Question about HP DesignJet 1050c plus InkJet Printer
Plotter wont recognize edge of clear films when loaded from a roll or sheet. recognized plain paper fine
    Scholar:
  • HP Expert
  • 123 Answers
Hello. Clear film media made for the Designjet has a white strip at the right edge of the media. The strip is for the edge detector to find the edge and load the media.
HP and Lexjet both sell the correct media for your plotter.
Posted on Jun 07, 2016
  • HP Master
  • 1,915 Answers
I would check the sensor on the carriage that detects paper. It might be dirty enough that printer cannot detect the subtle edge of the clear film. It is the blue light that turns on on the bottom of the carriage when you load paper.
Posted on Apr 18, 2015
Testimonial: "I did try cleaning the sensor but no luck... thanks"
  • Anonymous Apr 18, 2015
Red and green light turn after first run
Its common problem in T Series Plotters:
Cause of malfunction: These plotters having separate sheet path as well as roll path for print media. After initializing plotter its verify the available media(sheet or roll). If sheet path is occupied by the media it wont allow the roll media, means first priority is for sheet.If sheet path paper sensor dusty or malfunction, printer will say "remove paper from sheet path" even no paper in sheet path..
How to shoot this problem:
You need to clean sheet path sensor located at sheet loading area.(black 'U' shaped part) Applying the pressured air at sensor is the best method to clean.. If problem remain you need to remove the sensor & clean or replace it.
Follow the snaps:
Need to open roll feed right side portion
dadb8b23-32b2-4d8a-952b-038117715d5b.jpg f7392b92-295a-4144-8387-b83355c6889e.jpg 6f066468-8698-4d24-94d4-af1703c40407.jpg 6ed46665-db38-4ccc-8522-c52ae9c50dbf.jpg 37e6b4f2-cc2e-438b-849e-9911bd553c7e.jpg
Clean the IR sensor...
Fix it back..
Note: Technical knowledge required to understand the remedy..
Jan 26, 2014 | HEWLETT-PACKARD CP1025 Laser Printer
Canon ipf605 paper error
Here is what I've found out by trial and error.
Paper Roll Won't Load:
    -Usually occurs when the roll is less than 50% full
    -Printer will give the error "paper loaded askew"
    To Correct This:
      - Press and hold Stop until Job Cancel comes up on the
      screen
      - Press Menu
      o Scroll Down until Adjust Printer menu comes up
      o Press right side arrow next to OK button
      o Scroll down to Manual Band Adjust and press right side
      arrow again (or select one of the other adjustments)
      - Select Yes and press OK
      - Load paper roll - make sure paper is straight
      - When asked (printer will beep) select Plain Paper and
      press OK
      - Let paper load
      - When printer starts to print press and hold Stop to cancel
      job
      - Paper should now be loaded
      When all else fails load a new roll.
      This would be a temporary solution until the sensor is fixed.
Mar 12, 2012 | Canon imagePROGRAF IPF605 InkJet Plotter...
HP DesignJet 430 rejecting media
When you load the paper, the carriage edge detector measures exactly where the right edge of the paper is located. Then the paper is rolled forward and the edge is measured again. If there is a difference in the measurements, the printer assumes the paper is not loaded squarely and rejects the paper. After you load the paper and the printer asks you to align the paper, take your time, release the paper with the release lever, and line up the right edge of the paper with the right edge of the paper roll. You might have to do it more than once to get it to load. Some plotters are very sensitive and others are more forgiving.
Sep 25, 2009 | HP DesignJet 430 InkJet Printer
New ink roll in Philips fax Magic 2
Have just tec support (10p per min robbers !!)
Here is what you do
OPEN MACHINE
WITH THE NEW INK FILM IN, ROLL THE INK FILM ON ROLLER NEAREST TO YOU FORWARD UNTIL ALL THE SILVER STRIPS TO THE RIGHT ARE NO LONGER VISIBLE (THIS IS THE BAR CODE ON THE INK ROLL IT'S SELF)
REMOVE INK FILM FROM MACHINE
CLOSE MACHINE
TYPE IN OK 45 OK 7117 OK (THEN IT WILL ASK IF YOU ARE SURE) YES (CHANGE WITH < > BUTTONS BETWEEN OK BUTTON )
SET TIME AND DATE
OK
OPEN MACHINE
PUT INK FILM BACK IN
CLOSE MACHINE
YOUR DONE LOVERLY JUBBERLY !!!
HOPE THIS HELPS AS IT DROVE ME MAD Rob
Apr 04, 2008 | Philips PPF-531 Plain Paper Thermal...
Loading cut sheets
Try to check the paper media set on the plotter (roll/plain paper). It usually happens if paper media is not the same with the plotter setting. To change it, unload the paper, press the media button on the printer to the right media and load the paper again. It should work now.
Dec 06, 2007 | Canon iPF700 InkJet Printer
HP DesignJet 1050c plus InkJet Printer Logo
253 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
