Cpu fan stopps
in my system all the fans are stopped after few mins when i boot up. i changed the motherboard and put a new one.again same problem. then i changed the smps,hard disk , ram,cpu fan, cabinet. then also same problem. then i removed the processor and power on.. now its works. so i changed the processor which was working perfectly in another system. then again i power on.. same problem again. then i removed the new processor and put into its orginal machine.. now both the system's fans stops after few mins. what will be the problem? there is no restriction for the fan in the bios.
  • 121 Answers
Try to clear cmos with the jumper next to the mainboard battery
hit delete enter setup bios and save changes
chek if the main board is not in unapropriate contact with the metal case.
chek the fans power connector pins in the board
and finally make sure that ur power supply is functionong properly.
Posted on Nov 14, 2007
Displays momentarily and asks for CPU fan connection. I have changed 4 fans and still get the same error message and the display goes off.
You're sure you have the cpu fan connected to the correct socket? sounds like it's not connected, or is connected to a different socket. Does the fan turn?
Apr 22, 2015 | Computers & Internet
Can't get my system to boot up
The power mapping grid on the motherboard may be defective
Sep 15, 2012 | ASUS P8Z77 WS Z77 LGA 1155 ATX Intel...
My computer keeps shutting down after a few minutes. I have replaced the powersupply as well as the cpu fan. I am being told now that it is the system/motherboard. Is that an accurate answer?
When the CPUoverheats it goes into thermal shutdown and will not boot up again until theCPU has cooled down.
The heat sink may be clogged with dust, which causes the CPU to overheat byreducing air circulation through the heat sink.When you replaced the CPU fan, did you put new thermal heatsink paste on the CPU/heatsink? If not then the CPU can overhest. Your computer fanmay be faulty and not spinning freely, in this case replace the fan.
Check the fan and heat sink assembly and remove the dust, loosen the dust anduse a can of compressed air to clear away the dust.
Mar 21, 2012 | Computers & Internet
Algerian-47
you could try removing power lead then remove battery from m/b for 5 mins this will reset bios back to maufacturers settings then replace battery and power then try boot up if no luck then change motherboard
Jul 01, 2009 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
Pentium D problem
Hi oilian,
Be glad it did shut down. If it didn't, your new CPU could haveover heated. There are a few reasons for a CPU to over heat.
1.) There is no thermal grease or too little on the heat-sink assembly.
2.) The old thermal grease was not removed or the old thermal tape was not removed.
3.) The heat-sink assembly was not cleaned completely with alcohol before applying new thermal grease.
4.) The CPU fan is running too slowly.
5.) The heat-sink fins are possibly filled with dust build-up & the CPU fan can not cool the heat-sink assembly. Boot to the bios & go to Hardware Monitor. There you can check voltage, CPU fan speed, CPU temp & other bios monitored settings.
Good luck oilian!
Mike
Oct 01, 2008 | ASUS P5GC-MX/1333 - Motherboard - micro...
Pci express slot
Hi dineshcs.
When adding a new graphics card (Your's being a PCI-Express), you must change a bios setting under the title " Advanced " section. Open you're M2N-MX manual & turn to page 2-21. You need to change the boot order for you're graphics to list,
[PEG/PCI]. Change Initiate Graphic Mode Select to [Disable].
These changes stop the onboard graphics card from loading & allow the PCI-Express card to load. The issue of possible motherboard overheating can be caused by many things. Here is a list of things to check.
1). Check the CPU heat-sink fan. Make sure the fan blades are
free from dust build up. Check fan speed in bios (Its RPM will be listed). It should be running a min of 2300 RPM.
2). Also in the bios is Hardware monitor. By booting into the bios go to this & watch the temp of CPU & motherboard. If either is getting too hot suggest you add a side case 3" fan to the system to help lower the CPU & motherboard temp.
Good Luck!
Mike
Jul 18, 2008 | ASUS M2N-MX Motherboard
There is a problem in starting the system
check the battery and check the hdd belt also and also check the smps
Jan 17, 2008 | ASUS P5PE-VM Motherboard
Processor over heating
This is normal behavior. Fans normally only run when they are needed, and your computer has multiple temperature sensors that direct this behavior (they are primarily located on the CPU, which could explain why the fans all worked when you took the CPU out). You should only be concerned about the fans stopping if your computer is, indeed, overheating.
Nov 14, 2007 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
Your CPU may have a problem
Have you removed all memory, other cards and unhooked all other drives to see if a short exists there? With a 300W PS some other component may be pulling too much that the CPU can't start so it tells you the problem is with the CPU or The CPU its refering to is on the video card? Good Luck, Tim
Feb 10, 2007 | Albatron K8T800 (K8X800 PRO LL)...
Computers & Internet Logo
235 people viewed this question
David Payne
David Payne
