Question about Home Security
I have 32channel DVR but need the master password to log on Model. Ms-9032
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 133 Answers
THE DEFAULT PASSWORD IS 123456
Posted on Apr 25, 2016
I forgot my admin password i got a H.264 dvr 4ch China made
Admin and Passwords come as default. If you changed it and forgot, try unplugging the DVR and restarting. You can also still open the settings and try to re- factory the DVR if the settings permit. Next, I have to assume that you got the Booklet or the email or URL addresses to download same.
There is in the hand book the default password as the User name:password and the Password #'s 1-6. Good luck.
Sep 09, 2015 | Home Security
Tip
How to recover sql 2000 sa password
Microsoft SQL Server 2000 is a full-featured relational database management system that offers a variety of administrative tools to ease the burdens of database development, maintenance and administration. It operates in one of two authentication modes: Windows Authentication Mode (the default) or Mixed Mode.
When you install the SQL Server 2000, you can log in the server with Windows Authentication and SQL Server Authentication if you select mixed mode authentication. If you select Windows Authentication, you cannot assign a sa password during installation. However, you should set the sa password after installation.
It is very easy for one to set sa password in SQL 2000. Just follow the below steps:
* 1. Expand a server group, and then expand a server.
* 2. Expand Security, and then click Logins.
* 3. In the details pane, right-click SA, and then click Properties.
* 4. In the Password box, type the new password.
The type of client connections determines the choice of security mode. If all of the incoming clients support trusted connections, you can use Windows Authentication Mode. If some clients do not support trusted connections, you can select Mixed Mode.
If you forget the sa password, you will need to use MS SQL Server Password Unlocker to reset sa password SQL 2000. MS SQL Server Password Unlocker is easy yet powerful SQL Server password reset software for you to reset SQL password, including reset SA password and other user passwords. It provides you an easy and safe way to reset SQL Server password for Microsoft SQL Server 2000/2005/2008 in a minute. No need for you to reinstall MS SQL Server on your PC. The file in master.mdf format is enough for you to recover sa password SQL 2000.
Steps to reset sql password 2000 for sa as follows:
* 1. Download and install MS SQL Server Password Unlocker.
* 2. Click the application icon to run it.
* 3. Click Open to import your master.mdf file. All the user names of your MS SQL Server will be displayed.
* 4. Select sa account, click Change password button to reset sa password.
* 5. Type a new password, and then click OK to finish your operation.
Note: This method to reset sa password in sql server 2000 is usually applied when you cannot login SQL Server 2000 by Windows Authentication wile you forget system administrator login password.
More information about sa password:
According to Microsoft, System administrator (sa) is a special login provided for backward compatibility. By default, it is assigned to the sysadmin fixed server role and cannot be changed. Although sa is a built-in administrator login, do not use it routinely. Instead, make system administrators members of the sysadmin fixed server role, and have them log on using their own logins. Use sa only when there is no other way to log in to an instance of Microsoft SQL Server.
on Oct 19, 2010 | Computers & Internet
Tip
4 Methods to Change MS SQL Server Password
Have you ever forgot or lost your MS SQL Server password? Did you reinstall MS SQL Server or change SQL Server Password by some ways at that time? I once forgot my MS SQL Server password and I reinstalled My MS SQL at last as I failed to find some good methods to solve the problem. What annoying and terrible experience it is! In order to avoid reinstalling SQL Server for a second time due to the same reason, so I collect some methods to change SQL Server password for sa account.
Method 1: Use Command Prompt to Change SQL Server Password
Step 1. Open a command prompt (Start -> Run -> cmd)
Step 2. Type the follow commands, and press Enter after each line:
Osql –S yourservername –E
1> EXEC sp_password NULL, ’yourpassword’, ’sa’
2> GO
The yourservername is the name of your server, yourpassword is the new sql sa password.
The command line 1> also can be changed to other command, the model is EXEC sp_password ‘oldpassword’, ‘newpassword’, ‘sqlaccount’.
Method 2: Use the Query Windows in Management Studio to Change MS SQL Server Password
Step 1. Open SQL Server Management Studio
Step 2. Open a new query
Step 3. Type the follow commands and excute:
GO
ALTER LOGIN [sa] WITH DEFAULT_DATABASE=[master]
GO
USE [master]
GO
ALTER LOGIN [sa] WITH PASSWORD=N'NewPassword' MUST_CHANGE
GO
The NewPassword is set for your SQL Server sa account.
