Question about Singer 7470 Confidence Sewing Machine
I bought my machine last yr & just started using it 2 days ago. Now it's acting up? The needle is hitting the bobbin plate. I've notice this is a common thing to happen to other confidence owners.
It was working fine, then all of a sudden it stated catching the material & the needle kept dragging, now it won't work proper. I never touched anything, I just pulled it out of the box and stated using it as is. It came with a needle already in. The screw was so tight on the needle I had to use pliers to loosen.
  • 458 Answers
Sounds like the needle is bent. If it hits the plate just once it will blunt the needle and not sew properly. Failing that, the machine's timing may be off. Was it shifted about a lot in the year it was left in the box?
Posted on Apr 18, 2015
  • Cynthia Sallaberria Apr 18, 2015
    Hi Irene, no it was stored for the length of the time... I did notice the needle is bent now after messing with it. Did you get the picture I sent along with it?
    Thank you!
  • Irene Tulloch Apr 18, 2015
    No I didn't get the picture, hope a new needle will sort the problem
  • 97 Answers
SOURCE: Bobbin problems
Any time you have looping on the bottom, it is almost always related to the upper tension and not anything in the bobbin area.
A good way to troubleshoot this is to turn the machine off, blow out the upper tension disk assemblies with canned air, (the machine needs to be off because most canned air uses butane as a propellant. Butane + electricity = bad;) replace your needle, and rethread your machine. Once you've threaded it to the point where you're about to put the thread through the needle, "floss" the thread forward and backward to ensure that the thread seats correctly into the tension assemblies.
Set your tension to around 4.5 for most applications, and drop your presser foot. Give the thread a gentle tug to see if the tensions have engaged the thread, then thread the needle.
If doing this does not address the problem, you probably need to have your tensions professionally calibrated. This is also true if the needle is in fact hitting something in the bobbin area. This is usually caused by the machine's timing being out of alignment, which is not something that can be fixed at home.
Good luck,
-R
Posted on Sep 10, 2008
SOURCE: Just bought machine, new needle, thread, Needle
try sewusa loads of manuals and sewing diagrams. Since its a older machine.I would clean and oil it also.Lint can cause all kinds of issues.
Posted on Dec 29, 2009
Tally Girl
  • 1125 Answers
SOURCE: Singer Confidence 7463 - needle
Have you changed the needle since you purchased it? A needle should be replaced every 4-6 hours of stitching so for each garment sewn as a rule of thumb. So try replacing the needle, cleaning and oiling the maachine as per the manual. Check needle is in the correct way, it is easy to put in backwards if you aren't familar with them, flat shank to the back and there is usually a scarf (cut away area) at the back of the needle which is where the rotary hook under the needle plate comes around to catch the upper thread during the stitch process. So if needle is in backwards this will cause stitching to fail.
So elimate the needle firstly.
If this fails and the knocking noise continues, then it could be that the timing has been knocked out. It can happen if you sew over a pin and hit it hard (or the needle strikes the foot if stitch setup is wrong for the foot being used). In this case, you'll need to take it back to the shop for the serviceman to fix.
Posted on Mar 02, 2011
  • 111 Answers
SOURCE: I have a Confidence 7470
Sounds like your machine is off timing, When the machine is properly timed, you should see the hook passing behind the eye of the needle when the needle is on it's upward stroke. If this is not correct the machine will not pick up the bobbin thread. You may have to take it in for adjusting, unless your a bit machnical.
Posted on May 12, 2011
Testimonial: "Thank you so much for your prompt and thoughful assistance. I would definitely recommend your service to others."
SOURCE: My Singer 6160's needle is hitting the bobbin plate.
first change the needle--flat side to the back of the machine, make sure the needle is inserted all the way up into the needle holder
make sure it's the correct needle for the machine
if the needle keeps hitting the bobbin plate then the machine may be out of time & would have to be take to a sewing machine shop for retiming.
Posted on May 04, 2012
How to adjust placment of twin needle so it doesnt hit edge of bobbin holder?
