Question about Lebanon Seaboard Preen Garden Weed Preventer Canister, 6.26-Lbs
Need to eliminate grass in cracks of curbing and inside flowerbeds
If I spray on a weed that's in a flowerbed will it spread to harm some of my plants?
Hey Mary.. take a old deep bowl and mix a little weed eliminator in it and use a paint brush to apply to the weeds... this will eliminate over spray...
(I do this)..
please mark as helpful.. and follow me.. thanks
Jul 26, 2017 | Garden
How do I replace the blade belt on a ranch king lawn tractor?
Turn off the mower completely and clean out beneath the deck with a mower-cleaning tool to remove any built-up grass deposits. As debris collects inside the deck, the blades can't move freely and you'll have unusual patterns or unevenness forming in your lawn as a result. The mower-cleaning tool scrapes this debris off and restores the deck to proper function.
Measure the height of the mower deck with a ruler when the mower is on flat ground. The deck should be an equal distance from the ground on all sides to ensure an even grass cut. Adjust the leveling bolts on both sides of the deck as needed to readjust the height until it's even. If the mower hits something like a rock or a large stick while mowing, it may knock the deck off balance.
Inspect the deck for any dents or warping. Use a rubber mallet to carefully straighten any dents in the deck if the deck is metal. Plastic decks generally need replacement if they crack or warp.
Remove the deck for a more thorough inspection or cleaning as needed. Remove the grass catcher and take off the pins or mounting bolts holding the deck in place. Lower it to the ground and pull it out from under the mower. Unhook the cutting blade from the underside of the deck with a wrench and set it aside.
Sand off any rust with sandpaper and use the mallet or a hammer to eliminate any remaining dents or warps.
Reinstall the deck once any corrosion or dents are fixed.
OBD Tools 365 Days Shop
Sep 15, 2014 | Garden
Why does my zero turn mower struggle when trying to cut grass, it seems to be using half power.
If is a twin cylinder engine this could be very well the problem. Without the engine info it is hard what it could be.
Jul 23, 2014 | Craftsman 42 in. Precision Cut Plus 24hp...
Would a home a/c stop dripping condensation after a tune-up WAY, WAY overdue?
It should drip. That's the humidity from your house. Call them out again to have them verify the drain pipe is clear. Tell them you think they did something wrong. If it doesn't drain right, it will pool inside the unit and cause the internal AC panels to rust if the drain pan (below the condenser) overflows. Or worse, it might be a source for mold to grow inside the system. The later being unlikely, but not impossible.
May 16, 2014 | Heating & Cooling
Front bumper guard pulled loose on curb. Missing plastic push pins. One corner cracked slightly. Looks like it can be snapped back into place. Any suggestions?
New push pins and drill a couple hole on both sides of crack to install zip ties this will hold or you need to replace the cracked piece (bumper cover etc)
Mar 26, 2014 | 2004 Chrysler Sebring
I RAN OVER A CURB AND DENTED MY GAS TANK. A CANISTER FELL ON TO THE GROUND.......I WIRED IT UP AND DROVE HOME QUESTION.......WHAT IS THIS CANISTER FOR AND CAN I ELIMINATE IT?
You can not eliminate any thing off the assy line on any
vehicle built since 1980
All Emissions Related-- has to be there if you have inspection
to go to, or expect a computer controlled vehicle to even work
Charcoal Evap Canister
Feb 12, 2013 | Lincoln Town Car Cars & Trucks
Each station opens valve #1
Sounds like you have a wire in the MV pin without a Master Valve.
Oct 19, 2012 | Rainbird Rain Bird Esp-6tm Sprinkler Timer
I need a weed killer to prevent grass and weeds growing in cracks on driveways and cracks in sidewalks etc.
I was a professional landscaper for 27 years in California. I would recommend that you look for some type of a soil sterilant, (which is a very strong weed killer, non-selective, such as Isotox). These are good for weed abatement in cracks and areas that you need more permanent weed solutions. Use caution, though, because these chemicals usually have long term effects, and could be washed into other areas that you may not want effected.
Aug 23, 2011 | Roundup "" Weed & Grass Killer
How soon can weeds be mowed or watered after application of roundup?
Depends a littlebit on what tpe of weed but normally 24 hours after application on an actively growing weed is enough for it to be taken into the plant
Aug 03, 2011 | Roundup "" Weed & Grass Killer
Vibrating steering wheel when the speed is above 70 mph
The wheel having been rotated to the rear of the car would eliminate it as the problem. I believe you may have 'tweeked' something when you hit the curb. Have a front end alignment. This would reveal if anything was damaged when the curb was hit, and it might just be in need of an adjustment to solve the problem. If a component was damaged, the tech should know when doing the alignment. Let me know how you make out.
Jun 07, 2009 | 2008 Subaru Outback
Lebanon Seaboard Preen Garden Weed Preventer Canister, 6.26-Lbs Logo
206 people viewed this question
Top Lebanon Seaboard Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Lebanon Seaboard Garden Expert? Answer questions, earn points and help others
