Question about Miscellaneous
Model #is inside the door I can send u a pic - Miscellaneous
    Genius:
  • 1,585 Answers
What is it ure asking
Posted on Apr 19, 2015
52hm95 TV click and back on after 5 mins with no pic
I would suggest removing and inspecting the lamp this model uses to see if it is shattered inside---door is usually as seen from front of set on left side.
Oct 21, 2012 | Televison & Video
Doam light stays on
Hi. I don't know exactly what kind of vehicle you are dealing with so I can give you an answer but it may be generic in content. Usually, if a dome light stays on, it is due to a malfunctioning door jamb switch. It could also be due to a interior switch position on the dome light itself not turning off or stuck in the wrong position even if it has been switched to turn off. The last idea I have maybe a crossed wire or short causing the light to stay on due to a alternate power source that could be battery powered with key off. In any case, you are going to need a wiring diagram of the vehicle circuit involved with the dome light to help you better find all the components and what power and ground should be present. Check out the chilton's books in the library or, if you would like to send me a response with the year, make and model, I may be able to send a pic of the wiring diagram. If you happen to own a Ford Ranger.... the most common cause for this problem is the drivers door jamb switch. It is located inside the drivers door attached to the door lock actuator. They tend to get sticky and eventually stop working altogether. Good luck and let me know if theres any more help needed.
Aug 09, 2012 | Ford Ranger Cars & Trucks
Fridge is warm, was collecting water inside. Freezer is working fine. Increased temp but not responding. It is a bottom freezer model
send the model number off of the fridge,if the freezer is working fine then no air is being blown up to the fridge section,all it does is blow cold air from the freezer to the fridge section so either the door was left open and this is very common with a bottom mount freezer or the evap fan isn't blowing or on some models there's a damper inside the fridge section,the damper door opens and closes to let cold air in,when it reaches temp. the door closes,sometimes the door gets stuck in the closed position or the open position and the fridge freezes or gets warm depending on where the door is.first thing open the freezer door,do you hear the fan blowing,if not you could have a bad evap. fan motor,next look at the ceiling and on the packages,do you see frozen water droplets,if so the door was left open and the air ducts are froze up from the warm air getting in from the door being open and mixing with the cold air freezes up the air ducts,also stick your hand onto the back inside wall of the freezer,if there's like snow or frost on the inside back wall of the freezer you could have a defrost problem,bad defrost thermostat,heater,timer or board depending on the model or last a bad damper,when you open the fridge door there are air ducts usually up top and in the middle you should feel cold air blowing in,this is your problem the air isn't making it into the fridge section.if the door was left open,unplug the fridge,remove the food from the freezer and with a hair dryer heat up the back inside wall of the freezer and blow the hot air into the air vent holes in the back wall to melt out the air ducts,keep heating it up until you don't see any more water dripping,you can see the water dripping through the vent holes.so let me know what you find,send the model number and we can go from there.look up near the ceiling in the fridge section on the right hand wall and you should see a tag with the model and serial numbers,send the full model number so i can see what you have in your machine.
Jun 12, 2011 | Maytag Refrigerators
I need to transfer internal memory photos onto memory card
First need to take off the SD card; default settign make the SD card as main stored when this is inside the camera.
Take off the SD card and send the internal memory pics at pc folder (use USB connection); insure that the pics are in this pc folder, them delete the files in "internal memory".
Take on the SD card inside tha camera and send pics from pc folder at camera, confirm that the pics are there.
Hope helps.
Apr 28, 2011 | Fuji FinePix A850 Digital Camera
Do you have a pic posted on how to replace the roller on the whirlppol duet dryer , Mine is making loud noises.
heres a video of a guy on youtube successfully changing the dryer belt you can see in this video the location of the pulley and if you send me your model number i can send you detailed schematics on how the machine comes apart if you have any further questions please message me back and please remember when this chat is through to rank how this opinion has helped in your appliance situation thanks again
Rick
http://www.youtube.com/watch?v=btoFRFXVJCE
personally i would take the whole drum out to replace the pulley gives you alot more room i await your reply
Dec 21, 2010 | Dryers
Pls i am fady from lebanon i wana see the pics model of toyota carburator 1988 automatic
I do have a complete carbettor manual. email me at iambanshee74@yahoo.com and I will send this out immediately to you via email.
Jul 24, 2010 | 1988 Toyota Corolla 4 Door
The opening door handel broke off.
This is a generic response to your comment
Look at the inside of the door, you will probably find a plastic strip which can be pried out. Underneath the strip, you will find the screws that hold the door together. The screws may be "torx" head.
Take pics of your door with your cell phone as you work and remember, most doors are spring loaded. Watgch your fingers.
Once the door is split open, replacing the handle should be a simple matter.
I hope this helps you
a
Sep 22, 2009 | Jenn-Air JMV8208A Microwave Oven
Door latch opens and shuts off the camera on my S2 Pro Fuji FineP
I also own a Fuji Fine Pic Pro (mine is a S3). If there are no authorized dealers around you that can fix your camera I would send it in. Here is a link to send it to Fuji. Send it Priority mail and siginature confirmation. It will cost a little more to do this but it will insure that you know who signed for your camera. Also insure it. Hope this helps.
Here is the link:
https://camerarepair.fujifilmusa.com/Forms/RepairForm.htm
Jul 09, 2009 | Fuji FinePix S2 Pro Digital Camera
Inside Door Door Handle on Drivers Side of 1987 Chrysler Fifth Avenue Broke off. How do I remove door panel and replace it?
Get a Haynes manual for this model year
http://www.partstrain.com/ShopByDepartment/Repair_Manual/CHRYSLER/FIFTH_AVENUE
Are other sources, wortwhile every cent.
All you need to know for that car with full pics, drawings, solutions, etc.
I always use them if available.
You have to remove all attachements inside first carefully and the remove the inside cover with a protected screwdriver normaly proning.
Don't for get to rate me
May 07, 2009 | 1987 Chrysler Fifth Avenue
Craftsman 1/2 HP door opener bounces back open
There should be 2 sensors on the bottom of your door on the inside, 1 on the right side and 1 on the left side.
These sensors serve 1 purpose to send a beam or reflection to each other.
If something is blocking this reflection or is in front of the sensor the door will always come back up.
It is a safety feature so nothing or no one gets hurt when the door is closing!
Sep 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Miscellaneous Logo
37 people viewed this question
Top Miscellaneous Experts
steve cannon
Level 1 Expert
bill tarkulich
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