Method 3: Change SQLServer Password by Windows Authentication
If Builtin/Administrator is present in SQL Server, you can login with an ID which is member of Administrators group and change sa password in SQL Server. Just do as follows:
1. Login into SQL server using Windows Authentication.
2. In Object Explorer, open Security folder, open Logins folder. Right Click on sa account and go to Properties.
3. Type a new SQL sa password, and confirm it. Click OK to finish.
After restarting SQL Server and all its servers, you can log into SQL Server by sa login with new SQL sa password.
Method 4: Change MS SQL Server Password with Third Party Software
In addition to the methods above, you can aslo choose some SQL Server password recovery tool to change SQL Server password. MS SQL Server Password Unlocker is one of the good MS SQL passwrod reset tools which can help you change SQL Server password in a few seconds. It allows you to chage MS SQL password on SQL Server and Express 2000/2005/2008.
Following is a guide for you to change MS SQL password with MS SQL Server Password Unlocker.
Step 1.Download and install MS SQL Server Password Unlocker.
Step 2. Run MS SQL Server Password Unlocker, click Open, import your master.mdf file. All the user names of your MS SQL Server will be displayed.
Step 3. 3. Select an SQL account, click Change password button.
Step 4. Type a new password, and then click OK.
This SQL account password has been reset. You can login with it.
Well, the four solutions are the easy-to-use MS SQL Server Password Reset ways.
on Aug 10, 2010 | Computers & Internet
How to reset hi-focus h264 dvr admin password?
173480
8456Hl
375611
Please use above the Master Password. This password is only valid for today.
Kindly use the master password from VGA/HDMI.
Kindly follow the below procedure to reset the password:
Remove LAN cable if it is attached
Restart you DVR
Choose the "admin" account in USERNAME
Use MASTER PASSWORD in PASSWORD. Now you can access your DVR
Go for Main Menu >Advance > Account
Select "admin" user
Click on Modify Password, In Old Password Use Master Code,
In New & Confirm Password type your new password (without any special characters).
Now you can login with your NEW PASSWORD that you have created.
Oct 08, 2014 | Home Security
How to reset my dvr rds--p5102
Depends on what you mean by reset. If you are doing a default reset yes you will lose all settings in the dvr. You can't normally do this without logging in or getting a back door code from the manufacturer. If you mean a power reset all data will still be there but you still will not be able to log in.
Sep 09, 2014 | Home Security
HI I HAVE AN 8CHANNEL DVR BUT NEED THE SUPER PASSWORD TO LOG ON
I have an 32 channel DVR but need the super password to log on
Model ms-9032
May 27, 2014 | CSi Speco Speco DVR-T4IP 4-Channel Triplex...
I have a dvr model no. dyk4500 4ch h264 dvr i for got my password. How do i reset it
The DYK4500 is a DVR system and is not a Windows or traditional computer. It does not have an optical drive. You may first want to just hit enter and see if the password is not set. Try any other methods first, and if all else fails, you can attempt a reset by removing the BIOS battery and jumping the contacts for 30 seconds. This method sometimes has issues that are tough to recover from if you don't have the remote. You'll often get to a first screen that shows: HDD0 Detected, HDD1 No Device. Haven't figured out how to bypass this window without the remote. With the remote, you should be able to press '0' twice.
Dec 21, 2013 | Computers & Internet
I FORGET LOGIN PASSWORD OF "ZEN TECH DVR 36584 V
i have the same
ZEN TECH DVR 36584 V u can remove the battery and turn on the dvr but i cant log in i fogot the default password ....anyone rem it?
Aug 19, 2013 | Computers & Internet
How to reset password for q-see dvr model qt426
try to remove the cmos back up battery inside the DVR and install back the battery in invert position to short the polarity. Leave it overnight and install back the battery in the proper position and turn on. tyr to log in USERNAME: admin PASSWORD: 123456
Oct 27, 2012 | QPS Q see QT426 Video Surveillance System
MY DVR EYTRON TV8903 IS LOCKED, AND I FORGOT THE PASSWORD. WHAT IS THE SOLUTION?
Follow these instructions to reset the master password on the JPEG2000 and JPEG2000 H.264 Dual Codec series DVRs. Press the menu button on the DVR. When prompt for a password, press the follow buttons on the DVR in this order: STOP --> PLAY --> STOP--> SEARCH --> PTZ --> PIP -->1 --> 2 --> OK (or Enter). You will be logged into the DVR as the administrator. Select Configuration from the System Menu. Then, select password Setup from the confuration menu. The password setup screen will display your current password.
Nov 09, 2010 | GE SDVR-16 Video Recorder
Home Security Logo
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
