Question about Refrigerators
Ice Maker not working
Not working, have replaced mother board & all parts including icemaker, can hear it churning but will not drop ice
  • Refrigerators Master
  • 5,323 Answers
Inspect Water fill tube, Inspect the ice maker mold to see if there are ice cubes present. If there are no cubes or very small cubes, then you should look for issues with the water fill system. Inspect the fill tube and the fill cup area at the back of the ice maker to make sure that they are not frozen. If there is an ice buildup in that area, confirm no foreign objects have disrupted the flow of water into the fill cup. If nothing obvious has caused the ice buildup then suspect the inlet valve, tubing or low water pressure. Inspect the outlet tubing from the fill valve to the ice maker fill tube for any signs of restrictions and replace if necessary.
WATER INLET VALVE:
Check the water inlet valve for any restrictions. You will need to shut off the valve from the household water supply before you disconnect the inlet tubing. Some water inlet valves may have a screen to filter debris before it can enter the valve. If the screen is plugged, water flow will be restricted and the result will be small or layered ice cubes. Remove and clean the screen or replace the valve. If dirt has gotten into the valve it may not shut off completely and will continuously drip water into the ice maker fill tube and will eventually freeze up. Low household water pressure or a restriction at the manual shut off valve will also cause the water inlet valve to not shut off completely and create this same condition. Self piercing saddle valves are the most common shut off valve to cause this problem as the hole that is pierced in the water line is often too small and will more easily become restricted.
The water inlet valve is operated by line voltage supplied through the ice maker control. Power is applied for approximately 7-9 seconds during the harvest cycle and energizes the solenoid on the valve to allow water to flow.
You can check the solenoid for continuity with a multi-meter. On models with multiple solenoid inlet valves, you will need to determine which portion or portions of the valve are used for the ice maker. You can normally follow the inlet tubing from the ice maker back to the valve. Unplug the refrigerator and turn off the water supply to the valve before working with this part.
(HOW TO TEST INLET VALVE: Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush or warm running water. If you cannot clear theclog, it will be necessary to replace the valve (the filter is not removable on most inlet valves). Test thewaterinletvalve for continuity using a multImeter. First, inspect the coil for an indication of it's ohm rating. If no information is printed on the coil, then use the range of 170 to 500 ohms. Set the multitester to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multitester should display a reading that matches the coil's rating or if you don't know the rating then it should fall into the range of 170 to 500 ohms. If the water inlet valve does not pass this test, it should be replaced. If the inlet valve has two coils, test the second coil in the same way (note that they may not have the same ohm rating). The valve can also fail mechanically. So even if it passes the electrical test, it may still require replacement. If you have ruled out all other possibilities, go ahead and replace the valve.
Check the tap valve.A bad tap valve-the little device that connects the ice maker's water supply tube to the water pipe-may cause the problem where the ice maker's supply tube connects to the water pipe. If necessary, replace the inlet valve and the tap valve. For the tap valve, use the type that requires you to drill a 1/4-inch hole (as opposed to the "self-piercing" type). You can buy anice maker connection kitand do this yourself, or call a repair person or plumber to install an inline water filter when replacing the valve.
Lastly the ICE MAKER ASSEMBLY:
If there are no ice buildup issues or suspected problems with the water supply, then you may have a problem with the ice maker control. The most common type of ice maker used in modern refrigerators is the heat release ice maker. The ice maker uses heat to release the ice cubes.
If the water's route is blocked or the solenoid doesn't work-or if the bail wire is lifted-the ice maker won't make ice. (Also note that your home's water pressure may not be strong enough to serve an ice maker.)
If you have a heat release or modular ice maker it will have a removable cover at the front. Behind the cover is a series of electrical test points that can be used to diagnose the ice maker. The unit can be manually operated by inserting an insulated jumper wire into test points "T" and "H" to initiate a "test harvest". On other ice makers jumper at points N & M (neutral to Motor) The jumper should be insulated 14 gauge solid wire that has the insulation stripped back about 3/4 of an inch on both ends, and bent into a "U" shape. When inserted into the test points for 5 to 10 seconds, the motor should start and the cycle will continue on its own. You may have to manually close the freezer door switch for this to operate.