The needle should not hit the bobbin holder at all. Do you have the needle inserted all the way? If it is too low, it will hit. If you are saying the needle is hitting the sides of the needle plate where the needle goes through, then the needle is too wide for the plate. Either use a narrower twin needle or see is a needle plate with a wider needle hole came with your machine. Some decorative stitches can't be used with a twin needle because the combination of width of stitches and width of needle is too wide. In that case, narrow the stitch width until the needle doesn't hit the needle plate or use a narrower twin needle. I hope I have helped and answered some of your questions. Good luck.
Apr 26, 2014 | PfaFF Sewing Machines
Bobbin jumping like telltale heart
try changing the bobbin and see if the problem still happens
and if it does happen again then the machine needs to be checked
to see if their is something wrong with the hook and hook race.
Mar 26, 2013 | Sewing Machines
Singer 8763 Needle Won't Go Up and Down
read the user manual and if you do not get anything from the trouble shooting section take it back for a warranty check as something may have moved from the material jam
Apr 12, 2017 | Singer 8763 Curvy
I 've been using this 2639 Singer since 2006. It was working perfect until one day the bobbin case popped up away from the shuttle causing the needle to be blocked from moving. So, I removed the p
First change that needle. It's likely bent. A bent needle won't create a stitch.
Then double check your timing. It sounds like you have it ******** a bit... But that's hard to determine from a description. Before you start the timing process, make sure that your needle bar is in the correct position. (typically the upper timing mark on the needle bar is just below the lower needle bar guide when the needle is at its very lowest point) If necessary loosen the needle bar holder and make a correction. Once the needle bar is positioned correctly... then move on to the shuttle/needle timing.
Nov 03, 2012 | Singer Sewing Machines
Bobbin pops out and needle thread and bobbin thread bird nest
here's my suggestions
change the needle-make sure the needle is inserted correctly
into the needle holder & also turned the right way
make sure when sewing on the machine that the top thread does
not come off the thread take up lever
check the top thread tension it may be too tight,, usually 4 is good
or if the machine has automatic tension set it there
make sure it's the right needle for the machine & make sure it's the
right needle for the fabric & thread.
some thread is knotty ,,, make sure the thread is good quality
Sep 10, 2012 | Singer Inspiration 4210 Mechanical Sewing...
Brother se 400
try changing needles
also possible that the machine is out of time
Apr 09, 2012 | Brother SE400 Computerized Sewing Machine
Needle breaks because it hits the area around the bobbin.
Here are a few things to check. You may have checked some of these already but it may be worth checking again.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but check your manual), make sure that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot
Make sure it’s attached securely.
* Change your pressure foot
Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins
A needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew
You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate
Make sure it's securely in position.
* Change your needle plate
If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics, switch to a needle plate with a wider hole.
* Check the position of your needle
Sewing machines with zigzag capability allow you to adjust the position of your needle – right,left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
I hope this helps.
Dec 30, 2009 | Sewing Machines
Bobbin holder seems to be broke and needle breaks
Here are several things to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate and make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin. There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
Also, before you start to sew a seam, hold the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope these solutions help you.
Sep 20, 2009 | Brother XL-2230 Mechanical Sewing Machine
Safety Feature engaged Brother 270 D
Push the button to put the needle in the up position. Take the hoop off the unit and chekc everything. Rethread the top thread. Take out the bobbin and remove the bobbin plate (the plate, not just the cover). Check under and around the bobbin shuttle as best as you can for threads and lint. Use the brush to remove any lint clumps. If it still not working I would try switching the machine off. If you leave the item hooped and you didn't adjust your design any with the machine before you started stitching you should be able to put it back correctly. Turn the machine back on and try again, skipping ahead in the design to where you stopped before of course. If it still doesn't work contact Brother customer service.
Nov 24, 2008 | Brother SE-270D Computerized Sewing...
I have a singer 5817c
1.Remove the machine needle plate.
2. Remove the bobbin case.
3.Insert a new needle.
4.Turn the handwheel towards you by hand, and watch the
needle going down.It should go down all the way, and start coming Up again, WITHOUT TOUCHING ANYTHING.
Check, and let me Know.
Jun 09, 2008 | Singer 5050 Mechanical Sewing Machine
Singer 7470 Confidence Sewing Machine Logo
44 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
