Question about Garden
I have a jd rider 155 the wirinng started smoking how can I fix this I'm a female single parent don't know to much about this
  • Kprime
    Kprime Apr 18, 2015
    I will work on a detailed answer later this weekend, nice pic, very clear.
    Sergeant:
    Champion:
  • 294 Answers
Sorry, but I think you need to take this one to the shop.
Posted on Apr 18, 2015
My toro fh 580v smokes when i start it what is causing it to smoke?
hi.. your inlet valve stem seals are worn out, so oil will be drawn into the inlet with vacuum , as well as fuel...this is why it smokes on start up...quick fix , do an oil change but use a car oil like 15W40 weight oil
im sure you would be using a 10w30 oil now ,using a thicker oil might stop the smoke on start up, or it just wont smoke as much, regardless of using a thicker oil...the valve stems will still need to be replace.....good luck
May 16, 2014 | Toro Zero Turn Rider 74833 Lawn Mower...
Rider 155 mower
will not crank or will crank wont run ??? big difference.
Nov 15, 2013 | Garden
1992 crown vic lx smokes and skiips repalced the temp sensor to the computer did a compeson check all 155 to 160 smells like its flooding im stumped did have some water in my fuel so may drop the tank and...
Hi John, It would help to know more details? The color of the smoke gives a clue as to what is wrong with an engine. If the smoke is dark almost black grey it usually refers to a very rich fuel mixture, meaning that your diagnostics of flooding could be correct. If the smoke is a lighter greyish blue it usually means that the engine is burning oil. The first will mean finding out if an injector is leaking and once found replacing it. Also look for any damaged seals on both ends of all the injectors. I don't understand why you replaced the temperature sensor? Have you had a problem with the cooling system? Water in the fuel line can cause havoc and cause a misfire if it is not cleaned out. Vehicles don't run too well on water so I suggest that be the place to start your work. If there is water in the fuel system it will sometimes cause a light grey steamy smoke and definitely a misfire. Regards John
Sep 22, 2012 | Cars & Trucks
J power and smokes white
Possibly a head gasket problem (as the head heats up it warps slightly, allowing coolant to seep into the cylinders, which is the source of the white smoke--steam) Is the motor using coolant?
Aug 17, 2012 | John Deere 420,1020,2010,2020,2510,2520...
Troubleshooting for a 1998 park avenue
White smoke usually means water in the cylinders. I would say you have blown head gasket or intake manifold gasket. Could be something cracked or something I don't know about. Unless it is something I don't know about will not be simple or cheap to fix.
Jun 21, 2012 | 1998 Buick Park Avenue
White smoke from the exhaust (not a gas smell), burns oil (compression test 120 on one side and the other 60)
the smoke my not smell like gas but check the oil it might the needle valves don't seat in the carb and the gas drains into the crank case and the oil being thinned out by gas can make it smoke nest to check is a blown head gasket they blow out between the cylinder and the lifter port and **** oil into the cylinder its about a $25 part no fancy tools needed just do the one with the low compression
May 29, 2012 | Garden
Land rover discovery series 2 How do i plug in to the wirinng harnes from a after market stereo to the factory harnest from land rover i cant get sound from the speakers
it is a possibility that it can't be done that way, after market radios usually have to be wired into the wiring harness they don't just plug in for the simple reason vehicle manufacturers want you to use their radios & equipment NOT after market radios etc , you may have to get a auto radio installer to fit it for you otherwise if you don't know what you are doing it could be more costly in the long run......hope this helps......cheers.
Sep 14, 2011 | Land Rover Discovery Cars & Trucks
I have a Husqvarna Rider 155. Does the transmission oil ever need to be replaced? Is there a filter ? If so how do I change it? Where can I get a SERVICE manual?
Not an expert but have a rider 155. After looking at diagram on partstree.com, it does not appear to have a filter. Just a magnetic drain plug. This is the only site I have found for info and parts.
Apr 21, 2010 | Husqvarna Garden
I have a ready heater pro 155 BTU and the sitting
I certainly can. I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains what your problem is and where to get the parts and gauges to fix it. I recommend getting the better gauge if you are going to keep your heater. Let me know if you need more help.
hardrocko
Thanks for using FixYa
Mar 02, 2010 | Reddy Heating & Cooling
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
