Question about Samsung Stainless Steel French Door 28 Cu Ft 4 Door Refrigerator Rf4289hars
What is wrong with my ice despensor not turning to kick out the ice that is being made?
    Genius:
  • 1,554 Answers
Door latch switch , thinks door is open
or the motor is stuck /frozen
or the
front ice dispenser switch
does it switch to water an dispense
does the arm try to move /jitter,
being a geared down motor you can't /not turn it manually or can damage the teeth.
you might need help
Posted on Apr 18, 2015
When ice maker kicks on water comes out front water despensor and not in ice maker
Did someone switch the water dispenser side of the dual water control valve wiring to the wrong side? If someone has switched the wires around not knowing the difference this will happen. Look around the fresh food section door frame for the mofel number of your refrigerator. If you post the model number I may be able to provide a wiring diagram. Without the model number I will only guess what model you have. Also there may be more involved here. Please provide a model number so I know what you have. Thanks Sea Breeze
Nov 24, 2012 | Refrigerators
HAVE A KENMORE FRIDGE M.#106.74253400 WATER DESPENSOR STOPPED WORKING AN CAN HEAR IT HUMMING AN ALSO THE ICE MAKER WORKS SO I NO ITS GETTING WATER? THANKS
my kenmore did the same thing, It had a duel water solenoid on it and one that let water into the door water dispenser went bad. also my ice cube started to get smaller, the rubber in the other side of the water solenoid was dry rotting and eventually ruined the ice maker. I replaced the duel solenoid and ice maker and had no more problems.The solenoid is on the back of the fridge, it is what the main water supply connects to.
Dec 31, 2011 | Refrigerators
My dad has a old GE GSS20IEMD refridge - that is only being used outside. No water to the refidge just want to use the crush ice by manually putting ice in the despensor. Turned the switch in the back of...
No, this is a built-in function and should work when you push the crushed ice lever. If it is not working, you now know why it was moved to the garage, because it does not work.
Jul 30, 2011 | Refrigerators
Whrilpool side by side despenses water but no ice
follow the line down the back sometimes it freezes up. You might have to remove panel behind. try this
Apr 10, 2009 | Whirlpool ED0GTQXMQ Side by Side...
Door panel doesnt work
Check circuit fuse,electrical connections,check your door circuit & buttons.
Feb 21, 2009 | GE Adora (DSF25KGTBG) Side by Side...
The water despensor and the ice maker both stopped working
sounds like your folter may be plugged up or frozen, the water goes to the filter first then to the dispenser and ice maker look there first.
Jan 03, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice despenser in side by side door, kenmore does not work
Pull the grill cover off near the floor and look to see if any of the wires have been cut. I found that the grill cover wore on the wires controlling the door functions. First the crushed ice function went, then the water dispenser went. I had splice the wires back together and am leaving the grill cover off. No problems since.
Jan 01, 2009 | KitchenAid Superba Architect KSCS25INSS...
Samsung Stainless Steel French Door 28 Cu Ft 4 Door Refrigerator Rf4289hars Logo
113 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
