Question about Water Water Heaters
Water heater is leaking from the temp/pressure relief valve. the leak is coming out of the copper tube.
  • Water Master
  • 5,245 Answers
Following link has troubleshoot checklist and instructions:
http://waterheatertimer.org/How-to-replace-TP-valve.html
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Apr 18, 2015
Overflow valve on tankless Rheem was leaking & replaced with valve that has sensor from home depot. It is still leaking. Is there a specific overflow valve that I need to use on my tankless system?
The valves are the same specs. Is it possible that a new valve leaks, yew. However if both valve leak then there are other problems. Does the valve only leak when hot water is called for? Then check temperature setting on heater. Does it lek all the time? The water pressure is to high ,
  • Maximum Temperature Setting (Deg. F): 210
  • Maximum Pressure Setting (psi): 150
Why the relief valve at the water heater is leaking and what to do about it
Does tankless water heater require pressure relief valve
Jun 25, 2018 | Rheem Water Heaters
My rheem 30 gallon water heater(electric) is contasntly leaking. How do i stop it?
if not the inlet or outlet connections-the heating elements or relief valve then most likely have a damaged tank and most likely need a replacement
May 06, 2018 | Rheem Water Heaters
How to change out copper piping from release valve
If the release valve referred to is the pressure release valve, then a water leak out the attached vent pipe is an indication that the valve is failing. To change the valve, the water must be allowed to cool (turn off AC power or gas) and the water level inside the tank must be lowered (drained) to below the level of the pressure relief valve. Once this is accomplished the vent pipe is unscrewed from the relief valve and the pressure relief valve is unscrewed from the water tank. A new pressure relief valve with a sealant on the threads, is then screwed and tightened into place with the outlet port facing downward. The vent pipe is attached to the new valve and the tank refilled with water. A hot water facet must be opened to allow air to exit while filling. Upon becoming full (water will begin to flow from facet), turn off the facet and restore AC power or gas, therefore allowing the water heater to heat up. When the first hot water is utilized there may be some air expelled from the facet.
Sep 13, 2015 | Water Water Heaters
Pressure releif valve leaking
Hot water pressure relief valves serve two functions. The first is to remove high-pressure water from the hot water tank. The second function is to act as a high temperature valve to remove water that exceeds a predetermined point for the valve. Both of these relief settings are preset at the valve factory. Many pressure relief valves will come with a metal tag that identifies these release points. If you're attempting to remove the hot water heater pressure relief valve, pay careful attention to ensure that you replace with the correct valve.
Your hot water heater has a pressure relief valve safety mechanism. When pressure inside the water tank exceeds certain limitations, the valve opens up to allow the pressure to be released. A faulty pressure relief valve will not release excess pressure, which could cause extensive damage to your home. You should test the hot water heater pressure relief valve once every six months to ensure proper operation. If the pressure relief valve fails the test, replace the valve with a new one immediately
Locate the pressure relief valve on your hot water heater. The pressure relief valve has a lever handle on top with a drain pipe attached to it. The pressure relief valve is most often on the side of the water tank toward the top. Newer models of hot water heaters have the pressure relief valve on top of the water tank.
  • Inspect the area around the pressure relief valve for signs of leaking water. If there is leaking water near the relief valve connection, replace the relief valve. If no leaking is evident, proceed with testing the pressure valve.
  • 3
    Examine the area below the pressure relief valve drain pipe. Most water heater closets either have a drain in the floor below the pipe or the pipe is inserted into another pipe to direct the water out of the home. If the end of your drain pipe is not in another pipe or there is no drain in the floor, place a bucket under the drain pipe to catch water when you test the pressure relief valve.
  • 4
    Pull the lever handle on the top of the pressure relief valve up with your fingers. A working lever will lift up without difficulty.You should begin to hear water going through the drain pipe. Slowly release the lever to shut off the pressure relief valve. The pressure relief valve is good. If you did not hear water running through the drain pipe, lower the lever on the pressure relief valve and replace the valve. If the lever is difficult to raise, do not force the lever. Replace the pressure relief valve.
  • Now with all that said if you have a closed loop water supply system and you have a pressure vessal/expantion tank it may have gone bad and is making the TP valve leak. you can call your water provider to see if you have closed loop system.