This test will simulate a real harvest cycle and will operate the ejector blades, shut off arm and the fill valve in the proper sequence, and will allow you to do a proper diagnosis. This is a live voltage test and should only be performed by a qualified person. If the motor does not start, you can verify that you have power to the ice maker at test points "L" and "N". If the ice maker is getting power and does not perform a cycle, then the module will need to be replaced
On component mode ice makers the testing is done differently.
Testing a thermostat in a component ice maker:
The thermostat is located near the bottom ofthe support box. The thermostat is connected by two or three wires.Label the wire placement before disconnecting them. Remove thethermostat by loosening the clamp, by pushing back the retainerclips, or by removing the retaining screws.
Test the thermostat forcontinuityusing amultitesterset to the ohms setting X1. Start by testing the thermostat whenit has come up to room temperature (about 20 minutes after removing it from the freezer).
If the thermostat has two wires touch one probe to each wire. You should get a reading of infinity.Chill the thermostat in the freezer for about twenty minutes andretest. This time you should get a reading of zero (continuity).
If the thermostat has three wires, number them 1, 2 and 3. Test combinations 1 & 2, 1 & 3and 2 & 3 and write down the results. Two of the combinations should yield a reading of infinity and one should yield a readingof zero. Now chill the thermostat in the freezer for about twenty minutes and retest. The combination that had a zero reading before, should now have a reading of infinity. One of the two other combinations should now yield a zero reading.If the thermostat fails this test, it should be replaced.
Testing a modular ice maker 'sthermostatcan be tested and replaced individually.
Test the thermostat forcontinuityusing amultitesterset to the ohms setting X1. Start by testing the thermostat when it is cold (10 degrees). Insert one probe into the hole labeled "T" and the other probe into the hole labeled "H". The meter should indicate zero resistance (continuity). After the ice maker has warmed up, repeat the test and this time the meter should indicate infiinity (no continuity).If the thermostat does not pass both tests, it should be replaced.
Posted on Apr 21, 2015
Whirlpool Ice maker broken
First review this YouTube video about how to fix a current Whirlpool ice maker that does not make ice. Most are fixable. (The maker of the video, Repair Clinic, will work with you to find the exact part needed and sell you that part. Excellent company to work with.
Whirlpool Freezer Won Make Ice Ice Maker Assembly W10190965
You can determine which ice maker you need by checking at the Whirlpool website on icemakers.
Whirlpool Refrigerator Ice Makers Replacement Parts Accessories PartSelect
If you have determined that you cannot fix your existing icemaker, try checking Amazon for a replacement.
Amazon com whirlpool ice maker replacement
Feb 09, 2018 | Whirlpool Refrigerators
My icemaker stopped working but the water on the door still works what can the problem be model number 106.51552104
02fd7a9b-9a65-43a6-ae76-6bf68d211304.jpgThanks for the model number. If the ice slots inside the ice maker are empty try pouring tap water in and allow the water to freeze. If after the water freezes the ice drops into the ice bucket and the ice maker does not refill this would indicate that the side of the=> W10408179 Water Inlet Valve is defective on the side that controls ice maker water supply. If the ice maker just sits there and does nothing this would point to a defective ice maker. Depending what is wrong with the ice maker will determine what parts are replaced. Here is a list of those parts here=> Kenmore Refrigerator Model 106.51552104 Ice Maker Parts and if need you may be able to find a complete ice maker replacement by asking. Most people don't like replacing ice maker parts. I am here should you have questions or comments, Sea Breeze
Aug 30, 2013 | Kenmore Refrigerators
Troubleshooting a GE TPX24 icemaker
a19e2387-1433-4c2d-bb46-e670a2bac700.jpgSimple if the ice maker is not filling with water after cycling then fill ice maker until full allow water to freeze and if the ice maker drops the ice into the ice bin and then does not refill with water replace the=> WR57X10051 Water Inlet Valve If the Ice Maker does nothing with ice still inside the ice cube slots then replace the=> WR30X10093 Ice Maker Assembly These ice makers are electronic and once they fail there is no replacable parts. I am here should you have questions, Thanks Sea Breeze
Jan 13, 2013 | GE WR30X10093 Refrigerator Icemaker Kit
Model was bought 1/92. Ice cube maker not working although we hear a churning sound that seems to signal something's trying to work! What do you think? KitchenAid KBRP20EMSS Bottom Freezer Refrigerator
Those ice makers get stuck from frozen ice portions. Try feeling around to see if anything in the icemaker is frozen up or any foreign object. Please do this with fridge unplugged. If you can't find any frozen or other obstruction then use the hair dryer to defrost the ice maker. This is only a guess from past experiences. My kids once put pop cicle sticks in the ice maker wanting to make ice cube on a stick. Goodluck Google burdfrenzy
Nov 26, 2010 | KitchenAid KBRP20EMSS Bottom Freezer...
