Question about Ryobi RHT2660DA Petrol Hedgetrimmer - 26cc Quick Fire Engine
I need the starting instructions - Ryobi RHT2660DA Petrol Hedgetrimmer - 26cc Quick Fire Engine
Owners manual and starting instructions
What model is it? I need more information please
Oct 28, 2012 | Coleman Electrical Supplies
Mac Book Pro repeats Start Up Instructions
what instructions come at startup? please be clear
Mar 21, 2008 | Apple MacBook Pro Notebook
I have a Toro Model #71199 riding mower that I just received as part of my new house. I followed the start up instructions that were written on the machine but can't get it to start. It wants to turn...
.... if it is turning over - or trying to? If it is turning over, is it turning quite fast? If not, battery is weak and needs a charge / replacement, or battery cables need cleaning where they connect to the battery.
Jul 04, 2011 | Toro Garden
I need instruction manual on how to adjust color, ...
Hi, click on the Start Button, in the Start Search Window; Type: power, in the next window; in the (left) Tasks area, click to open "Adjust the display brightness."
May 19, 2010 | Computers & Internet
Need instruction manual
Yes you put the dishwasher soap in the soap dispenser. Then you close the lid to it. then shut the door and start the dishwasher.
Apr 19, 2010 | Kenmore 24 in. 17602 / 17604 / 17609...
Need assistance changing the convergence IC's -STK392-570... can I replace them with a standard soldering iron and non-lead solder? Are they mounted directly on the heat sinks?
I have step by step start to finish instructions for this repair if you want them.
You can use regular solder--the original is lead free, it does not matter.
If you want the instructions rate this solution with 4 thumbs and I will post the instructions for you.
they will tell you everything you need to do the repair and step by step start to finish instructions.
SD TECH
Nov 09, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Need instructions on how to use black and decker jump start
Amazon.com: Customer Reviews: Black & Decker VEC010BD Start It 300 Amp ... Instructions note that units are already partially charged before ... Recent discussions in the Black & Decker VEC010BD Start It 300 Amp Jump Starter forum ...amazon.com/Black-Decker-VEC010BD-Start-Starter/.../B000E1HAIK - 235k - Cached
Feb 22, 2009 | Black & Decker Jump Start System 300 Amp...
Acer l100 will not restart
If it's just not loading Windows, restart into Safe Mode. Instructions here:
http://www.bleepingcomputer.com/tutorials/tutorial61.html
Restore from a system restore point created before you ran the PC tuneup software. Instructions for Vista:
http://bertk.mvps.org/html/restoresysv.html
Instructions for XP:
http://techpaul.wordpress.com/2008/09/04/how-to-use-system-restore-to-fix-windows/
Feb 06, 2009 | Acer Aspireā„¢ T180 PC Desktop
Connect phone to seal sit-up wireless visor kit
Hold onto the second button until you hear a long beep and see 2 buttons flashing red and blue. Then use your phone to pair with the device and the code is "0000".
Oct 23, 2008 | Cell Phones
Open Questions:
I have a Ryobi RHT 2660DA Hedge trimmer that will not start. I have tried the following things; 1. Replacing the spark plug. There is a good spark on both the old and new plug. 2. Adjusted the carburetor as suggested. 3. Put a teaspoon of fuel into the spark plug hole directly. Does not even try. 4. Tried easy start in the spark plug hole directly and into carburetor. No joy. 5. Took off carburetor and cleaned a suggested. No joy. 6. Replaced the available diaphragms (4 in all). No joy. 7. Replace carburetor with a new one. Same result. 8. Checked compression which was only about 50 per square inch. 9. Checked tightness of crankcase screws. All tight. 10. Replace crankcase gasket. Still same compression result. Again no joy. 11. This machine is about 5 years old but only used about 5 or 6 times so should not be a wear problem. 12. Replace mixture (did this early on in the sequence) 13. Took off exhaust which was full of fluid. Cleaned and dried, but to no avail. 14. Stripped unit down as I started to believe this was a timing or compression problems, but I cannot get the bottom clutch unit off (do not know how to remove it as it looks like an interference fit on the shaft. As a result I cannot get to the flywheel to see whether the key way or key has sheared or the timing has somehow moved. I am now at a lost of a way forward. I would appreciate any help or suggestions. At the moment I am left with what is an expensive piece of junk.
Jul 30, 2013 | Ryobi RHT2660DA Petrol Hedgetrimmer - 26cc...
Ryobi RHT2660DA Petrol Hedgetrimmer - 26cc Quick Fire Engine Logo
148 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
