Question about Beko Washing Machines
Beko washing machine will not start and trips main trip board
  • Colin Apr 18, 2015
    Hi Tom thanks for the reply I will check brushes on the motor and heating element tomorrow . Just to add the machine did a normal cycle but did not spin so I think the brushes might be the culprit. Many thanks again and will let you know the outcome very soon.
    Regards
    Colin
    Genius:
  • Beko Master
  • 1,585 Answers
Check heater element also motor
Posted on Apr 18, 2015
  • Colin Apr 20, 2015
    Hi Tom thanks for your advice it was the heating element.
    Regards
    Colin
  • 44 Answers
SOURCE: Washing machine tripping RCD
electrical short in m/c.could be heating element. regards
Posted on Jul 30, 2009
FitzOriginal
  • 842 Answers
SOURCE: beko wma 1510s keeps tripping eletric sockets
I once had a machine that would trip the power if it had an unbalanced load when it went to spin. Whirrr.... bang bang bang bang... click! Lights out.
HOWEVER, this is highly unusual. If the machine is tripping the power then you should take great care. either you have an electrical fault (The motor may be failing and burning out, or another component may be failing unsafe) or you may have a water leak from a defective hose somewhere that is getting electrical equipment wet. Just remember that water and electricity are a very un-funny mix and your trips are there for a good reason.
Does the machine trip the power as soon as it is powered on, even after standing for days (Probably an electrical fault)? Does it trip as a particular thing happens, such as moments after the water coming into the machine or as the drum starts to agitate or the spin cycle starts or as the water empties.
Here are a few suggestions. Having thought about when the fault trips the power, do the following:
TURN OFF THE POWER AND UNPLUG THE MACHINE FROM THE WALL. Isolate the water supply. Make sure that the machine is drained of water. Now it's safe, look for water leaks.
Take the top off the machine (Usually a couple of screws in the back and then the lid will tap forward or pull back depending on the model). Look for signs of water inside the chassis, where the water pipes run from the inlet valve to the soap tray. The rubber gasket around the door may also be cracked and leaking. A classic point for the start of a leak is the rear bearing of the drum (This is the centre of the big wheel of the drum), you may see water marks or limescale buildup that has dripped from the bearing if it is leaking.
If you are looking underneath for leaks, never tip the machine all the way onto its back, you may cause a water leak inside the machine. ALWAYS tip BACKWARDS, so the control panel for the machine is pointing up to avoid water getting to the control panel. I would recommend putting a chair behind the machine as you tip it, so the top back of the machine comes to rest on the seat and the machine is at about 45 degrees. this will give you access to underneath without a leak and make is a lot easier to tip it back on to its feet again afterwards.
While the machine is on its back, look at the motor, If you can, have a good sniff at it (Do you smell burned electrical equipment?) Look around for other components such as printed circuit boards, visually inspect and sniff them too.
The golden rule here is if you can see a leak and you can replace the part, then that's great, go ahead and Do It Yourself. BUT be sure that when you have finished everything is absolutely dry inside (Use a hairdryer if needs be). When you are absolutely sure it is all safe then prepare to test. With everything connected up turn on the mains and start the machine. ONLY TOUCH THE PLASTICS until you are sure it is working exactly as it should. Even then you should of course check to ensure that there is no electrical power leakage. If in doubt, it the power trips, if you have the slightest concern, get a professional in, Your family will prefer to pay for his visit rather than your funeral.
Posted on Feb 09, 2009
  • 417 Answers
SOURCE: Zanussi ZWD1680W Front Load All-in-One... Problem:
With the symptoms you describe i would suspect a intermittent heater element fault as you are getting earth leakage current which is tripping the whole supply rather than a current overload which would just trip the socket circuit breaker. Get the heating element checked over first as this is the most likely cause.
Posted on Nov 04, 2008
kachbibi1
  • 979 Answers
SOURCE: LG 1412RD Tips main fuse.
You have a dead short either in your breaker box or the plug in. Chances are it is your receptacle.
Posted on Feb 24, 2009
  • 166 Answers
SOURCE: hotpoint washing machine keeps tripping electric
First unplug your washer. Check the ground on the washer and make sure it isn't loose; this would be a good time to inspect the wiring harness for any problems. Next check the outlet (turn off the electric to that breaker first) make sure all the wires are tight and are making good contact; pay special attention to the neutral (white) wire. If that seems fine, and you are comfortable with going into you breaker panel, turn off that breaker and check the hot (the wire on the breaker) to make sure it isn't loose and then check the neutral wire. If either of these wires seem loose tighten them down....a loose wire will move when a load is put on it and cause the breaker to trip. If all seems normal and washer is still tripping the breaker you might want to replace the breaker.....they can go bad. Good luck!
Posted on Aug 26, 2009
Switch power button ON and fusebox trips
Hi, you will have to get the unit checked out as your fuse box should not trip out , there must be a short somewhere in the wiring.
Dec 28, 2015 | Beko WME7247W Washing Machine
Washer trips mains fuse when started
There's a short-circuit in the washing machine, possibly in the heating element.
Feb 11, 2015 | Beko Washing Machines
When I press start the electricty trips ?
u HAVE A SHORT SOMEWHERE AND NEED TO CHECK UR WIRING FOR BURNED OR FRAYED AREAS.
Dec 16, 2014 | Beko Washing Machines
Trip switch cuts out when i use washing machine
Main board power circuit fault.disconnect main PCB and reconnect power cable .you can identify the fault. Replace main pcb.
Sep 01, 2014 | Indesit Washing Machines
Beko eco care is tripping after about 1 minute into a wash
I think it could be the motor or the circuit board
Mar 24, 2013 | Washing Machines
Washing machine starts but trips mains MCB, kitchen is on it's own ring main. Replaced fuse and reset MCB but tripped again, I'm thinking electronic fault, board maybe?
Sounds like short or Electrical leakage,,locate and disconnect the heating element then try this goes faulty now and then....Machine should then run /spin fill ...if so fit new heater
Feb 10, 2011 | Bosch Classixx WFL 2066 Front Load Washer
I have a beko wm5100w washing machine and it keeps tripping the electricity
Hi, I have just come back from holiday. I turned on my beko washing machine,power comes on and when it starts it switches off the main electric box.before i went away i turned off the main electric box. Is the machine broken and if so expensive job?
Nov 25, 2010 | Washing Machines
Beko dvc 62 ,all electrics tripped out ,put cooker
The element has blown. It will cost you around
May 16, 2010 | Ovens
Hotpoint aquarious wd 440 two years old tripping main board
A faulty heater in both a washing machine and dishwasher will trip swithes because they both cause an earth........the chances are you heater needs replacing......the reason its tripping after a short period is probably beacause the cycle doesnt start heating the water until after approx 15-20 mins depending on the cycle chosen
Mar 28, 2009 | Hotpoint Aquarius WD63 Front Load...
Washing machine
Sounds like you may have a corrosion issue or water ingress, causing a short. Could be a corroded heater, water in the main control board, water in the pump motor - the list is endless. Most washers tend to run the pump to ensure drum is drained before starting the cycle, so it would be probable that the problem is in the pump area.
You don't say if the main switch is an RCD or an ELB. I presume it's an RCD.
Oct 07, 2007 | Beko 24 in. D3421F Free-standing...
Washing Machines Logo
89 people viewed this question
Top Beko Washing Machines Experts
micky dee
janman
Domenico Grillo
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
