Question about John Deere 826 1032 Snowblower Operators Manual Jde3
When running and you push in the auger it will turn for a short time than motor well die
    New Friend:
    Problem Solver:
  • 15 Answers
On the top of the right & left handle grips there are safety switches that you have to hold down and what happens is those switches get worn or the wiring connections to them get corroded or the wire brakes off you need to replace those safety switches
Posted on Oct 10, 2015
  • Troy Rambousek
    Troy Rambousek Oct 10, 2015
Ice maker does not dispense ice through the door
Hello. I had the same problem. I replaced the auger motor(around$95) 3 times and would only last about a little longer than a year. I bought the 4th one but this time, I wanted to diagnose the issue. So it turns out that the auger motor goes installed with the impeller upwards. What was happening was that if a piece of ice would stay in the dispenser chamber and melt, the water would go into the auger motor eventually causing the auger casing to get full of water and slow it down or short it out. I took the casing apart and noticed that there was a small space between the motor and the casing. I drilled 2 nice sized holes in the dimple of the new motor very gently as to not drill into the impeller motor and installed the auger. To this day, 3 years later, no more having to buy new auger motors. Hope this helps!
Mar 10, 2015 | Refrigerators
The ice maker will not dispense any ice. When the dispenser lever on front panel is pushed the dispenser door opens but the auger motor does not operate. If I thaw the freezer the auger motor will...
It sounds like your auger motor has an issue in my opinion. How i check them is: remove ice bin, open freezer door, hold door switch down, depress the freezer ice dispenser button on the door and see if the auger motor has the torque when it turns, if the motor has power and turns but cant turn w/ torque or has power and dosen't turn. you need a new auger motor. lmk if u need more help!
Aug 04, 2013 | Frigidaire FPUS2686LF Professional 26 Cu....
Kitchenaid KSRS25 Ice dispenser blades get stuck
Greetings,
In looking up this partial model # KSRS25, it shows you have
the model with the large ice bin inside the freezer.
My question to you is: Does the auger motor run when you
push the ice lever?
2 trouble prone parts on this model. Both in the case of NO
auger motor activation.
#1 broken pin that hold the micro-switch on to the switch bracket.
Item # 15
1690545?addlogo=false
Next #2 and the Worst, A Broken Blue wire or wires in the wire loom
under the freezer door hinge. Un-repairable new door needed if still
available.. You have to get creative restoring the power.
So before I continue, Does the Auger motor Run?
And if it does, remove the bin and close the door switch that turns the
light off, and tape switch shut. With door open and ice cradle pushed
in watch the auger drive fork turn? Is the the key hole stripped in the
fork.(rounded out) May need the fork or motor. #9 & #2
1708855?addlogo=false
May 28, 2013 | KitchenAid Architect® Series II KSRS25RS
Kenmore model number 253.55693400 when I push the ice dispenser tab the motor to push ice is on, but not pushing ice out.
You have an auger type of ice dispenser, so when you say you hear the motor is on, do you mean it is turning the auger? Take out the ice bin and close the door, push the dispense button and then open the door quickly to see if the auger is turning. If is is then dump your ice bin and let it sit out until it is completely defrosted and dry. Reinstall the ice bin and put the lever down. And see if that will clear the problem. The auger motor is not that strong and if you get any ice build up under the auger it will stop working. So defrosting and drying will normally clear it up.
Oct 02, 2011 | Kenmore Side by Side Refrigerator
Icemaker will not dispense ice. the bin is full. when you push the button the micro-switch clicks and the flap opens, but the motor don't turn. is it the motor or the pc board
You are correct. Motor or Board. See if you can turn auger motor by hand It is geared and should be hard to turn but not locked up. You can also remove auger motor assembly. Plug it into 110v it will run, (replace board) or not. (replace auger motor).
Nov 15, 2010 | Whirlpool GS6NBEXR Side by Side...
