Question about Garden
Trottle shaft leaking fuel on a white 2-135 roosa master pump
How to set timing on a injection pump farmall 656
You will have to get the degree of timeing from a manual. But on the outside of the pump is a plate with 2 screws the plate is about 1/2" x 1-1/4" take it of and you will 2 disks the one to the back should have a black line and it does not turn the front one does turn so you may not see it at first. If not turn the engine over til toy see the front come into the opening when it goes into the opening you are coming up to #1 compression go to the belt pulley on front of engine and set degree of time to the pointer then check the 2 lines on the pump they should line up if not loosen the 2 nuts that hold the pump on and rotate to line up lines in pump if in line that is it. Shut fuel of first because it will run out. That is about it.
http://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=farmall&th=454456
Dec 03, 2017 | The Times Case Corporation Tractors...
Loosing fuel pressure every ten to twelve seconds
are you using a gauge? is this the 1.0L engine 3cylinders.
Trottle body injection (TBI) >
running or not?
the correct way to do this is measure at the fuel filter test port
ill quote the FSM
  1. Relieve fuel system pressure.
  2. Disconnect the fuel inlet line at the fuel filter and install a suitable pressure gauge on the line.
  3. Connect a jumper wire between the terminals of the fuel pump relay connector and check the system pressure on the gauge.
  4. Fuel pressure should be 25-33 lbs.
  5. As the pressure reaches 33 lbs., the relief valve in the pump should pulsate the pressure so it is always within specification.
  6. If the pressure is above specification, check for restrictions in the fuel lines. If no restrictions are found, replace the fuel pump. If the pressure is below specifications, check for battery voltage to the fuel pump and correct as required. If battery voltage is found, replace the fuel pump or fuel pump relay.
  7. Before removing the pressure gauge, relieve the fuel pressure again.
  8. Reconnect the fuel line. Start the engine and check for leaks.
end quote.
Jan 28, 2014 | 1993 Geo Metro
Holden rodeo 1996 2.8 turbo diesel fuel pump 104641-5810 leaking from rear of pump
Probably an accelerator shaft seal leaking. Best discuss it with a diesel pump rebuilder as it may be an easy fix or expensive.
Mar 03, 2013 | Cars & Trucks
Leaking water pump
If coolant is leaking out of the water pump shaft, it needs to be replaced. Cooling system sealer can't stop this type of leak.----------------------------------------------------------------------------------
VAS 5054A
Dec 17, 2012 | Cars & Trucks
97 s10 2.2...have replaced the ignition module, both coil packs, computer, fuel pump, and both cam and crank shaft sensors. Fired at first when messing with the wires under the hood all the way on the...
make sure the the firing are in place. check cables for continuity especially the high tension cable. and must be well fix.
check the connections of fuel pump and must be well grounded.
Aug 15, 2012 | Cars & Trucks
Intermitently quiting at idle. also ocassionally surges when accelerating. happens more frequently when ac is on.
There to many reason why if you have an Idle problem. Here are some example.
1. You may have a vaccume leak.
2. misfiring (spark plug)
3. Sensors on the engine 02 or EGR valve sensor.or EGR valve.
4. manifold Intake leak
5. cloged trottle
6. coil or relay fuses.
7. fuel filter or fuel pump ( I hope is not the fuel pump) lol.
My best BET is use a high power clean GASOLINE for tree days and see if your Idle problem change, and if there is no change, GO to Autozone or any car parts dealers and kindly ask them to borrow there scanner to diagnose your car. Good Luck. Reginskie. :-)
Aug 20, 2010 | 1998 Ford Econoline
I have a 1997 nissan quest XE. I can drive it to
clean throttle body and the idle air control valve which is bolted onto the trottle body and it should fix it
Dec 13, 2009 | 1997 Nissan Quest
Car will start but will not idle. If RPM's not
Possible low fuel presure at idle. If new fuel filter does nt fix , then it will
require a new "fuel pump". Have you driven this car on low fuel level often?
Nov 23, 2009 | 2003 Mitsubishi Eclipse Coupe
Good fuel pressure. engine turns will not start. runs if primed through trottle body.
Replace the fuel pressure regulator in the intake plenum. This is the No. 1 problem for hard starting with the 4.3 L engine. It leaks fuel and loses fuel pressure when sitting for a few hours. You can try to cycle starter for a split second without cranking wait 3 seconds the turn key OFF then repete 3 times then tryto start. This will build up lossed fuel pressure and verify leaky fuel pressure regulator. Joe ASE Master Tech
Feb 22, 2009 | 1999 Chevrolet S-10 Pickup
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
