Pressing dryer program but keeps washing. What am I doing wrong hope you can help thank you
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Try unpluging for 15mins retry
Posted on Apr 18, 2015
Err message whatever I press!
Try unplugging the washer, wait about 10 minutes and plug it back in. Maybe this will reboot your washer. Since most new washers are digital and maybe this will help. Good luck
May 13, 2014 | Zanussi ZWD1470W Front Load Washer / Dryer
Ariston combo ( washer + dryer)
Hi there the controller board is faulty replace main controller board.
Thanks J
Feb 05, 2008 | Ariston Technologies AWD120 13 lb. Washer...
I have a Whirlpool commercial dryer model number LEQ7030KQ1. I will wash a load a clothes in the wash machine and they will come out so they are as spun dry as they can get. The problem I experience is...
Did you mean that you need to press manually to have the drying done well, if so the program settings is what is wrong?
Does a good timing setting work on the set?
Please clarify more.the fault you are.experiencing.
Sep 28, 2010 | Whirlpool LEQ7030KQ Electric Dryer
Ariston Margherita Washer Dryer 2000 dries when not supposed to.
I think I am right in saying that on this machine you have the facility to either incorporate the drying process as part of a program or you can use it as a stand alone dryer, is it possible that you have simply asked the machine to dry after wash by selecting a wrong program is there a another button that allows you to wash with out dry even on a wash dry program if there is such a button/switch and it does not seem to do much it could be that the switch contact have corroded and are not making proper electrical contact check manuel
NEVER OPEN MACHINE CASE WHILST STILL CONNECTED TO MAIN POWER SUPPLY
Jan 17, 2010 | Washing Machines
Hotpoint wd420 washer dryer door won't open.
Press the start cancel button for at least 2 seconds, switch off, leave for 2 mins,switch on again holding the botton for 2 secs, then press start cancel buuton again for at least 2 seconds, hope fully ,this should do ths trick.
Thanks
Plz rate my solution
Jan 22, 2009 | Hotpoint Ultima WDM73 Front Load Washer /...
Dryer
It sounds as if you have the dryer button pressed in before you start the wash! If you don't. it is likely it is stuck in or the switch is shorting out on the back. Unless you are a competent DIYer, find someone who is to check the electrical connections and test whether the switch is working correctly.
Sep 14, 2008 | Ariston Technologies Ariston AWD12 Front...
Dryer not spinning
ok this sounds simple
if the dryer stopped spining there are 4 things to look at
1 the belt for dryer if this snapped the drum will stop spining
2 the dryer wheels these ware down and break off this is what helps keep dryer in a spin straight
3 this is the crucial one the motor siezed up from lack of appliance oil not being added to a regular maintenance
4 the guages has stopped working but i doubt this if it still keeps a timer going round this would not be it you dont have to run dryer to test guages just set guage to a time and see if it rotates with the time on it
the belt you can check your self by pulling down the dryer pan that will show bottom of dryer with belt if its a belt simple maytag can come out and do a replacement and maintenance on the spot
i hope this helped seeing im not there to actually see in person whats actually wrong
May 17, 2008 | Maytag LSE7806A Top Load Stacked...
How to use the dryer of my Candy Aquaviva 1300 please?
wahing machine works great but a cant work out how to use dryer
Feb 21, 2008 | Candy AQ130 Front Load Washer
Aml 125 washer - washing for hours
i would never suggest working or attempting to work on a machine covered by guarantee but this sounds like there is a fault with the heat cycle, obviously the machine keeps tumbling until the heat reaches the right temperature, with a heat fault it will not advance, to test without removing screws etc, press any heat option button like economy or turn heat dial to no heat etc, see what happens next. hope i have helped, if so rate me please, please note most engineers know if a machine of that age has been worked on and this will void any guarantee
Sep 07, 2007 | Ariston Technologies AW125NA 13 lbs. Load...
Error message "test"
yhe washing machine has been put into test mode to get out of this mode you must press and hold down the On/Off and Start/Cancel buttons until "d off" is displayed that will get you out of the test mode
Jun 24, 2007 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