    Feb 04, 2011 | Whirlpool Water Heaters
    Turned off the hot water to fix a leaking tap. now the tap has no hot or cold water and the hot water tank valve is leaking?
    It sounds like two problems.
    Problem 1) Clog inside faucet or clog inside pipes at faucet
    Remove supply tubes leading to faucet and see if problem is inside pipes or inside faucet.
    My bet is clog inside faucet.
    If you have galvanized pipe that meets copper pipe, this can be trouble spot.
    Article on clogged water pipes at Inspectapedia:
    http://www.inspectapedia.com/water/Water_Pipe_Clog_Repair_Guide.htm
    Article on clogged pipes:
    http://www.waterheaterrescue.com/pages/WHRpages/English/Troubleshooting/Tanklets/backflushing.html
    Problem 2) Water heater leak ... you say tank valve is leaking? Is that cold-water shut-off valve? Or tank drain valve? Or TP valve?
    If cold water shut-off is leaking, then replace shut off.
    If tank drain valve is leaking, then check if plastic valve is cracked. If drain valve is cracked, then replace with a brass valve from Home Depot. If plastic valve breaks off, then use hammer and screwdriver to gently chip out the broken plastic valve. New valve threads need teflon tape to seal pipe. If valve is just dripping, then put garden-hose cap over end of valve and screw down tight.
    If TP valve is leaking, then replace with same temperature and pressure rating.
    New TP valve threads need teflon tape to seal pipe.
    Problem 3) If pressure is low all over house:
    Buy pressure gauge at hardware store that screws onto hose connection.
    Test pressure on outdoor spigot.
    Open faucet and check if pressure drops. This says if problem is inside pipes that enter house.
    Test pressure on water heater drain valve.
    This says if pressure problem is before -or- after water heater.
    If problem is before the water heater, then shut-off valve located on cold water line is suspect.
    If problem is after water heater, it could be in hot water outflow pipe on top of water heater, or a nearby elbow.
    Remove hot water line leading from water heater and check pressure. This says if problem is where hot water leaves tank.
    Read articles above about clogs inside water lines.
    Nov 16, 2010 | Rheem Water Heater Pressure Relief Valve
    Pressure relief valve
    The pressure relief valve only leaks when there is excess pressure in the system, possible causes could be excessive static pressure, overheating, faulty pressure vessel or undersized pressure vessel.
    Apr 11, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
    Leaking pressure relief valve
    what is the water pressure on the cold side? You may need to install a pressure reducing valve at the water heater inlet to reduce inlet pressure and keep pop off valve from opening when not needed.
    Feb 27, 2010 | Emerson Part UWL Chrome Ultrasystem water...
    Burner lights but will not shut off. then pressure
    CHECK TO MAKE SURE THE WATER TEMP IS AT THE NORMAL OPERATING RANGE. USUALLY AROUND 120-130 DEGREES. IF IT IS, CHANGE OUT THE PRESSURE RELIEF VALVE. IF THE TEMP IS OUT OF SCALE, CHANGE OUT THE ECO AND TSTAT.
    Jun 28, 2009 | RTO Atwood Water Heater - 6 Gal LP
    Hot water tank leak
    drain valve must have already been leaking, that's why someone put the cap on. It's ok to cap the drain but never the pressure/temp relief. If the water is coming out of the drain (not around it) you could either replace the cap or the drain valve to stop the leak - otherwise it's time for a new water heater.
    May 24, 2009 | Water Heaters
    The pilot was out this morning and after I got it started, I got
    Hi jeake9,
    Yes, you are correct it sounds like the pressure relief valve. It is an important safety device that lets water out of the water heater when temp/pressure exceed the limit set on the valve. It did its job good.
    Now the important part is to change out the valve and try to diagnose why it tripped. Odds are the water temperature was too hot AND the relief valve couldn't close because of mineral deposit build up.
    Replace the relief valve and turn the water heater down for starters.
    Please rate this response and Good Luck, Phil
    Jan 01, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
    Water Heaters Logo
    56 people viewed this question
    Top Water Heaters Experts
    vince
    80stech
    D. E. Hev
    Are you a Water Heater Expert? Answer questions, earn points and help others
