I need a three digit code to sync my remote with my time warner remote
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
330 334 335 337 338 340 341 342.
Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Posted on Apr 18, 2015
Time Warner codes for Mitsubishi tv
If Time Warner remote is universal, you probably can use its code search feature to find something that will control your Mitsubishi TV. Also, Time Warner might be able to tell you what code to use.
Jan 14, 2015 | TimeWarner Cable Time-warner cable...
Where is "set" button on the remote so I can set DVD code?
You need to be using the TV's remote, not the Time Warner remote.  You are reading the TV's manual to set it's remote, not the Time Warner remote.  If you want the Time Warner remote to operate the TV, you will need to find the instructions that the Time Warner box/receiver provides and enter the TV's code.
Mar 24, 2009 | Toshiba 36A50 36" TV
Trying to find a remote code. The tv is a 19"PLEDV1945A-B and the remote is a Time Warner UR5U-8780L-TWC
TV Instructions:
TV Codes: try 333
or 116, 143, 258, 363
STEP 1 Turn on the TV.
STEP 2 Press the [TV] button and the [OK/SEL] button simultaneously for three seconds. The TV Device LED will turn on indicating that the remote is in the programming mode. The LED will remain on for 30 seconds and the next step must be entered while the LED is on.
STEP 3 Point the remote control toward the TV and enter the three-digit code number assigned to your brand device (codes can be found in the code tables in the user guide or online). If there are more than one three-digit number listed for your brand, try one code number at a time until your TV turns off.
Note: When the TV turns off you can verify that you have selected the correct code by pressing the [POWER] button. The TV should turn back on. Then try all of the functions on the remote control (i.e. volume, mute, etc.) to ensure you have the correct code. If any of the functions do not operate as they should, repeat the instructions from STEP 3 above using the next three digit code number from the brand list.
STEP 4 Store the three-digit code by pressing the [TV] button once again. The TV Device LED will blink twice to confirm that the TV code has been stored.
Program My Remote Time Warner Cable
Nov 13, 2014 | Proscan 19 In. 720p LED HDTV/DVD Combo...
Tengo un control remoto time warner y no encuentro el codigo para box digital no.tb100mw9y no puedo haceer k encienda
003,002,061,028,083,091 are the codes to check. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts. Setup code list and setup instructions to some popular model remote controls are given
Mar 10, 2013 | Televison & Video
Need remote codes to connect with my Time Warner Cable digital box remote
Would have to know what digital box you have. On the back you should have a model number, and there maybe a separate brand other than time warner.
May 03, 2011 | Olevia LT37HVS 37 in. LCD HDTV
Need 3 digit code for controlling sony rdr-gx7 dvd recorder with my time warner cable remote.
This is a common problem for the Sony RDR-GX7 dvd recorder.
It seems to occur with various remotes (DirectTV, Bell ExpressVu or in your case, the time warner cable remote).
In most cases, the problem can be solved by using a different remote frequency from the system menu as follows:
Insert a dvd and make sure it is not playing (stopped).
Enter the System Menu then / Setup / Options / Command Mode (this can be done from the access panel on the front of the unit). There are 3 possible values, (DVD1, 2 or 3), try changing it.
Then enter one of the suggested codes for your Warner remote (in my case, for Bell ExpressVu I selected the DVD1 command mode
and I used 883 as the 3-digit code. The up and down arrows are not functional with this code but I bypass this problem by entering the menu item number. Good luck!
Feb 14, 2010 | Sony RDR-GX7 DVD Recorder
Need Time Warner Remote code for LG 42LB5D HDTV
For Time Warner Cable digital remote controls to work with your 42" LG HDTV, do the following:
1. Press "TV" and "OK" simultaneously for 3 seconds, until the button "tv" light on the remote is on.
2. Enter the TV code. In this case, it's "113". With the right code, your component will turn off. Quickly press the power button on your digital cable remote to turn it back on. Press the "TV" button again so that the remote saves that code.
3. You should be done.
Feb 08, 2010 | Directed 434MHZ Remote Control
Remote codes for dynex tv time warner remote
time warner has only one code and it is 400
Nov 26, 2009 | Televison & Video
Program Time Warner Remote RT-U62CP-1.17 to work ONKYO TX-SR575
i bot a new tv i don't have the book for the time warner remote so i don't know how to program it to work the tv it only works cable box
where can i find how to program remote that comes with time warner cable
Dec 26, 2008 | Onkyo TX-SR573 Receiver
Codes to make my Time warner remote control the tv
Here's the list from Time Warner
http://www.timewarnercable.com/Carolinas/site.faqs/Equipmenta/Remotes/Digital-Remote-TV-Codes
Oct 26, 2007 | Toshiba 36A50 36" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
