Question about Epson Artisan 810 All-in-One Color Inkjet Printer
How do I scan a photo and print out a copy of it on regular paper?
    Genius:
  • 1,552 Answers
Insert the photo onto the scanning surface.
Click the "copy" button.
Posted on Jun 05, 2015
Hp c6180 won't print from 4x6 photo paper tray
If you put regular paper in the tray as it is asking does the printer use the regular paper to print the picture? If so, be sure the 4x6 photo paper tray (with photo paper) is pushed all the way in, and when you select print there should be an option (probably hidden in a submenu) to select the photo tray as the paper source. If you are printing from Adobe Acrobat, I have not found a reliable way to get the c6180 to use the photo paper tray. I hope this helps.
Jul 15, 2012 | HP Photosmart C6180 All-In-One InkJet...
Does not print red on regular copy paper Does print red on 4 x 6 photo paper
Check ur printer settings. Might be set to print on photo paper.change settings to normal paper. If all else fails. Uninstall and reinstal printer software.
Nov 01, 2011 | HP Photosmart 3210 Printer
Do I need a special paper for this printer?
no not necessarily. I suggest you align your printer tray in such a way that it will instantly insert the paper and print it successfully. Otherwise the problem is maybe the unit itself or the drivers..
Mar 09, 2011 | Dell Inkjet 720 Printer
How to print a regular document from Microsoft Word, Excel.
Instead of pressing the start button to print, you need to press the small ON/OFF button. The start button works to copy/scan. But to print, you will need to turn the printer on first. Once the printer is on, the computer should recognize it fine and allow you to print from your applications.
Jul 13, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Can I scan pictures to my computer?
Yes ... your all-in-one can print, copy and scan.
http://h10032.www1.hp.com/ctg/Manual/c00737535.pdf
Scan an image
You can start a scan from your computer or from the HP All-in-One.
This section explains how to scan from the control panel of the HP All-in-One only. To use the scan features, the HP All-in-One and computer must be connected and turned on. The HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) must
also be installed and running on your computer prior to scanning.
● On a Windows computer, look for the HP Digital Imaging Monitor icon in the Windows system tray (at the lower right side of the screen, near the time) to verify the software is running.
Note Closing the HP Digital Imaging Monitor icon in the Windows system tray can cause the HP All-in-One to lose some of its scan functionality. If this happens, you can restore full functionality by restarting your computer or by starting the HP Photosmart Software.
● On a Mac, the software is always running.
Tip You can use the HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) to scan images, including panorama images. Using this software, you can also edit, print, and even share your scanned images. For more information, see the onscreen Help that came with the HP All-in-One.
To save a scan to a memory card
1. Make sure your memory card is inserted into the appropriate slot on the HP All-in- One.
2. Load your original print side down in the right front corner of the glass.
3. Press the Scan Menu button.
4. Press to highlight Scan to Memory Card, and then press OK.
The HP All-in-One scans the image and saves the file to the memory card in the JPEG format.
To scan a photo and reprint it
1. Press Reprints.
2. When prompted, load your original photo print side down on the right front corner of the glass, and then do one of the following:
To reprint your original photo using the default print settings
➔ Press Print Photos.
To change print settings before reprinting your original photo
a. Press OK.
Basics Guide 13
HP All-in-One overview
b. Press or to highlight a paper size, and then press OK.
The paper size choices available vary depending on your country/region.
Note Depending on the paper size you choose, you might be prompted to choose a layout for the photos on your pages.
c. When the Fix Faded Original? prompt appears, highlight Yes or No as appropriate, and then press OK.
The HP All-in-One scans your original and shows a preview of the photo on the display.
d. Press OK to display the selection menu.
Tip If you want to print more than one copy of the selected photo, press to highlight Copies, and then press OK. Use the arrows to increase or decrease the number of copies.
If you want to edit the photo before printing, press to highlight Edit
Photo, and then press OK.
e. Press to highlight Done, and then press OK.
The Print Summary screen appears.
f. Press or to highlight one of the following options, and then press OK.
Print Options Enables you to manually specify the type of paper on which you are printing and whether you want to print a date and
time stamp on your photo.
By default, the Paper Type is set to Automatic and the
Date Stamp setting is set to Off. If you want, you can
change the defaults of these settings with the Set New
Defaults option.
Print Preview Displays a preview of what your printed page will look like. This enables you to verify your settings before printing and
wasting paper and ink on potential mistakes.
Print Now Prints your photo with the size and layout you selected.
To scan to a computer
1. Load your original print side down in the right front corner of the glass.
2. Press Scan Menu.
3. Press to highlight Scan to Computer, and then press OK.
4. If the HP All-in-One is connected to one or more computers on a network, do the following:
a. Press OK to select Select Computer.
A list of the computers connected to the HP All-in-One appears on the display.
Note The Select Computer menu might list computers with a USB
connection in addition to those connected through the network.
Jul 06, 2009 | HP Photosmart C5180 All-In-One InkJet...
Nothing prints on paper
Kodak printer 5500 make out photos with UltraPremium Paper very flashy even with darker photos shots,
tried calibrations with photo paper kodak says: no suitable paper format
Feb 11, 2009 | HP PSC 1315 All-In-One InkJet Printer
My HP Photosmart C6200 All IN ONE serial # MY7AJH63BB, will not print photos coming from my Mini Mac computer on to the photo paper in the photo paper tray. It will only print onto 8x11 paper sheet. I...
None of the buttons on my 3 in 1 photosmart c6280 work but I can use to HP solution to get prints ,scan , and copy. Can not turn off or clear '! "button with out unpluging
THANKS
Nov 29, 2008 | HP Office Equipment & Supplies
Hp fax/scanner # 6110
Hi Judy,
The only document I found at HP.com that may seem to address your issue is the following:
A 'Paper Mismatch' or 'Paper too Narrow' Error Occurs While Receiving a Fax
Have a look at the suggestions on that web page and see if anything there helps. Post back you results and good luck.
Nov 07, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Ink Color Issues
Did you change any of the configurations on your printer. Most photo printers have color settings that are media dependent. It sounds like you might have it set to print on regular paper but not on photo paper. There are a lot of settings that you can accidentally change on a printer so I would suggest uninstalling the printer then reinstalling it and see if that is the issue.
Sep 11, 2008 | HP Photosmart 3210 Printer
Epson Artisan 810 All-in-One Color Inkjet Printer Logo
224 people viewed this question
Top Epson Computers & Internet Experts
teamtech
teamtech
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
