Question about Health & Beauty
OK the only thing I had done was shave the flywheel it's a 2 stage flywheel now it makes me wonder if they shaved outer lip of flywheel
SOURCE: No close shaves
I've replace the cutting surfaces and the thing just won't cut.
Posted on Sep 02, 2008
VtToolMan
  • 704 Answers
SOURCE: Plastic retainer for the shaving blades is broken
You can buy a replacement shaver head and screens from an Oklahoma shaver business, electric shaver company.
Here's a link to their site and the page for the Norelco shaver you're looking to get parts for. The 3rd item down is the shaver head and screens, blades, etc.
I don't think you can get just the plastic retainer all by itself, as the manufacturer makes a complete head and blade as a replacement set, however, you can call them to see if they have just the retainer part you need. But frankly, it's likely a good idea to change shaver heads every so often to get the best shave, etc., so you might just want to spring for the complete replacement assembly part #HQ9 on this site for under $40.00.
http://www.electricshaverstore.com/get_list_143.htm
Hope you find this Very Helpful and best regards!
Posted on Sep 22, 2009
hslincoln
  • 235 Answers
SOURCE: Kitchen aid mixer drops metal shavings in the
Hi REDLACQUER. Sorry to hear about the metal shavings. This is probably not to best way to take iron in your diet... My first thought would be to ask if your mixer is still under warranty. If you’ve had the machine less than one year, then I’d let KA replace your mixer with a new one. However, I suspect like many who seek assistance from FIXYA.com, your mixer is out of warranty, so what can you do?
Have you been able to find exactly where the metal shavings are originating? From the symptoms you describe, it appears that the planetary/agitator shaft assembly may be rubbing against its housing and generating the metal shavings at higher speeds. Have you noticed any increased noise levels/squeaking/screeching when the planetary rotates? It’s also possible that the planetary is out of alignment and not rotating true. Could the agitator shaft been jarred or hit hard during set up or moving in or out of you storage cabinet? Or the shavings could be symptomatic of other internal gear problems, but that would be the least likely scenario as the mixers internal gears are pretty much self-contained.
The good news is that this can be troubleshot and fixed quite easily (OK, maybe with a little effort) by yourself if you are a DITY type person, and feel adventurous. However, before you start to disassemble your mixer, be sure you have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case, KP2671, and select the last file, KP2671XWH3.pdf (325.07 KB) listed under Parts List (24) (check to verify that it matches your mixer model).
Turn to pages 4 & 5, titled “Case, Gearing and Planetary Unit”, which provides and exploded view for the disassembly and reassembly of your mixer, along with all the parts. I suspect your Planetary Assembly, Illus No. 15, is rubbing somewhere against its housing, Lower Gearcase, Illus. No. 24.
To gain access to these pieces you’ll need the following tools: a regular or Phillips screw driver, retaining clip pliers, and a small drift pin punch and a small hammer. You need to remove the Transmission Housing (Illus No. 7) and remove all the lubricating grease from the transmission housing and gears (when removing the grease be on the lookout for shavings in the grease which would indicate excessive gear wear). This will allow you to remove Illus No. 25, 21, 18 & 19, Retaining Clip, Bevel Gear, Retaining Pin and Worm Gear Follower, respectively.
Once you remove the Retaining Pin (Illus. No. 18) the Planetary Assembly can be tapped down through the Lower Gearcase Assembly (Illus. No 24). With the Planetary removed, you can inspect it and the inside of the Lower Gearcase to determine where the shavings originated. Be sure to look closely at the Planetary Gear in the lower gearcase as well as the Agitator Shaft Pinion Gear (Illus. No. 12). That will also identify what parts need to be replaced, which you can order online.
You’ll need to replace the grease you removed with new grease. You should use a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call). Do not try to reuse any original grease as it may have ‘debris’ in it.
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com (for grease). You should search for ‘food grade grease’. Prices can vary widely between vendors, so do your comparison shopping.
It can be messy but quite gratifying to diagnose and repair your mixer yourself.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer. The mixers displayed in the links are different KA models, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer.
