Question about Hoover Washing Machines
I have a hoover machine and the motor stoped working
  • tom cassidy
    tom cassidy Apr 18, 2015
    Hi Albert Zarb, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • Hoover Master
  • 5,323 Answers
WASHER WILL NOT START:
Power If your washing machine won't start, begin by looking at the power source. First of all, is the washing machine plugged in? If it is, has it tripped a circuit breaker or blown a fuse? Check and reset the breaker (or replace the fuse) if necessary.
Lid Switch The main control for the washing machine is the switch inside the lid. If this has stopped working for some reason, your washing machine won't start. It's not especially difficult to troubleshoot this on a washing machine. You might have to open the top to access the switch. With the power on, depress the switch and listen for a click. If you don't hear one, the switch MAY BE BAD and will need to be replaced. Confirm defectiveness with a multi meter checking for continuity OHMS. An open circuit reflects a bad switch..
If the switch works but the washing machine still won't start, check to see if your washing machine has a special fuse for the lid switch. It will usually be inside the control panel. If it's blown, you'll need to replace it before the washing machine will start.
Door Interlock The problem could be with the door interlock. If the lights come on but the machine won't start, this might well be the cause. This could either be down to the wiring that runs to the door interlock, or the door catch not activating the interlock itself.
Timer Knob Some models of washing machine use a mechanical timer knob and won't run until the water in the machine has filled to the selected level. If the knob doesn't line up properly with the graphics on the control panel, you can try to troubleshoot the washing machine problem by advancing the timer a little. When you've done this, pull it out a little way and see if the washing machine will start properly.
Overheating If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings.
Posted on Apr 20, 2015
Hi, i have ONHF 6117 Hoover washing machine which dropped out of my van while moving house the problem is there no motor action, i had someone look at it he changed the pcb module board, motor and pre
All washing machines have a switch that is activated when the lid or door is closed. This tells the machine its safe to run the motor. If this thing dropped out of a van, it's possible the housing twisted and the little metal bracket on the door is not making contact with the safety switch or the switch may now be broken.
Nov 25, 2014 | Hoover Washing Machines
My Hoover washing machine 2305l sometimes dosen't
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jun 10, 2011 | Hoover HTC243 Top Load Washer
Hoover AL 120 washing machine won't spin
i would check the motor carbons it could be your problem if it fills goes through the programme until the end but has motor action
Apr 12, 2010 | Hoover AL120 Front Load Washer
Hoover 5010D drier died on me...is it thermostat ?
If it is a thermostat there is nothing wrong with jumpering the supply across to the out feed to make sure that the rest of the heating side is OK before you buy a new stat.
You only need to run the machine for a minute or so to acertain if it all works
Oct 06, 2009 | Hoover Dryers
Loud noise, smell smoke, brushes turn slower than before, stoped using
yes there are replacement parts for your hoover call any athourized hoover dealer and give them your model # usualy the motors are more expensive than the hole machine
May 22, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Commander 7kg (about 9 years old) not working. It does not spin in any wash cycle, although it can be done manually with ease in the 'spin dry' cycle. There was a strong rubber smell before. Any...
I have a Hoover Commander Model 2045LOAUS. The machine washes OK but will not spin (ie pump the water out). Could it be a burnnt out spin solenoid or motor??
Apr 26, 2008 | Hoover Washing Machines
Hoover CA230 1300 Special Edition Washing Machine
Should you have to use un due force to get the filter undone on the Hoover 1300 special deition washing machine
Jan 14, 2008 | GE S8000E
Washing Machines Logo
71 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
