I saw many listing the same problem I had, batter plugged in but not charging and now my computer is dead and won't start
    Top Expert:
  • Computers & ... Master
  • 8,204 Answers
HAVE YOU TRYED STARTING IT WITH OUT THE BATTERY IN?SOME WILL START WITH OUT BATTERY,IF IT DOES THEN REPLACE BATTERY.
Posted on Apr 18, 2015
Razor electric scooter e 300 battery charges but won't run
first check to ensure the batter has held the charge you put into it. Just plugging the charger in does not mean the battery is holding the charge. If the battery is bad, it will drain as fast as you put it in. if the batter holds a charge, should be able to disconnect the charger and battery will show charge. if so, you have a bad connection or motor.
Jun 29, 2013 | Motorcycles
Presario cq60-420 won't power on or charge
Is not necessarily a problem of the battery, the screen is also related to, a change in the LCD.This should help you http://www.lcdinverters.net/Laptop-Inverter/Compaq/Compaq.html
Oct 10, 2012 | Compaq Presario CQ60420US Pentium DualCore...
Phone is beeping and not holding a charge
batter could be shot or if u plug ur phone in the wall when batter is not fully dead the memory from the phone will still think ur battery is dead when its not
Jun 17, 2012 | Samsung SGH t340G Straight Talk Cellular...
Kindle Touch won't start
Bad battery, needs changed.
Nov 09, 2017 | Computers & Internet
My explorer won't start, It was dead, I charged the battery. got a clicking noise. the battery died again, charged it and let it sit for a couple hours, went to try again, didn't even have to...
if the batter has a drain the starter may be at fault the starter can drain a battery with out running i would unhook the battery cables then charge the battery then i would have the starter tested.
Sep 05, 2011 | 1991 Ford Explorer
After charging my dead battery it will only run for a second or two then dies.
Perhaps the batter is "dead" dead and has met the end of it's functional life. You see, lead batteries like car batteries convert lead ions in solution into a solid as energy by chemical reaction. Charging the batter reverses the process, but the process becomes less and less reverseable as the age of the batter increases. When the process can no longer be efficiently reversed by "charging", the battery remains in it's dead, or semi-dead state, where it might run for only a few seconds.
Also, your alternator might be shot because technically, if you can start your engine, the alternator should provide the power to remain on; the battery serves only the purpose of starting the car and receiving the charge from the alternator to power the rest of the car's electronics.
Test both the battery and alternator, no more than $100-$150 to fix either problem.
Hope that helps!
Feb 02, 2011 | 1995 Jeep Grand Cherokee
Battery is dead and I want to charge it and take it in for replacement
Boost your car with jumper cables and let the car idle or drive around for about 20 minutes for the alternather charge the batter on its own .if the car shuts off after you started it might be your alternather is no good . the reason why ur alternather might not be working is because the batter all it does is give enough power for the starter to crank the engine as soon as the engine starts running it gets all its juice from the alternather and it charges the batter as well. but some times when the alternather works and the batter is dead meaning all the cells inside the batter are dead it will never take the charge from the alternather. so you would have to change the batter.
if you would like to know how you can you test both parts useing a volt-a-meter... just ask...
p.s. I think its ur batter if you never changed it. so get that changed for the winter so you wont have any more starting problems during cold wheaters
Sep 26, 2008 | 2001 Chrysler PT Cruiser
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
