Question about Bushnell Optics
Where is battery on Bushnell Truth and Power Button?
My bushnell forcaster can not locate signal have tried different locations . worked prior ?
On many of these units there is a reset button or a small hole that can be pushed in with a paperclip to reset the unit after battery change.
Jan 04, 2015 | Bushnell Optics
Change from meters to yards on bushnell chuck adams rangefinder
First, remove the battery then replace it to reset the unit, then ...
Taken word for word from the manual: While looking through the eyepiece, press and hold the POWER button down for approx. 5 seconds. During this time all liquid crystal segments and icons will be displayed. As you continue to depress(hold down) the power button, the display will toggle back and forth between Yards and Meters. Once the unit of measure desired is displayed, simply release the power button. The device will return to the last unit of measure setting used each time the unit is turned on.
Sep 12, 2012 | Bushnell Optics
New Bushnell Backtrack won't turn on.
I have the same problem with my Backtrack. I unlock back battery cover, unscrew some screws. Then I take the screen, check connection - it's ok. Then I try to close power switch with screwdriver. It started, but doesnt worked. There are some symbols on the screen. It's all I can do. My BackTrack still won't worked. For comments: greenspot@mail.ru
May 28, 2012 | Bushnell BackTrack Handheld GPS Receiver
I just purchased a northstar, goto telescope, model 78-8876. I purchased it second hand. When I try to turn on the power on, I have to keep the power button pressed down to have power, I let go, the power...
Obviously either your hand controller is broken and or a circuit inside the scope.
Here is Bushnell's repair web site:
http://www.opticsplanet.net/bushnell-warranty.html
Apr 10, 2011 | Bushnell NorthStar 78-7880 (190 x 78.74mm)...
Bushnell 7 day forecaster. My screen does not display information and says that the network is lost or in network - please wait 1 hour. It's been more than an hour it's been a few days. I have changed the...
I have a Bushnell 7 day forecaster for about 10 years I love it . Suddenly one morning it lost its signal and no matter where I placed it I would receive a message from the unit no signal found try another location . Loosing my owners manual IN THE BACK OF THE FORECASTER AND THERE IS A SMALL RESET BUTTON ON THE BOTTOM I TOOK A SMALL PIN AND PRESSED THE RESET BUTTON AND IT WORKS PERFECTLY now Hope this can help who ever has this issue , note the smaller five day forecasters do not come with a reset button in the back.
Feb 03, 2011 | Bushnell Measuring Tools & Sensors
I got my Bushnell Trail Sentry Digital Trail Camera and the code does not work so what is another code.
the first time the camera is used the code should be 0000 unless previously changed,try removing and reinstalling the batteries,this hould start your set up again.
press and release the power button and wait for 4 H's,"HHHH" to appear,this may give you another chance to use 0000 or whatever you chose as your password.press enter after each digit,then press enter again.the indicator should display PASS.if it displays ERRO then it is the wrong password.there is a password recovery service provided by Bushnell at 1-800-423-3537 and press option 2,you will need to provide your serial number to the representative.
hope this helps.
Jan 09, 2011 | Bushnell Trail Sentry 11-9200 Digital...
Bought a used Bushnell NorthStar #78-8846 controller not working
Contact Bushnell warranty and repair at this web site:
Jul 06, 2010 | Bushnell NorthStar 78-8846 (675 x 114mm)...
Dropped my bushnell 1500 Mode button will not work and cannot get
Try this...while holding your thumb on the battery door, shake the unit a little....if you hear a rattle, then a lens has broken off...(rangefinder is dead) If it doesn't rattle then you have knocked it way out of alignment. It might work on a STOP sign (because its reflective) but nothing else. Send it to bushnell for repair.
Bushnell Repair Center
8500 Marshall Drive
Lenexa, KS 66214
Send $10 for return shipping and handling.
Explain your problem.
Apr 21, 2009 | Bushnell Velocity Speed Gun
Bushnell 78-8890 Power On
If this is a new unit (or even if it is not), I'd call Bushnell for help!
UNITED STATES
Bushnell Corporation
9200 Cody
Overland Park, KS 66214-1734
Important Phone Numbers:
In Kansas City area - (913) 752-3400
Consumers - (800) 423-3537
Dealers - (800) 221-9035
Fax - (913) 752-3550
Mar 05, 2009 | Bushnell NorthStar 78-8890 (300 x 90mm)...
Optics Logo
295 people viewed this question
Top Bushnell Optics Experts
George Merkley
George Merkley
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
