Question about Kenmore HE2 Plus Front Load Washer
Washer leaks only on the final rinse and is not a hose. Is this repairable?
    Genius:
  • Kenmore Master
  • 1,585 Answers
Seems to b a pump prob check pump
Posted on Apr 18, 2015
  • Patrice Jennings
    Patrice Jennings Apr 19, 2015
    I'm having the same problem! How would I check the pump?
  • tom cassidy
    tom cassidy Apr 20, 2015
    u need to b electral minded
After final rinse washer continues to run water out on the floor
leaking or faulty waste water hose, tighten or replace it.
Mar 03, 2016 | Washing Machines
Water leak from the bottom of washer
Hi friend, thank you for your post!
I understand that water is leaking from the bottom of your Frigidaire washer. There are many components that could cause a washer to leak the bellow (gasket), leak from drain hose, drain pump, or water valve. Since it could be any one of these underlying issues I would recommend having a technician come out to diagnose and repair your appliance. Hope this is helpful. -Matt
Jul 30, 2014 | Frigidaire Washing Machines
Water leaking from bottom of machine - machine not washing well
It is important that you look underthe washer to confirm the point of leak so as to get a first hand information.If the leak is during the wash cycle it can be from fault of the celing gasket or a leak from the drum moving spindle.However if it is during the rinse cycle,the leak can be from the out let hose,drainvalve/drainpump.If so the hose can be tighten or the valve pump can be removed,repaired and reset.
Aug 31, 2010 | Samsung WF337AA Front Load Washer
Water has started pouring out from under my washer
Hello, you've indicated this problem only arrises during the rinse cycle, is that correct ? The leak doesn't occur during the wash cycle initial fill level ? I want to distinguish the difference because there has been a repair tip issued by whirlpool for the duet and sport washer's. This may be applicable to your machine. If it is indeed only during the rinse, the problem is within the door assembly. Specifically the glass and it's "seat" to the frame. Let me know, I'll watch for your reply. macmarkus :)
Mar 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Got a Kenmore Elite HE3t Front Load washer from my old man, hasn't been used in 5 years... sat in my basement for the first month i lived here unhooked and unused... FINALLY, got a dryer, hook everything...
A burst hose or a broken hose connector clamp most likely. Open the back after disconnecting power. Use bright flashlightto see where its dripping from and confirm the hose-clamp is brokem/ open or a connecting hose is burst. Carry broken hose to hardware store like Rona for a replacement tubing, cut to size and re-instal, voila!
Dec 13, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Leak during rinse and final spin
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
May 20, 2009 | Washing Machines
Washer does nothing during rinse then leaks during spin cycle
hi thanks for the question i would check the drain hose your problem is the washer is not draining check the drain hose thanks the appliance doc
Sep 27, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Leaking
The pumps usually have rubber hoses fitted them and they can deteriorate over time, moreso around the clamps that hold them onto the pump. Also, maybe the pump has been slightly opened via a worn seal. Either way, there may be a risk of fire if any water gets onto the electrical connections of the pump or spray onto any other open electrical connection inside the machine. It would certainly be advisable to have it checked with some urgency.
During the final rinse and spin, I would think the pump may not be used during these cycles.
Hope this helps somewhat.
Sep 14, 2008 | Whirlpool WTW6400SW Top Load Washer
Washing machine
If water is leaking only during the times when it is supposed to be coming in , then the first places to check are at the hose connections and the hoses themselves. If it continues to leak after the water stops coming in , then you have to look at the drain connection and finally at the drum seal.
Nov 22, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore HE2 Plus Front Load Washer Logo
75 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
