front Spkr +
White/Black - Left Front Spkr -
Gray - Right Front Spkr +
Gray/Black - Right Front Spkr -
Green - Left Rear Spkr +
Green/Black - Left Rear Spkr -
Violet - Right Rear Spkr +
Violet/Black - Right Rear Spkr -
The red and white RCA pigtail leads is for AUX input
Left set of Preamp Outputs - Rear Channels
Right set of Preamp Outputs - Front Channels
Only Models C3433U, C3304U, and C3333U have a 2nd set of RCA pigtail leads for subwoofer output.
Hope this helps.
Apr 14, 2009 | Car Audio & Video
Re sent wire diagram gat all messed up
Hi
have we spoke before in previous post?
the red can go to any 12v live peramanent such as wire to clock or other item that has power with ignition off and the same with the yellow if your putting these to the same permanent live say from clock you can join these to together red/yellow to red on clock
the black can go to any metal or neg wire.
This should then have your device working the only problem im looking at for you now is the pink wire as this stops you using the device whilst driving as it goes to handbrake but i need to find out if its live or negative.
You could just wire the red/yellow to live and black to earth then see if it switches on and works if not then let me know and ill see about the pink wire ok
Makes sure you use inline fuses on the live wires so as not to short the device out.
Make sure you know what is permanent live to put the yellow/red wire to.
It doesnt need to be ignition it only says this so you cant use it with ignition off but you can wire it into any live feed from clock or switches so its up to you what to wire it to its just the pink wire im concerned about.
PINK: does it tell you to put it to live or earth on handbrake switch?
let me know ok
Apr 19, 2008 | Car Audio & Video
Boating Logo
150 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
