Question about Pool & Spa
Our spas is flashing code "Ec". It is still heating but will not keep the jets on.
  • 1,631 Answers
Ec = Economy mode versus Standard mode.
all electronic control systems with digital controls, or solid-state controls, have a built-in timer. Jets will only stay on for 15 minutes. Some as long as 20 minutes. They will not stay on longer than that! Because moving water, because of kinetic energy or friction, will heat the water to a boiling point, if Jets are allowed to remain on indefinitely. That is why they automatically turn off, or should turn off.
Posted on Apr 21, 2015
I have an EC display on my panel
That means your "Heating" mode is in Economy! Without knowing what make our model spa you have, or the manufacturer of spa controls, difficult to assist in telling you how to switch to other modes. Maybe try this:
Pressing the "Temperature" button and then immediately the "Light/Jets" button may change the system back to Standard? Once you press those buttons, the "Ec" code comes on and stays on (flashing), and then you can press the "Light/Jets" button to toggle between Standard and Economy and maybe SL - which is Sleep modes.
Good luck
Feb 22, 2015 | Pool & Spa
EC keeps showing on my temperature screen can not find anything in the instructions. Help
Means "Economy"
You probably have a Balboa Control System.
Find the "Code" number on the label of the unit and do a Google Search. Find how to switch between Economy and Standard.
I recommend that spas be on Standard.
But if the spa is hot and is not giving you any problems, and the only irritant you have is not knowing what EC means, you can leave it alone, since you now Know.
Good Luck
Sep 26, 2014 | Eclipse 4 Person Hot Tub Spa - Dream Maker...
What does Ec mean
EC on a Hot tub shows that it is in "Economy mode" meaning the spa will only heat during a filter cycle. Not a setting to be in if you live in "cold country" (you risk having the equipment freezing up)
Nov 21, 2013 | Dream Maker Spas Pool & Spa
Over heating spa
Are Jets staying on HIGH?
Are your controls mechanical or digital?
Exact Information of the spa control system, not the spa manufacturer, will help us to help you. The box below with all the wires coming in & out. Name, model, code & serial #'s will help.
When jets stay on & don't turn off, water will heat up just by circulation causing "Friction".
If mechanical, your thermostat may have failed. If digital, your temperature sensor may have failed.
Dirty filter can cause this as well, if your flow sensor is failing.
Nov 17, 2013 | Belize Spas Belize e480L Lounger Spa -...
What is Ec code on disply mean dreammaker spa
check recirculation pump and heater element if ok temp sensor
Mar 29, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
What does ec mean on my hot tub
EC stands for Economy mode. This is a setting that tells the computer to check the temperature of the spa less frquently, as well as running fewer filter cycles. Spas should be set to EC while you are away on vacation or not planning to use it for a while
Apr 29, 2011 | Qca Spas Dream Series Dream Master Hot Tub...
Tub is not heating to temperature and flashing a Ec message on the temperature screen.
the Ec message is reffering to the mode the tub is set for. Ec stands for Economy mode. In Economy mode the heater will only come on during the filter cycle you have programmed. It will take a while for the tub to actually heat up in this mode. Change the mode to St mode which stands for Standard mode. Your manual should explain how to do this. usually you hit the temp button then the light button to change from mode to mode. Once the St is in the read out window don't touch anything and it will except the programmmed entry automatically. In the Standard mode the tub will keep heating until the set temperature is reached. then it will come on every half hr or so to check that the temperature is maintained.
Oct 09, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Pool & Spa Logo
139 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
