I am not computer savvy, pressing the power button does no good, it has totally stalled
It's unplugged right now, why plug something in that's not working?
    Top Expert:
  • 6,702 Answers
Never unplug the computer. To switch it of,press the on / off button for 4 or 5 seconds, it then will power down, as it should and first save all important data. When you unplug, you will damage the data needed to start up again, without trouble. When switching on again the computer gives messages, follow these, so it can try to recover the lost data.
Posted on Apr 18, 2015
Why did my computer monitor stop showing an image?
Disconnect it from computer and power. wait 15 minutes and plug only the power back in, press the power on button. The monitor may display a message that there is no signal or something like that. If that happens the problem is either the cable or the computer. If you get no message then look for the menu button and press it to see if any thing appears. If not find the manual on line and read it. Many times monitors get over-driven by computers to the point that they can't display OR they self destruct.
OR
Another way is to just unplug everything computer and monitor for 15 minutes. Plug in monitor first then plug in computer and press the power button, the display should display the booting information if the cable is good and the monitor is good.
Jul 19, 2014 | ViewSonic Computers & Internet
Proton savvy 1.2 runs for a while then stalls
hi,
savvy engine is same with renault engine. there's a flywheel sensor/engine speed sensor between engine and gearbox. change the engine speed sensor.
The engine speed sensor is control the ignition timing, if the sensor can't read the 0' angle the engine won't fire up.
Jul 10, 2014 | 2009 Proton Savvy 1.2
Do not print after a paper jam
Do a total power drain in your printer.
Turn it off. Unplug it from the wall outlet and from your computer. Make sure that you remember where those plugs to put back.
While turned off and unplugged, press and hold the power button of your printer to 8-10 seconds to drain the power.
After doing that, plug it in to the wall-outlet. Turn it on. Connect it to the printer. Turn off then turn it back on. Try printing. IT should work.
Let me know if you have any questions.
I hope this helps!
David
Feb 10, 2013 | Canon PIXMA iP2000
My print activity says something is being deleted but it won't delete
Clear NV RAM.....
Unplug the Power Supply from the Printer....
Press and Hold the #5 button on the Printer and plug in the Power Supply.......
Don Release the #5 button till the Printer turns on completely....
After releasing the #5 button........
Press the Menu button once Keep on Pressing the Right Navigation Key till u find an option saying Maintanence goto maintanenece and go to manufacturing and click on clear NV RAM.....
Now as soon as the Printer is Restarted......
It will not show that message again.
Good Luck!!!!
Sep 26, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Compute turns on, lights light up, and fans move, but there are no beeps or bios showing up.
Computer turns on but no display. This issue is commonly caused by electrical static on the motherboard. Try doing a power drain.
If this computer is a laptop:
1. Turn the computer off by pressing the power button for a bout 5seconds.
2. Take the battery out of the computer.
3. Unplugged the ac adapter.
4. Press and hold the power button for about 30 seconds. (without any power source)
5. Put the battery back in and plug the ac adapter back into the computer.
6. Turn the computer back on.
If this computer is a desktop:
2. Unplug the power cable from the computer.
3. Press and hold the power button for about 30 seconds. (without any power source)
4. Plug the power cable back into the computer.
5. Turn the computer back on.
Thank you for choosing FixYa! have a good one!
Jun 02, 2011 | Computers & Internet
I have an IBM ThinkPad R32 2658 N4U laptop. Problem: When I press the Power button, it does not boot. I followed one advice which was to take battery and unplug it then pres power button 10 times, then...
It could be the battery or the power converter in the computer.
But after a closer reading it sounds more like a chipset error.
Does it work if the battery is completely removed and you boot on just the power cable?
On this link you can find the latest drivers for the chipset:
https://thinkpads.com/support/Thinkpad-Drivers/download.lenovo.com/lenovo/content/ddfm/R32.html
I can also see that it is an older model. You don't mention what version of windows you are running, but if you are running XP or earlier that says something about the age of the thing.
It could be that it is just simply worn out.
Luckily almost all the Thinkpad models are build to last, so you could take it to a shop and have them run a diagnostics on it and replace what ever parts that might be failing.
Just be adviced that the price for the diagnostics would most likely exceed the value of the laptop.
Personally I would get a tech savvy person to get the harddrive out (myself in my case), plug it to a second device with cables as an external drive (can be bought in most wellstocked computer hardware stores) and then do a backup of any essential data.
Mar 11, 2017 | IBM Computers & Internet
Is there a reset button? My son tried to plug the computer into our Vizio tv and now there is no power - it doesn't come on. I think he inserted something into the "service" plug.
We have a 42" LCD, model E421VA that had a problem. I called Vizio and they told me how to reset the TV. Unplug the TV from the power source, press and hold the TV power button (located on the TV) in for 30 seconds, then plug the TV back in and turn it on. Good Luck
Sep 04, 2010 | Vizio Televison & Video
Pump motor stalled
My advice would be that if your printer is in warranty then call up HP Total care as u
will get a replacement if the issue is not fixed over the phone. But if the machine is Out
of warranty, then you can try the following:
Make sure the printer is connected directly to the wall socket(No Porwe Surge or anything).
1) Power Drain: Unplug the power cord from the back of the printer, then press & ho;d the
power key for 30 seconds, then release the key & plug in the power cable back.
Check if the problem is resolved.
If Not
2) Partial reset: Unplug the power cord from the back of the printer again. Press and hold
the # and 3 keys together and while holding them plug the power cord back in.
If Not
3) Semifull reset: Unplug the power cord from the back of the printer again. Press and hold
the # and 6 keys together and while holding them plug the power cord back in.
hope fully the problem will be fixed by this. Please let me know
Aug 04, 2009 | HP Photosmart C6180 All-In-One InkJet...
System turns on however hard drive will not cycle nor will mouse or key board activate
Turn power off and unplug power from computer.
Unplug printers,backup drives and speakers.
Open case and unplug power supply from the board.
plug power cord back in press the power button.
Of course nothing will happen.
unplug power cord again.
plug power supply back into the board.
plug power cord backup and press power switch.
If nothing happens unplug power cord again.
pull out your memory sticks and plug cord back in and press power button.
Of course not much will happen.
But really something is happening to your computer so continue.
Pull power cord and replace memory sticks.
replace power cord and press power switch.
Continue this pulling out pci cards one at a time until you find out what the problem might be.
Try different keyboards and mice too.
Good Luck
Oct 27, 2008 | Intel Computers & Internet
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
