Question about Car Audio & Video
Can any one help with stereo code. its from fiat scudo pu-2294a and c70000002541. thanks
SOURCE: the gauges on my fiat scudo ie temperature ,speedo ,,clock mileag
check fuse 5 and 12 behind glove box
Posted on Jun 10, 2009
  • 70 Answers
SOURCE: fiat scudo starts and runs for 8 secs then cuts out
8 seconds and stall,..
Sounds like you're starting fine and there's no apparent problem with the engines electrical impulses in regards to wires, plugs, coil etc,..
Which it sounds like you're running off residual fuel but continuous fuel supply is being disrupted.
I'm all but certain if you pull a SP it'll have unburned fuel on it. Check your fuel pump, filter, pressure regulator and injectors
From those symptoms the pump could be faulty, filter clogged and only feeding seepage, the regulator could be flooding it out ot the injectors aren't opening { clogged }
What do you get when you try to press the accelerator when it's running or have you not tried that?
Posted on Jul 27, 2009
  • 4963 Answers
SOURCE: i need a radio code for a pug 106 serial no
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C7000000 + + + + on a label somewhere on the metal casing.
(There are usually two barcodes on one label. The one required is the lower one )
If not then it will only be available from your Main Dealer or a Decoding Service
Posted on Sep 09, 2009
  • 4963 Answers
SOURCE: i have coad for my fiat scudo sterio but dispaying
It is showing ERROR7 because of all the wrong codes being entered previously.
To reset , LEAVE SWITCHED ON....UNDISTURBED for as long as it take to automatically reset itself.
This may take many hours as the waiting time doubles after each wrong code entered.
Make sure you have the correct code.
Posted on Nov 22, 2009
  • 4963 Answers
SOURCE: car radio locked out
The only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also  has a BARCODE SERIAL NUMBER beginning with C7000000 + + + +  on a label somewhere on the metal casing.
If not then it will only be available from  your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM)
If you have this barcode serial number then
POST A NEW QUESTION
Posted on Dec 03, 2009
Code pu-2294a(c) serial:CL040110727344
usually you can define error codes by entering the name of the item and error pu-2294a into google
Jan 26, 2014 | Clarion Car Audio & Video
Code clarion pu-2294a(c)
google: clarion pu-2294a error code
Fitted new cd player in fiat scudo and noticed the lcd mileometer does not work checked fuses but they are fine any ideas
Original stereo units are linked the the display unit if your replacement unit is not an original fit the display will not work.
Dec 01, 2013 | Fiat Cars & Trucks
Need radio code for Clarion Pu-2294A
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your vehicle manufacturer's service centre and get them to enter this code for you.
Apr 03, 2013 | Car Audio & Video
Fiat scudo fuse box
On this website you find fuse box diagram and description for Fiat Scudo mk2
Fiat Scudo mk2 2006 2016 fuse box diagram Auto Genius
Feb 14, 2012 | Fiat Cars & Trucks
Hi I need code for MODEL PU-2294A(C) serial CL040130897281C Thanks
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio
Jun 28, 2011 | Car Audio & Video
What is the meaning of warning code 8350 on my fiat scudo van
i want to reprogramme or change the immobiliser code on my fiat scudo van r reg?
Nov 02, 2008 | 2006 Fiat Strada
Car Audio & Video Logo
103 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