The icemaker of our Samsung side by side refigerator gets full and clogged up frequently and although we can hear the machine churning inside, ice is not dispensed. We have put in a new water filter after...
Either the icemaker support is broken, DA61-01801A or the ice tray is damaged or has lime buildup. The ice tray is supposed to twist when it flips: an off-center stud on the tray catches the support, while the tray is still turning. If it does twist but does not release ice - replace or clean the ice tray, part number DA63-02284B
Good luck,
Vlad
First Choice Appliance
Aug 17, 2010 | Samsung RS2630SH Side by Side Refrigerator
Water in icemaker overflows into ice cube storage box AND CAUSES ICE CUBES TO FREESE TOGETHER AND FORM BIG ICE CHUNKS. ALSO THE FULL SHUT OFF PADEL HAS ICE FORM ON TOP OF IT
Check the ice maker after it dropped the ice cubes and when it calls for water it should be pouring it for no much more than 7 seconds ,if more it overflows, in this case the module board inside the ice maker has to be replaced(or for almost the same price with parts and labor you can replaced it for a new ice maker) But if water is sitting in the ice maker all the time , the dual valve which supplies water to the ice maker is leaking and needs to be changed (it's located at the back of the fridge in the bottom behind the cover where the water line is hooked up).
Aug 05, 2009 | Refrigerators
My icemaker is not working. Water not filling tray
Probably the valve that feeds water to the ice maker leaks and this water freezes up at the filling tube to the ice maker and the water doesn't go through, but if the filling tube is not frozen and the ice maker doesn't call for water the problem is in the ice maker inside board ,if so you should replace the ice maker.
Jul 14, 2009 | Refrigerators
Same problem
Icemaker is pretty much independent from the mother board, but you don't say why you replaced the mother board, or why you think you need to replace the icemaker (problem with it is?). If you need to replace the icemaker, you can do it yourself rather easily and should save a good chunk of money by doing it yourself.
Jul 09, 2009 | GE GSL25JFPBS Side by Side Refrigerator
I have an old U-line ice maker. I can not find
The mechanical parts of those models is the same as a BI 95 or BI98. If your looking for the faceplate that would be part number 150. This includes the timer motor,gears,water switch, and hold switch. You can order this thru a parts distributor. Appliance Parts Depot or All Brand Parts should be able to help. If you want to replace the complete icemaker assemly that part number is 402
Jul 04, 2009 | U-Line Icemaker
Ice maker won't dump
REMOVE THE FRONT PANEL FROM THE ICE MAKER,SEE IF YOU SEE ANY BROKEN GEARS,ALSO THERE IS A HEATER THAT HEATS UP BEFORE THE DUMP CYCLE TO LET THE ICE DROP OUT,THE BEST TO DO IS REPLACE THE ICEMAKER IF TYOU DON'T FIND ANYTHING,YOUR LOCAL APPLIANCE PARTS STORE SHOULD HAVE ONE FOR AROUND $50,EASY TO INSTALL-MIKE
Mar 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
50 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
