Question about Dryers
How do I remove the drum to change the belt - Dryers
  • Dryers Master
  • 16,037 Answers
This is not as hard as it would appear. The top comes off, usually lifting and without any screws because there are clips. You need to use caution because of paint chipping etc if you have to pry. Then with the top off you need to look for the screws that hold the front of the dryer. You remove those and the drum is free to remove or replace the belt.
Posted on Apr 26, 2015
How do I change the drum belt on maytag Neptune dryer
have to remove the whole front section including door the top will flip up after u remove front and screws which were hidden until u removed the front section
Oct 12, 2014 | Maytag Neptune MDE4000 Electric Dryer
What does a belt life ends soon mean, on a brother MFC 9440ch color laser printer?
Are you sure of the error message? The Brother printers that I have used have Drum Ends Soon and Change Belt messages.
The Brother MFC-9440CN has a belt that can be replaced. The Belt unit has an life expectancy of ~50000 pages. The belt unit is part BU100CL and costs a bit over $150 at office supply stores. Amazon.com and some other stores have the unit for under $100. http://www.amazon.com/Brother-BU-100CL-HL-4040CN-HL-4070CDW-Series/dp/B000SC245E is one source.
When the unit says Change Belt Unit, follow the directions from the manual's maintenance section to replace the belt unit. See page 178 (page 189 of the PDF) http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002252/mfc9440_usa_usr_b.pdf . You have to remove the Drum and then the Belt Unit. Then slide in the new Belt Unit and replace the Drum unit. Then close the printer and turn it on. Finally reset the counter from the Machine Info sub menu (press Menu 8 4 and select the Belt Unit and press OK. Then press 1 followed by Stop/Exit).
If you mean the Drum Unit, that is part DR-110CL and costs over $175 at the office supply stores. Order this part when the Drum End Soon message appears and replace it if the print quality deteriorates (or when you have the new drum). The Drum Life is ~17000 pages. The steps start on page 166 (182 of the PDF). You need to remove the old Drum unit. Then remove the toner cartridges from the drum. Prepare the new Drum Unit, including putting the cartridges in the new Drum. Then replace the Drum unit and reset the counter.
I hope this helps.
Jun 04, 2012 | Brother MFC-8460N Laser Printer
We need to change the drive belt. How do you take the dryer apart to change it?
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley or a faulty motor.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Apr 09, 2011 | Kenmore 64882 Electric Dryer
How do I change the dry drum belt? I have figured how to remove the top.
If you have to replace your drum belt and if you have a front loading machine.
Be real careful not to knock any of the wires off of the timer switch.
Remove the front of the machine by removing two screws at the top of the front, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket
not to turn.
on them this will cause a noise like a thumping type noise.
Free answer...Please rate me
Dec 04, 2010 | Maytag MDE5500AYW Electric Dryer
How to open up dryer to change belt
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Also remove the screws from the lint filter.
Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Please do not forget to rate me
Thank you
May 30, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How do you change the drum belt
remove the top (generally spring clips), remove the front (spring clips and/or screws) the drum will fall out.
Check the small tensioner on the bottom of the machine. There are two slots for the tensioner to sit in. make sure it is in the slots.
Put the new belt around the drum, get on the floor, pull a loop of the belt through the tensioner and place it around the motor pulley.
Get up ... get help, put the drum in place, replace the front panel, drop the top down, give it a try. If it works, pop the top down and bingo - you are done
Thanks for using FixYa.com
Please vote
a
Dec 04, 2009 | Lands Phones
CHANGE THE DRYER BELT MODEL LSE7800ACW MAYTAG WASHER/DRYER COMBO
Hi...you can go to the following website and check out how the belt goes on the dryer.
On a front load dryer, you would normally remove the front to expose the drum and belt, after you remove the drum then that exposes the drum rollers, motor, idler arm pulley, etc.
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=LSE7800ACW&mfgModelNum=&fkMfgID=1
Hope this helps
Sep 29, 2009 | Maytag Dryers
Need to change the belt, I gotta get the shell off but it's hard
First and most important, REMOVE POWER! Then remove the two hex screws below the bottom front panel. Then remove the two screws below the bottom of the upper front panel. Then remove the four screws that hold the panel the front of the drum rides in. Under the drum you will find an idler arm and pully by the motor, push up on the am and remove the belt. Next take the belt from the motor pully, after this you can slide the belt from the drum. I doubt if it is the belt. Look on the front panel that had the four screws. It has two rub strips that the drum rides on and a felt ring. I suspect that these are the problem.
Jan 15, 2009 | Amana DLE330RAW Electric Dryer
My hotpoint vtd20 dryer is vibrating when running. When stopped, with my hand i can barely turn the drum (not sure if it turned easily before) any advice?
hi Step 1: Locate the belt by removing the back or front service panel. Depending on the type of dryer you own, you may have to prop up the drum to keep it from sagging. Don't let the drum hang; the bolts that hold it in the cabinet could be damaged. Don't remove any more parts than necessary.
Step 2: Identify the belt. The old belt may be threaded around the idler pulley and motor drive shaft. Draw a diagram showing how the pulley is installed so you'll be able to replace it properly. If the old belt is worn or frayed, but not broken, leave it around the drum as a pattern for positioning the new belt; cut the old belt and remove it when the new belt is in position.
Step 3: Remove the old belt from the pulleys and stretch the replacement belt into place. The new belt must extend around the dryer drum and the pulleys. The trick is to align the belt on the drum with the pulleys -- the ribs on the new belt go against the drum.
Step 4: Once the belt is aligned, turn the drum by hand, if possible, to make sure the belt is tracking. You may have to reassemble part of the cabinet to do this.
Some older dryers have a V-belt pulley drum drive. With this system, two or three pulleys of different sizes set the speed of the drum. To change this type of belt, decrease the tension on the idler pulley and install the new belt in the V-grooves of all pulleys. Then place the idler pulley back into position.
With any dryer, make absolutely sure that you replace the old belt with a new one made especially for the dryer. Any difference in belts can change the speed of the drum and cause problems with other dryer components.
thank u................
Sep 12, 2008 | Dryers
Asko T700 loose belt, access from front?
I think you must replace the belt and the tensionarm. It MUST be done from the backside of the machine... Remove the backpanel, and the drum, change the tensionarm, and put the drum into the machine again. Put on the new belt, and mount it together again. Be careful for sharp edges! Hope this helps :-)
Jan 12, 2008 | Asko T700 Electric Commercial Dryer
Dryers Logo
59 people viewed this question
Top Dryers Experts
