Question about Marvel Appliance Ice Maker
Marvel 301M5904 need water inlet valve cant find it anywhere
Any help appreciated
Where is water inlet valve located. Took lower back panel off and found that water tube goes up into refrigerator. Cant see valve anywhere.
Hi Tom:
Is there any chance that the tube you are looking at is the drain from the auto defrost on the freezer compartment?
It will go into anevaporation tray under the fridge.
The top should be visible at the back about level with the bottom of the freezer compartment.
If your fridge has a water dispenser or automatic ice cube maker, I could be all wet.
Groan.......... I can't resist a pun.
Hope this helps.
Cheers.
Jan 10, 2016 | Refrigerators
Why does the power stay on to the water valve and the water overflows into the ice storage area on my Marvel ice machine.
i suspect ur inlet water valve coils have gone bad staying open and not shutting u can check it with a meter for ohms and for voltage
Feb 08, 2015 | Marvel Refrigerators
Ice maker makes hollow ice
Not enough water. Check water filter if you have one and replace. Check water inlet valve pull supply line off of water inlet valve and make sure the screen in the water valve is not stopped up. make sure water line is not kinked.
Jul 11, 2014 | Marvel Appliance Ice Maker
Our Marvel icemaker was working great then it starting making ice at a much slower pace. It is not make ice no where near as fast as it was. What could be the problem?
Could be a dirty condenser coil, blocked return air, if the ice machine is in a warm environment it takes longer to make ice, water temperature if it is warmer it will take longer to make ice. if water inlet valve is letting water seep buy during freeze cycle it will take longer to freeze.
Dec 17, 2012 | Marvel Appliance Ice Maker
My sanyo washing machine does not fill in water, its director drain out. model asw 40sit.
If the washer is not filling with water then the water inlet valve needs to be checked.The water inlet valve is also called water fill valve.If the fill valve is faulty then it will not the water to get filled in the machine. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 30, 2010 | Washing Machines
Not making Ice
Is the freezer at least 10 degrees? Is there water in the ice mold? If not put some to see if it will harvest after it freezes. If no water getting to ice mold Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear. The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
Jul 10, 2009 | Marvel Appliance Ice Maker
LG 3 in 1 Dishwasher model LD2131SH
E1=Water inlet Error
Not reached to the normal
water level in spite
of 10 min. water supply
Causes:
The Water Supply Tap is closed.
The Water Supply is shut off.
The Inlet Hose is kinked.
The Water Pressure is very low.
(below 10 psi)
Inlet Valve is OK?
The filter of Inlet Valve is clogged
by impure water.
The Hall sensor is OK?
The Impeller of Air Guide is bound
Solutions:
Take action on Water Supply
device.
Measure the electric resistance of
Inlet Valve. (950-1300 )
Clean the filter of Inlet Valve.
Check the frequency of Inlet Water
by the Test Mode.
Replace the Air Braker.
Aug 14, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Marvel Appliance Ice Maker Logo
229 people viewed this question
Top Marvel Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Marvel Kitchen Appliances - Other Expert? Answer questions, earn points and help others