Whirlpool GS6NBEXRS01 ice auger motor
Un plug refrig. Check continuty on auger motor(ohms). If open winding or no continnuty motor is NG. Or rig a power (cheetercord)cord to apply 120v to motor to see if it will run. If the frezer door is open the door switch kills power to auger motor. Check door switch. If power is fed by a circuit board in the door pannel it my be NG. Or just the micro switch that the paddel hits when you push a glass up to it is NG or not being hit.
Oct 30, 2009 | Refrigerators
My ice maker makes plenty of ice, no problem with the water either. My problem is that the auger will not turn to dispense the ice out of the bin. The motor kicks on when you push in the buttom, however it...
Pull the ice bucket out, then hold in on the door light switches and while you push a glass into the button for ice (may require two people). Ice dispenser and auger will only work, when you push for ice, when the freezer door is closed, so by holding the light switch(s) in the off position with door open you can simulate door being closed. If you can push the button and see the auger drive turn (with ice bucket out) then check to see if you have some ice stuck between the blades on the bucket, if the auger motor doesn't turn, it may be "ice frozen". Common problem. Remove motor, let sit on counter for about three hours and then reinstall, if it then works then check for water dripping from the fill tube, where the water comes into freezer for the ice maker, and see if it is dripping onto auger motor.
If you put auger motor back in and it still won't turn then more and likely you need an auger motor.
Let me know.
Oct 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker makes ice but can't dispense ice
Please try this. Remove your Removable Ice Bucket Assembly which is where the Auger (corkscrew) is located. You should be able to see the Auger Motor Drive Fork which is located permanently inside the freezer compartment... opposite the end of the Removable Ice Bucket Assembly that you just took out. Close the freezer door and attempt to dispense ice... if you can hear the Auger Motor running as you attempt to dispense ice... then the Auger Motor is OK. Dump out all the ice that is in your Removable Ice Bucket Assembly and wash it out in your kitchen sink with warm water. Reach into your freezer and put your hand on the Auger Motor Drive Fork ... you should be able to rotate it CW or CCW...it is a little hard to turn but it will turn. Position the Auger Motor Fork to a 12:00 and 6:00 o'clock position. Now take your Removable Ice Bucket Assembly and position its Receiver Auger Fork to a 9:00 and 3:00 o'clock ....Re install the Removable Ice Bucket Assembly into the Auger Drive Fork. Close the freezer door and again attempt operate the ice dispenser... you should hear the Auger Motor again run as you press the ice dispenser. Note....at this same time the Ice Chute Door in the Freezer Door should spring open so that ice can fall out. Of course you have no ice in the Auger at this time...but it all this works then future production of ice will fall out. Note...Usually the Auger Motor never fails. but the whole thing can get jammed with ice and not dispense. Also, the the solenoid that operates the Ice Chute Door fails quite frequently. Last but not least... if nothing is happening... it is a control board type problem. Hopes this helps! Handy Henry
If you need further help, I’m available over the phone at https://www.6ya.com/expert/henry_239f63a136de60f0
Jul 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice Dispenser kitchenaid KSRP25FNSS
first make sure that there is not ice clogging the auger. check that connection to the auger motor is secure. If it appears to be fine you will need a volt meter for the following steps. If you are not comfortable using this equipment or do not want to buy one call a repairman. If you choose to continue remove the leads from the auger motor. Configure the meter to read ohms and place the leads across the motor connections. The meter should read some resistance if not the motor is either shorted or a lead has burned completely due to a short. If the motor is fine configure the meter to read volts. Look on the motor and determine if it is AC or DC and configure the meter for this. Connect the voltmeter leads to the motor feed wires and press the ice despense button. If no voltage is observed check the switch for continuity. Replace any faulty parts. If this sounds foreign to you call a repairman.
Mar 27, 2008 | KitchenAid KSRP25FNSS Side by Side...
John Deere 826 1032 Snowblower Operators Manual Jde3 Logo
129 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
