Question about Maytag Dishwashers
My maytag dishwasher jetclean quiet pack won't drain
  • 954 Answers
Hi Cherie: Try watching this video that demonstrates how to repair non-draining dishwashers: https://www.youtube.com/watch?v=rO19zoOyNHA
Posted on May 13, 2015
abhishek33
  • 1239 Answers
SOURCE: MAYTAG JETCLEAN QUIET PACK
hi Replacing the Door Gasket
If water leaks through the dishwasher door, the gasket is probably faulty. Open the door and examine the gasket. It should be soft and resilient. If it's worn, cracked, or hard, it should be replaced.
Once the gasket is in place, check it for fit against the door frame. It should fit tightly with no cracks or bulges between the gasket and the frame. If necessary, tighten or loosen the retaining screws, or refit the gasket in the clips or the door channel. Then run the machine through a washing sequence and check for leaks.
If you spot a leak, and the gasket seems to be properly in place, try adjusting the door latch. The trick is to position the gasket against the frame of the door without flattening the gasket or squeezing it too flat when the door is latched properly. Adjust the latch or the gasket until it fits snugly against the door frame.
Posted on Oct 10, 2008
  • 172 Answers
SOURCE: My Maytag dishwasher does not drain water after the wash cycle is over
Hi olabrk,
If you have a disposal make sure it is clear. You can put some icecubes in it to clean the blades and run some water through to make sure the drain is clear. If the dishwasher will still not pump out all the water check the drain line from the dishwasher to the sink drain for obstructions. If the drain is you will have to check the pump for obstructions. Sometimes glass, popcorn, toothpicks etc.... can get in the pump and prevent it from pumping out. If the pump is clear, then you will need a new pump. Good luck to you.
Mike Anderson
Posted on Oct 30, 2008
SOURCE: Maytag JetClean Dishwasher Quiet Pack
Power on, drains clear but no water entering durining cycles?
Posted on Dec 20, 2008
  • 5 Answers
SOURCE: Dishwasher does not drain
The drain runs from the dishwasher into either the side of your garbage disposal, or directly into your sink drain. If it is running to your disposal, pull the hose and make sure that the plug in the disposal (where the hose connects) is knocked out. Some have been known to install them without removing the plug. Either way, pull the hose loose and you can use a compressor to blow through it. If the air comes back through the dishwasher, then you are probably blocked in the main drain.
Posted on Jun 22, 2009
SOURCE: Maytag jetclean eq plus dishwasher: soap problem
This could be due to 2 problems: not enough water or water is not being pumped hard enough through the system. The 'not enough water' is easy to check - open the door in the middle of a wash cycle. If you have enough water (about 1" or more) then that is probably ok. The 'not pumping hard enough' could be as simple as plugged up filters and holes in the spray arms. Remove the racks and disassemble the lower spray arm and the filter assembly all the way down past the screen. Clean the arm holes, throughly clean the screen, clean everything. Pull the top spray arm and throughly clean the spray holes there. Put it all together and run a cycle. You should see a pronounced increase in the sound of the water spraying around. This should fix your problem - it did for me.
Posted on Jul 15, 2009
Users manual showing how to operate maytag jet clean dishwasher quiet plus
Good Morning Marion!
You can find installation and user guides for the Maytag Jetclean here
Maytag Jetclean Dishwasher (it's the Maytag site, and the page has several links to PDF files. The specific owners manual is at
http://www.maytag.com/digitalassets/MDB5000AWB/Use%20and%20Care_EN.pdf
Hope this helps, and good luck!
D
Nov 19, 2015 | Maytag Dishwashers
My maytag jetclean dishwasher quiet pack makes a grinding noise and the sprayer doesnt spin
Take apart the sump filter area and check to see if anything is stuck in the impellers for the wash motor.
Jan 01, 2015 | Maytag Dishwashers
On a maytag jetclean quiet pack dishwasher all the panel lights come on and flash
I had the same problem today - they replaced my telephone pole yesterday and had the power shut off for a couple hours. All light blinked when door closed. I reset by pressing the "drain/off" button for 15 seconds.(found info. on another site) Seems to be ok now
May 21, 2012 | Maytag MDB7100AWB Dishwasher
Maytag Jetclean problem
Hi!!! 10 years is alot for a dishwasher..You could have a plugged drain pump.Check your drain pump.All make sure that the water inside your dish water is hot inside it should read over 100 plus..Good luck..
Jan 03, 2009 | Maytag MDB9600A Jetclean II Built-in...
Loud noise during cycle MDB6600AWB Maytag Quiet Series II
look for odjects in the pump cutter ie glass plastic or the cutter is bent or a rushing sound could be motor bearings
Dec 24, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Hi olabrk,
Mike Anderson
Oct 30, 2008 | Maytag 24 in. MDB7650AWS Built-in...
Feb 27, 2007 | Maytag 24 in. MDB5600A Jetclean II...
Jet dry not draining no clog as far as i know
i needed all your all your serial num its important 17
Nov 30, 2006 | Maytag 24 in. MDB5600A Jetclean II...
Dishwashers Logo
217 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