I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
Posted on Jan 12, 2010
SOURCE: Type of Battery ER203 Panasonic
BATTERY MODEL NUMBER: WER203L2508
Posted on Jan 28, 2010
kerguney
  • 577 Answers
SOURCE: resetting the how many shaves counter
Hi,unfortunately there is no way to reset this counter,even after replacing battery it still stands there.Braun somehow prohibits user and/or unauthorized repair men to do such action.If you visit the following link there is a official statement by Braun states that" total number of shaves (cannot be reset)."
I am sorry,this is the fact.
Regards
www.service.braun.com/line/SH/S5646/S5646_3_CHIN_KOR.pdf
Posted on Jun 05, 2010
Sportsman 400 4x4 blows back threw radiator and resivoir but no water in oil
have a compression test done to check for cracked head
if you didn't follow the procedure exactly, ( cleaning out the stud holes , replacing with new head studs , pulling down in a sequence in several stages , had the head shaved to make it flat again , then the problem will be in what you have failed to do properly
Mar 26, 2017 | Cars & Trucks
I am a woman with hair on my upper lip, is it ok to shave it?
No!! it's a terrible idea to shave the hair on your upper lip. It will just grow back stubbly. You can either bleach it or have it removed permanently with electrolysis or laser treatments.
Feb 18, 2013 | Health & Beauty
Any tips for shaving my bikini line?
1. Make sure you use a moisturizer before you start shaving
2. Pull the skin tight to create tension.
3. Shave in the direction that the hair grows
4. If you have a beach or pool day out, make sure you shave the night before to avoid rashes and irritation from shaving.
After Im done shaving with my electric shaver, do I need to use any lotion?
In order to properly care your skin, you should use a pre-shave lotion after you done shaving. First you should rinse your face with warm water then cool water. Then, you need to par your face dry and apply an after shave balm to smooth your skin.
Feb 06, 2013 | Health & Beauty
This is the first time I am shaving with an electric shaver, is there anything I need to know?
If your switching to electric shaver or it is the first time you shave you will need to give your face three weeks to adjust to electric shavers. Try not to fluctuate back and forth between blade shaving and electric shaving during the first three weeks.
What should I do after Im done shaving?
First you need to clean the remaining shaving cream on your face and then you should use after-shave toners which will help remove any residue left over from shaving, close the pores, and refresh the skin.
Starter grinding on 87 f-150 with the 4.9 strait six and c-6 trans. done put 4 starters does it need shiming
You can't shim Ford starters. First check to make sure you're getting correct starter... Ford 6's have a couple different "noses"/inputs - some actually extend further in. So check to make sure you're getting the correct part from your source. If it is correct part, you're going to have to replace flywheel. Also before putting in starter, check the flywheel for "burrs" - tiny metal particles left behind from old starter on flywheel. Almost like metal shavings between teeth of flywheel.
Mar 11, 2011 | Ford F-150 Cars & Trucks
Washing machine making vey load something is wrong noise. Called repair man, he states too young (2yrs) to be a drum problem and okay to use just do smaller loads. On 2nd load found metal shavings..have...
The rear half of the outer tub that contains the rear metal bearing has loosened so much that the inner drum has sagged and is rubbing on the front half of the outer tub. You need to see if this is under warranty. There is usually a 5 year warranty on the outer tub and a 10 year or a lifetime warranty on the inner tub. When I do this repair, I replace the rear half of the outer tub and the inner drum since it's under warranty anyway. The repair is the most difficult and time consuming repair possible on that type of washer. It needs to be done by an expert, not just your average washer repair guy. It's not rocket science, but you have to take EVERYTHING apart and it takes a long time and you've gotta know a few things about the machine in the first place. It's not fun. If it's under warranty for parts, expect to pay between $75 and $200 for labor. If the parts are not under warranty, then throw it away. They're $500+ for the parts.
May 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Health & Beauty Logo
701 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
Jeff Tilburn
Jeff Tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
